[Mapserver-users] arcims emulation and arcexplorer
Ed McNierney
ed at topozone.com
Mon Jun 30 12:04:07 EDT 2003
Mark -
No problem. The ArcMap client seems much cleaner and more well-behaved than the ArcExplorer client - Chris' decoding of what "CustomStream" meant sure eluded me for a while!
- Ed
-----Original Message-----
From: Howard Mark [mailto:MHoward at SpaceImaging.com]
Sent: Monday, June 30, 2003 12:02 PM
To: Ed McNierney; Mapserver Users
Cc: Williams John
Subject: RE: [Mapserver-users] arcims emulation and arcexplorer
Ed,
OK - I see. I thought you were doing ethernet packet-sniffing (that's
different!).
This HTTPLook is very interesting.
Thanks for the info!
Mark
Sent: Monday, June 30, 2003 9:52 AM
To: Howard Mark; Sean Gillies; Mapserver Users
Mark -
Well, packet-sniffing by any other name is just as useful <g>. I just
downloaded HTTPLook and managed to get a complete log of the HTTP
conversation about 5 minutes after I started without writing any code...
Part of the problem is that the complete interface (for which I have no
documentation) is not very "clean". For example, not all responses are XML
(cmd=GetVersion, for example).
And, as I've just learned from Chris and Sean (and confirmed), the
ArcExplorer client uses the "CustomStream" parameter to select an ArcXML
output format wrapped in a few bytes of binary data, which is not at all
obvious in the data stream if you're expecting it to be text!
- Ed
Ed McNierney
President and Chief Mapmaker
TopoZone.com / Maps a la carte, Inc.
73 Princeton Street, Suite 305
North Chelmsford, MA 01863
ed at topozone.com
(978) 251-4242
This message is intended only for the use of the Addressee and may
contain information that is PRIVILEGED and CONFIDENTIAL.
If you are not the intended recipient, you are hereby notified that any
dissemination of this communication is strictly prohibited. If you have
received this communication in error, please erase all copies of the
message and its attachments and notify Space Imaging immediately.
