[Mapserver-users] shapefiles
Vincent Schut
schut at sarvision.com
Thu May 1 08:09:51 EDT 2003
Probably you will have to change the 'extent' parameter in the map file. Try
setting it to the boundingbox of the shapes you have. If you don't know this,
(i think) you can obtain the bounding box coordinates using the ogrinfo
utility that comes with gdal. Eventually change the projection and units
also.
Regards,
Vincent Schut.
On Thursday 01 May 2003 13:19, sanjay tiwary wrote:
> Hi All I have used examle given on the link
> http://mapserver.gis.umn.edu/cgi-bin/wiki.pl?PHPMapScriptRH73which is
> working fine.Now i want to use the same example with the shape files i am
> gettingfrom the link http://www.vdstech.com/map_data.htm ( data -
> india)but the final output is a blank page, nothing is diplyed.
> How it is happening? I have changed the name of data
> section in the .map file to include new data.Everything else remains
> same.How to get that? Sanjay Catch
> all the cricket action. Download Yahoo! Score tracker
______________________________________
Vincent Schut (schut at sarvision.com)
Sarvision B.V.
Wageningen, The Netherlands
www.sarvision.com
