[Mapserver-users] PERL mapscript undefined symbol woes
Joe Bussell
joe at otsys.com
Fri May 2 12:28:00 EDT 2003
Red Herring alert!!
I believe that the undefined symbols are set by the encapsulating
instantiation of PERL. This is not my problem. The real problem
resulted from a change in one of my shapefiles. The updated file
contains a significantly larger number of points. My current working
theory is that the number has somehow exceeded a fixed limit.
Cordially,
Joe Bussell
Slaven Rezic wrote:
> Joe Bussell <joe at otsys.com> writes:
>>perl -V does indeed include "useshrplib=true"
> Does it help if you specify LD_LIBRARY_PATH?
> env LD_LIBRARY_PATH=/path/containing/libperl.so yourscript
> Regards,
> Slaven
>>>>Greetings Listers,
>>>> I have a Debian box with PERL5.8 and mapserver-3.6.5. I have had
>>>>great success in the past with this box, but something in my build went
>>>>awry. The compile for mapserv and then perl/mapscript completed without
>>>>error. The object is also generally useful when using dump.pl and even
>>>>some live map rendering under apache. The symptom that I observed is
>>>>that whenever the process needs to carp out something it segfaults and
>>>>dies. I ran ldd with the -r option and observed an interresting clue
>>>>(see below). Does anyone have any ideas how the Perl_* symbols are
>>>>defined?
>>>Normally the Perl_* symbols are either in the perl library or in the
>>>perl executable.
>>>>Why would they not be found? Should the list of *.so include
>>>>libperl.so?
>>>I don't think so, at least it's not on FreeBSD.
>>>>Any ideas on getting out of this mess?
>>>What is the output of "perl -v"? Does it include "useshrplib=true"?
>>>Regards,
>>> Slaven
>>>>ldd -r blib/arch/auto/mapscript/mapscript.so
>>>> libgd.so.2 => /usr/local/lib/libgd.so.2 (0x40102000)
>>>> libjpeg.so.62 => /usr/lib/libjpeg.so.62 (0x40147000)
>>>> libfreetype.so.6 => /usr/local/lib/libfreetype.so.6 (0x40164000)
>>>> libpng.so.2 => /usr/lib/libpng.so.2 (0x401ad000)
>>>> libz.so.1 => /lib/libz.so.1 (0x401d3000)
>>>> libtiff.so.3 => /usr/lib/libtiff.so.3 (0x401e0000)
>>>> libproj.so.0 => /usr/local/lib/libproj.so.0 (0x40224000)
>>>> libgdal.1.1.so => /usr/local/lib/libgdal.1.1.so (0x40255000)
>>>> libm.so.6 => /lib/libm.so.6 (0x404b0000)
>>>> libc.so.6 => /lib/libc.so.6 (0x404d1000)
>>>> libXpm.so.4 => /usr/X11R6/lib/libXpm.so.4 (0x405e1000)
>>>> libX11.so.6 => /usr/X11R6/lib/libX11.so.6 (0x405ef000)
>>>> libdl.so.2 => /lib/libdl.so.2 (0x406ab000)
>>>> libstdc++.so.5 => /usr/lib/libstdc++.so.5 (0x406ae000)
>>>> libgcc_s.so.1 => /lib/libgcc_s.so.1 (0x40757000)
>>>> /lib/ld-linux.so.2 => /lib/ld-linux.so.2 (0x80000000)
>>>>undefined symbol: Perl_croak_nocontext
>>>>(blib/arch/auto/mapscript/mapscript.so)
>>>>undefined symbol: Perl_sv_setiv (blib/arch/auto/mapscript/mapscript.so)
>>>>undefined symbol: Perl_sv_2pv_flags (blib/arch/auto/mapscript/mapscript.so)
>>>>undefined symbol: Perl_mg_find (blib/arch/auto/mapscript/mapscript.so)
>>>>undefined symbol: pthread_getspecific
>>>>undefined symbol: Perl_sv_newmortal (blib/arch/auto/mapscript/mapscript.so)
>>>>undefined symbol: Perl_sv_isobject (blib/arch/auto/mapscript/mapscript.so)
>>>>undefined symbol: Perl_sv_2nv (blib/arch/auto/mapscript/mapscript.so)
>>>>undefined symbol: Perl_Isv_yes_ptr (blib/arch/auto/mapscript/mapscript.so)
>>>>undefined symbol: Perl_sv_setpv (blib/arch/auto/mapscript/mapscript.so)
>>>>undefined symbol: Perl_newXS (blib/arch/auto/mapscript/mapscript.so)
>>>>undefined symbol: Perl_Tna_ptr (blib/arch/auto/mapscript/mapscript.so)
>>>>undefined symbol: Perl_Tmarkstack_ptr_ptr
>>>>undefined symbol: Perl_Isv_undef_ptr (blib/arch/auto/mapscript/mapscript.so)
>>>>undefined symbol: Perl_sv_magic (blib/arch/auto/mapscript/mapscript.so)
>>>>undefined symbol: Perl_sv_setsv_flags
>>>>undefined symbol: Perl_Tstack_base_ptr
>>>>undefined symbol: Perl_get_sv (blib/arch/auto/mapscript/mapscript.so)
>>>>undefined symbol: Perl_Gthr_key_ptr (blib/arch/auto/mapscript/mapscript.so)
>>>>undefined symbol: Perl_sv_setref_pv (blib/arch/auto/mapscript/mapscript.so)
>>>>undefined symbol: Perl_sv_2iv (blib/arch/auto/mapscript/mapscript.so)
>>>>undefined symbol: Perl_sv_setnv (blib/arch/auto/mapscript/mapscript.so)
>>>>undefined symbol: Perl_Tstack_sp_ptr (blib/arch/auto/mapscript/mapscript.so)
>>>>undefined symbol: Perl_sv_setpvn (blib/arch/auto/mapscript/mapscript.so)
>>>>undefined symbol: Perl_mg_get (blib/arch/auto/mapscript/mapscript.so)
>>>>Cordially,
>>>>Joe Bussell
>>>>On Time Systems
>>>>www.trafficdodger.com
>>>>_______________________________________________
>>>>Mapserver-users mailing list
>>>>Mapserver-users at lists.gis.umn.edu
>>>>http://lists.gis.umn.edu/mailman/listinfo/mapserver-users
