[Mapserver-users] Problems with PerlMapscript 3.7 Syntax
Lowell Filak
lfilak at medinaco.org
Thu May 1 14:07:03 EDT 2003
There are a few things here that may be causing the exit during the setting of the image type, ie. "use strict".
Have you already tried tuirning on the debugging to see if you receive a better message of what is occuring?
Lowell F.
The following message was sent by Babak Toloue Tehrani <babak.tehrani at geosysnet.de> on 01 May 2003 16:34:07 +0200.
> Hello,
> I have still problems with perlmapscript 3.7. The demo below with the
> syntax of perlmapscript 3.6 is working very fine on my system. shp2img
> is also working for the mapfile below.
> >From the WIKI MigrationGuide I Take the syntax for saveImage():
> $img->saveImage('test37.png');
> and get following output:
> Can't locate auto/mapscript/imageObj/saveImage.al in @INC (@INC
> contains: /usr/lib/perl5/5.8.0/i586-linux-thread-multi
> /usr/lib/perl5/site_perl/5.8.0/i586-linux-thread-multi
> /usr/lib/perl5/site_perl/5.8.0 /usr/lib/perl5/site_perl .) at test37.pl
> line 7
> Then I looked for the string saveImage in the mapscript.pm module and
> found the function msSaveImage who brings me following output:
> Usage: msSaveImage(map,img,filename); at test37.pl line 7.
> I tried: $map->msSaveImage($map,$img,'test37');
> and got same errormessage as before. Then I tried to set the set the
> ImageType with:
> map->setImageType("png") or die('Unable to setImageType.');
> and see that it failed. Here the script and the mapfile:
> (Does someone now a tool to extract from a perl Module (mapscript.pm) a
> list of all Classes/Objects, Members and Methods?)
> Thanks a lot,
> Babak
> #!/usr/bin/perl -w
> use mapscript;
> use strict;
> my $map = new mapscript::mapObj("data/demo37.map") or die('Unable to
> OPEN mapfile.');
> $map->setImageType("png") or die('Unable to setImageType.');
> my $img = $map->draw() or die('Unable to DRAW mapfile.');
> $img->free();
> NAME DEMO37
> STATUS ON
> SIZE 600 450
> EXTENT 5.3 55.5 15.5 46.9
> UNITS METERS
> SHAPEPATH "data"
> IMAGECOLOR 255 255 255
> OUTPUTFORMAT
> NAME png
> DRIVER "GD/PNG"
> MIMETYPE "image/png"
> IMAGEMODE PC256
> EXTENSION "png"
> END
> LAYER
> NAME TESTLAYER
> TYPE POLYGON
> STATUS DEFAULT
> DATA lnd01dd.shp
> CLASS
> NAME TESTCLASS
> SYMBOL 0
> COLOR 195 195 195
> OUTLINECOLOR 102 102 102
> END
> END
> END
> Mapserver-users mailing list
> Mapserver-users at lists.gis.umn.edu
> http://lists.gis.umn.edu/mailman/listinfo/mapserver-users
