[Mapserver-users] Size's line
Dean Gadoury
gadoury at dmsolutions.ca
Fri May 2 07:36:21 PDT 2003
--------------030406040308000709080009
Content-Type: text/plain; charset=us-ascii; format=flowed
Content-Transfer-Encoding: 7bit
I have observed that this seems to be one of the most frequently asked
questions on the list, aside from compilation / installation issues. It
seems to trip up new users very frequently and I think its fair to say
that that is because setting a circle symbol for a line is, at first
glance, counterintuitive.
Has there ever been any consideration of the idea of making a circle
symbol default when setting the thickness property of lines? That would
make things more intuitive and more in line with the way other web
mapping, GIS, and graphics packages work. In fact, Mapserver is the only
application I've ever used in which you need to apply a symbol to a line
to adjust its thickness. I guess there is a dependency on the symbol
file, but could things be done in such a way that a circle symbol is
available in the actual core of Mapserver and is used by default? Users
could still override this if they choose to use a symbol, but if not
they get the circle symbol and only have to use size to define the
thickness of a line.
Dean Gadoury
Eric Bridger wrote:
>Yes. Add the following to your map file:
>SYMBOL
> Name 'circle'
> Type ELLIPSE
> Filled TRUE
> Points
> 1 1
> END
>END
>LAYER
>TYPE POLYGON
>CLASS
> OUTLINECOLOR 255 0 0
> SYMBOL 'circle'
> # this size will determine the thickness of your line.
> SIZE 3
>END
>At 01:59 PM 05/02/2003 +0200, Marco Ferrari wrote:
>>Hi,
>>Is possible to define the line's size of the polygon, as
>>for example, "outlinecolor" defines the line's color?
>>Thanks.
>>_______________________________________________
>>Mapserver-users mailing list
>>Mapserver-users at lists.gis.umn.edu
>>http://lists.gis.umn.edu/mailman/listinfo/mapserver-users
Dean Gadoury
DM Solutions Group
72 Chamberlain Ave. Third Floor
Ottawa, Ontario. K1S 1V9
613 565-5056 ext. 24
www.dmsolutions.ca
Content-Type: text/html; charset=us-ascii
<!DOCTYPE html PUBLIC "-//W3C//DTD HTML 4.01 Transitional//EN">
<html>
<head>
<meta http-equiv="Content-Type" content="text/html;charset=ISO-8859-1">
<title></title>
</head>
<body>
I have observed that this seems to be one of the most frequently asked questions
on the list, aside from compilation / installation issues. It seems to trip
up new users very frequently and I think its fair to say that that is because
setting a circle symbol for a line is, at first glance, counterintuitive.
<br>
<br>
Has there ever been any consideration of the idea of making a circle symbol
default when setting the thickness property of lines? That would make things
more intuitive and more in line with the way other web mapping, GIS, and
graphics packages work. In fact, Mapserver is the only application I've ever
used in which you need to apply a symbol to a line to adjust its thickness.
I guess there is a dependency on the symbol file, but could things be done
in such a way that a circle symbol is available in the actual core of Mapserver
and is used by default? Users could still override this if they choose to
use a symbol, but if not they get the circle symbol and only have to use
size to define the thickness of a line.<br>
<br>
Dean Gadoury<br>
<br>
Eric Bridger wrote:<br>
<blockquote type="cite"
cite="mid4.3.2.7.2.20030502091053.00aa0620 at mail.gomoos.org">
<pre wrap="">Yes. Add the following to your map file:
SYMBOL
Name 'circle'
Type ELLIPSE
Filled TRUE
Points
1 1
END
END
LAYER
TYPE POLYGON
CLASS
SYMBOL 'circle'
SIZE 3
END
</pre>
<blockquote type="cite">
<pre wrap="">Hi,
Thanks.
<a class="moz-txt-link-abbreviated" href="mailto:Mapserver-users at lists.gis.umn.edu">Mapserver-users at lists.gis.umn.edu</a>
<a class="moz-txt-link-freetext" href="http://lists.gis.umn.edu/mailman/listinfo/mapserver-users">http://lists.gis.umn.edu/mailman/listinfo/mapserver-users</a>
</pre>
</blockquote>
<pre wrap=""><!---->
</pre>
</blockquote>
<br>
<pre class="moz-signature" cols="$mailwrapcol">--
Dean Gadoury
DM Solutions Group
<a class="moz-txt-link-abbreviated" href="mailto:gadoury at dmsolutions.ca">gadoury at dmsolutions.ca</a>
<a class="moz-txt-link-abbreviated" href="http://www.dmsolutions.ca">www.dmsolutions.ca</a></pre>
<br>
</body>
</html>
--------------030406040308000709080009--
More information about the MapServer-users
