[Mapserver-users] query
Srinivas Reddy
csr at rboxtech.com
Thu Mar 6 01:10:07 PST 2003
Thanks for replay Mr.Antti Roppola,
I traid which u explained in such way. Still i did not get the result.so
what i will do for this.
csreddy
----- Original Message -----
To: <csr at rboxtech.com>
Cc: <Mapserver-users at lists.gis.umn.edu>
Sent: Thursday, March 06, 2003 2:30 PM
Subject: RE: [Mapserver-users] query
> I have only taken a cursory glance at your code but:
> $mappointq->setXY($map_x,$map_y);
> $mappointq->setXY($map->width / 2,$map->height / 2);
> Won't this set your query point to *only* the latter?
> And this won't be in map coordinates, but page coordinates.
> Maybe try manually setting to known coordinates and test that
> you are actually getting results back before trying to read them:
> $mappointq->setXY(-36.25,145.30); // pick a known good coordinate
> for ($ilayer=0; $ilayer<=$map->numlayers; $ilayer++)
> $selLayer = $map->GetLayer($ilayer);
> // you'll get output in your web browser here if no
> // results are being returned.
> $selLayer->queryByPoint($mappointq, MS_MULTIPLE, -1);
> Hope this helps,
> Antti
> -----Original Message-----
> From: Srinivas Reddy [mailto:csr at rboxtech.com]
> Sent: Thursday, 6 March 2003 3:34 PM
> To: Mapserver-users at lists.gis.umn.edu
> Subject: Re: [Mapserver-users] query
> Thanks Eric, But i like to display the query resutls in the same page. I
> written like this
> $mappointq = ms_newpointObj();
> $queryResult = $selLayer->queryByPoint($mappointq, MS_MULTIPLE, -1);
> for the above code i did not get any results. So how can i get the results
> form the layer? Can anyone help this point.
> From: "Eric Bridger" <eric at gomoos.org>
> Sent: Wednesday, March 05, 2003 4:54 PM
> You will need to define a TEMPLATE "template.html" in your LAYERS. Even
> if you do not want to use the templates.html to display the results, you
> still need to have a TEMPLATE in the layer. The html does not even to
> exist.
> Hope this helps.
> Eric
> On Wed, 2003-03-05 at 12:45, Srinivas Challa wrote:
> > Hi Daniel,
> > Thanks for the replay, I need ,?When I am clicking on map selected at
> point or in rectangle area content recognitions with PHP. I had written
the
> map file like this
> > MAP
> > NAME "New Demo"
> > STATUS ON
> > EXTENT 184861.560567497 88197.0005976087 2380774.92575433
> 826403.167230631
> > SIZE 800 480
> > SHAPEPATH "data"
> > IMAGECOLOR 255 255 255
> > UNITS meters
> > WEB
> > IMAGEPATH "/apache/htdocs/tmp/"
> > IMAGEURL "/tmp/"
> > METADATA
> > "WMS_TITLE" "New Demo"
> > "WMS_ABSTRACT" "Information system"
> > "WMS_ACCESSCONSTRAINTS" "none"
> > "WMS_ONLINERESOURCE" "http://localhost:81/demo/demo.phtml"
> > "WMS_SRS" "EPSG:26915"
> > END
> > END
> > # Start of reference map
> > REFERENCE
> > STATUS ON
> > IMAGE "graphics/refreance2.gif"
> > SIZE 200 80
> > COLOR -1 -1 -1
> > OUTLINECOLOR 0 0 255
> > MARKERSIZE 3
> 826403.167230631
> > END
> > QUERYMAP
> > STATUS ON
> > SIZE 400 400
> > STYLE HILITE
> > COLOR 255 0 0
> > END
> > # Start of legend
> > LEGEND
> > KEYSIZE 18 12
> > LABEL
> > TYPE BITMAP
> > SIZE MEDIUM
> > COLOR 0 0 89
> > END
> > STATUS ON
> > END
> > # Start of scalebar
> > SCALEBAR
> > STATUS TRUE
> > COLOR 0 0 0
> > OUTLINECOLOR 0 0 0
> > UNITS kilometers
> > INTERVALS 5
> > SIZE 200 5
> > STYLE 0
> > LABEL
> > SIZE tiny
> > COLOR 0 0 0
> > END
> > END
> > # Start of symbol definitions (we're only using a few)
> > SYMBOL
> > NAME "circle"
> > TYPE ELLIPSE
> > FILLED TRUE
> > POINTS
> > 1 1
> > END
> > END
> > # Start of layer definitions
> > LAYER
> > NAME "Boundary"
> > STATUS ON
> > CONNECTIONTYPE OGR
> > CONNECTION "data/Boundary.tab"
> > TYPE POLYGON
> > CLASSITEM "NAME"
> > LABELITEM "NAME"
> > METADATA
> > "DESCRIPTION" "Daerah"
> > "RESULT_FIELDS" "Name"
> > "WMS_TITLE" "Selected Information"
> > "WMS_ABSTRACT" "more information."
> > END
> > CLASS
> > COLOR 255 255 200
> > OUTLINECOLOR 0 0 0
> > LABEL
> > MINFEATURESIZE 40
> > MINDISTANCE 150
> > POSITION CC
> > SIZE TINY
> > COLOR 0 0 200
> > END
> > END
> > End
> > LAYER
> > NAME "Fed_Rd"
> > STATUS ON
> > CONNECTIONTYPE OGR
> > CONNECTION "data/Fed_Rd.TAB"
> > TYPE LINE
> > #STYLEITEM "AUTO"
> > CLASSITEM "NAME"
> > LABELITEM "Name"
> > METADATA
> > END
> > CLASS
> > COLOR 255 0 0
> > #OUTLINECOLOR 255 0 0
> > LABEL
> > #MINFEATURESIZE 40
> > #MINDISTANCE 150
> > POSITION CC
> > SIZE tiny
> > COLOR 10 100 100
> > #SHADOWCOLOR 80 80 80
> > #SHADOWSIZE 1 1
> > END
> > END
> > END
> > LAYER
> > NAME "Highway"
> > STATUS ON
> > CONNECTIONTYPE OGR
> > CONNECTION "data/Highway.TAB"
> > TYPE LINE
> > # STYLEITEM "AUTO"
> > CLASSITEM "NAME"
> > LABELITEM "NAME"
> > METADATA
> > END
> > CLASS
> > #SYMBOL "MYSYMBOL"
> > COLOR 46 210 200
> > LABEL
> > MINFEATURESIZE 40
> > MINDISTANCE 150
> > POSITION CC
> > SIZE TINY
> > COLOR 0 800 200
> > END
> > END
> > END
> > LAYER
> > NAME "Railways"
> > STATUS ON
> > CONNECTIONTYPE OGR
> > CONNECTION "data/Railway.TAB"
> > TYPE LINE
> > STYLEITEM "AUTO"
> > CLASSITEM "NAME"
> > LABELITEM "NAME"
> > METADATA
> > END
> > CLASS
> > NAME "Rail Lines"
> > COLOR 0 0 0
> > OVERLAYSYMBOL dashed2
> > OVERLAYCOLOR 0 0 0
> > OVERLAYSIZE 3
> > LABEL
> > MINFEATURESIZE 40
> > MINDISTANCE 150
> > POSITION CC
> > SIZE TINY
> > COLOR 100 0 200
> > END
> > END
> > END
> > LAYER
> > NAME "State_Rd"
> > STATUS ON
> > CONNECTIONTYPE OGR
> > CONNECTION "data/State_Rd.TAB"
> > TYPE LINE
> > #STYLEITEM "AUTO"
> > CLASSITEM "NAME"
> > LABELITEM "NAME"
> > METADATA
> > END
> > CLASS
> > COLOR 180 180 180
> > LABEL
> > MINFEATURESIZE 40
> > MINDISTANCE 150
> > POSITION CC
> > SIZE TINY
> > COLOR 220 100 0
> > END
> > END
> > END
> > # Seven Layer Under tesing Process... sucessed
> > LAYER
> > NAME "Towns"
> > STATUS ON
> > CONNECTIONTYPE OGR
> > CONNECTION "data/ Towns.TAB"
> > TYPE POINT
> > CLASSITEM "TOWN"
> > LABELITEM "Town"
> > METADATA
> > "DESCRIPTION" " Towns"
> > "RESULT_FIELDS" "Town"
> > END
> > CLASS
> > SYMBOL 'symbols/town.gif'
> > LABEL
> > MINFEATURESIZE 100
> > MINDISTANCE 450
> > POSITION LC
> > SIZE TINY
> > COLOR 40 100 40
> > END
> > END
> > END
> > # End of the map
> > END
> > For the above map Script is working fine. But while I am querying I did
> not getting the results. How can query the map using PHP at point and
> selected rectangle area.
> > Is any one can send the script for this.
> > In this project i am not using applets. Just Map querying on 7 layers
> using php.
> > srinivasa reddy Challa
> > Srinivas Reddy wrote:
> > > Now am new to this technologies but I had done some of project with
> > > the reference of DM solutions map reference. In DM
> > > solutions they are done using SHP data files. But I am using "*.Tab"
> > > data. How can I query the content of the "*.TAB"layers
> > > using php and mapscript. This is my problem. This is my email id :
> > > csr at rboxtech.com or reddy_challa at yahoo.com
> > You will have to provide more details on what you are trying to do
> > exactly if you want anyone to be able to help.
> > If by "query the contents of .tab layers" you mean clicking on a map
> > image and selecting features from a TAB layer then this works the same
> > way for shapefiles and for .tab files. The only difference is that you
> > need MapServer with OGR support, and you define an OGR CONNECTION in
> > your LAYER. For more details on using OGR CONNECTIONS, see the OGR
> > HOWTO at http://mapserver.gis.umn.edu/doc36/ogr-howto.html
> > Daniel
> > Daniel Morissette morissette at dmsolutions.ca
> > DM Solutions Group http://www.dmsolutions.ca/
> > Mapserver-users mailing list
> > http://lists.gis.umn.edu/mailman/listinfo/mapserver-users
More information about the MapServer-users
