[Mapserver-users] arcims emulation and arcexplorer
    Howard Mark
    MHoward at spaceimaging.com
    Mon Jun 30 08:40:43 PDT 2003
Sean,
Great - that methodology makes sense.
I see your emulator is Perl (ish?). I'm going to talk to my supervisor about
distributing our JAVA version for the "Perl impaired" .
Mine works in a very similar manner as yours excepting the configuration.
There is a master catalog XML file that is simply fed back on a catalog
request.
Each service has it's own file that is fed back on a serviceinfo request.
These files are maintained by the administrator (of course).
I'm just getting aroud to setting up a config file that would allow the user
to specify:
The WMS server URL for each service
The local physical image location
The virtual image location
It would be great if we could collaborate on this - so our configurations
match.
What do you think about this idea?
BTW - are you still at I3? I worked last week with Randy setting up their
ArcIMS -> WMS connector using our JAVA version!
Small world.
Mark
-----Original Message-----
Sent: Monday, June 30, 2003 9:24 AM
To: Howard Mark
Cc: Mapserver Users
Subject: Re: [Mapserver-users] arcims emulation and arcexplorer
Yeah, this is exactly what I did as well.  No packet sniffing
required.
Sean
On Monday, June 30, 2003, at 09:07  AM, Howard Mark wrote:
> Sean, Ed
>       I can't imagine why you'd want to do packet-sniffing. When I was
> developing my ArcIMS emulator, I simply wrote the ArcXML dialog out to
> a
> file. It's easy to output the URL with variables and all the XML. I'd
> feed
> back my hand-edited XML files as a response to check syntax..... This
> is
> simple using JAVA servlets.
> I still log all requests and responses.  Here's some sample log (server
> names changed to protect the innocent):
Sean Gillies
sgillies at frii dot com
http://www.frii.com/~sgillies
This message is intended only for the use of the Addressee and may
contain information that is PRIVILEGED and CONFIDENTIAL.
If you are not the intended recipient, you are hereby notified that any
dissemination of this communication is strictly prohibited. If you have
received this communication in error, please erase all copies of the
message and its attachments and notify Space Imaging immediately.
More information about the MapServer-users
