[Mapserver-users] arcims emulation and arcexplorer
Howard Mark
MHoward at spaceimaging.com
Mon Jun 30 11:07:31 EDT 2003
Sean, Ed
I can't imagine why you'd want to do packet-sniffing. When I was
developing my ArcIMS emulator, I simply wrote the ArcXML dialog out to a
file. It's easy to output the URL with variables and all the XML. I'd feed
back my hand-edited XML files as a response to check syntax..... This is
simple using JAVA servlets.
I still log all requests and responses. Here's some sample log (server
names changed to protect the innocent):
CATALOG CALLED
<?xml version="1.0" encoding="UTF-8"?><GETCLIENTSERVICES/>
http://<server>.spaceimaging.com/servlet/com.esri.esrimap.Esrimap
ServiceName=catalogREQUEST = catalog
CATALOG CALLED
ServiceName=Space_Imaging_Mosaic&CustomStream=FalseREQUEST =
<?xml version="1.0" encoding="UTF-8"?><ARCXML version="1.0.1"><REQUEST
dpi="96"><GET_SERVICE_INFO/></REQUEST></ARCXML>
SERVICEINFO CALLED203
cmd=getversionGetversion Request
version="1.1"><REQUEST><GET_IMAGE autoresize="true"><PROPERTIES><MAPUNITS
units="DECIMAL_DEGREES"/><FEATURECOORDSYS id="4326"/><FILTERCOORDSYS
id="4326"/><FILTERDENSIFY tolerance="1.30258337923976E-02"/><IMAGESIZE
dpi="96" scalesymbols="true" height="561" width="549"/><ENVELOPE
minx="-105.02977105628" miny="39.7372540449187" maxx="-104.97766772111"
maxy="39.7717835433104"/><BACKGROUND color="254,253,252"
transcolor="254,253,252"/><OUTPUT type="png"/><LAYERLIST
order="true"><LAYERDEF id="FB_5M_MOSAIC:V880_5M_FUSEBLEND" name="5 Meter
FuseBlend" visible="true"/><LAYERDEF id="IK_1M_MOSAIC:V880_1M_IKONOS"
name="1 Meter Ikonos" visible="true"/><LAYERDEF
id="PROMO_IMAGES:V880_CSDATA" name="1 Meter Promotional Imagery"
visible="true"/></LAYERLIST></PROPERTIES></GET_IMAGE></REQUEST></ARCXML>
GET_IMAGE CALLED
URL CALLED =
http://t3host/t3?userid=AIMS&passwd=AIMS&request=map&srs=EPSG:4326&format=JP
EG&width=549&height=561&layers=FB_5M_MOSAIC:V880_5M_FUSEBLEND,IK_1M_MOSAIC:V
880_1M_IKONOS,PROMO_IMAGES:V880_CSDATA&quality=QUICKEST&wmtver=1.0&bbox=-105
.02977105628,39.7372540449187,-104.97766772111,39.7717835433104
<ARCXML version="1.0">
<RESPONSE>
<IMAGE>
<ENVELOPE minx="-105.02977105628" miny="39.7372540449187"
maxx="-104.97766772111" maxyy="39.7717835433104"/>
<OUTPUT
url="http://<IMAGE_SERVER>.spaceimaging.com/images/arcims/1053545812015.jpg"
</IMAGE>
</RESPONSE>
</ARCXML>
1844 (ms response time)
Mark
-----Original Message-----
Sent: Friday, June 27, 2003 8:09 PM
To: Sean Gillies; Mapserver Users
Subject: RE: [Mapserver-users] arcims emulation and arcexplorer
Sean -
I was just about to post a similar message, asking for ArcExplorer help!
I could really use some help in trying to diagnose just why my emulator
works fine under ArcMap and does NOT work under ArcExplorer. The two do
use somewhat different "dialects" for the conversation, but I have spent
several days of packet-sniffing, comparing the dialog with a "good"
ArcIMS server and with my server, and I cannot figure out why mine is
treated differently!
If there's anyone with ArcIMS experience, particularly someone who is
familiar with the actual HTTP dialog between the client and server,
please speak up. I'd like to help fix Sean's problem, and I'll offer
free access to our ArcIMS USGS DRG, DOQQ, and GDT Dynamap/2000 services
if you need to be bribed <g>.
Sean, if someone intelligent joins us, I'll start posting my
observations on the dialog between client and server.
- Ed
Ed McNierney
President and Chief Mapmaker
TopoZone.com / Maps a la carte, Inc.
73 Princeton Street, Suite 305
North Chelmsford, MA 01863
Phone: (978) 251-4242 Fax: (978) 251-1396
ed at topozone.com
Sent: Friday, June 27, 2003 8:57 PM
To: Mapserver Users
Subject: [Mapserver-users] arcims emulation and arcexplorer
I've been writing a Python MapScript version of Refractions' imsemu.pl.
It works with ArcCatalog/ArcMap, but with ArcExplorer I get an
error message:
org.xml.sax.SAXParseException: Document root element is missing
What is ArcExplorer expecting differently? Another version of
Arcxml than 1.0? Differently formed XML? Is there any reference
for this? I'm hoping that those who've put together the new
emulators might clue me in. I'd like to use ArcExplorer to test
and debug my app (rather than ArcMap).
thanks,
Sean
Sean Gillies
sgillies at frii dot com
http://www.frii.com/~sgillies
Mapserver-users mailing list
Mapserver-users at lists.gis.umn.edu
http://lists.gis.umn.edu/mailman/listinfo/mapserver-users
This message is intended only for the use of the Addressee and may
contain information that is PRIVILEGED and CONFIDENTIAL.
If you are not the intended recipient, you are hereby notified that any
dissemination of this communication is strictly prohibited. If you have
received this communication in error, please erase all copies of the
message and its attachments and notify Space Imaging immediately.
