[Mapserver-users] Mapscript extension error...
Paul Spencer
spencer at dmsolutions.ca
Fri May 2 13:50:54 EDT 2003
Richard, there are a couple of things that can go wrong, but this
normally means that a dll that mapscript needs is not found in the
system path. On winXP there is a utility called depends.exe that will
show you dependencies of any executable or dll file. You can access
this utility by right clicking on the php_mapscript dll and selecting
"view dependencies". The resulting screen will show you all the files
that php_mapscript needs in order to load. It is most likely that you
are missing one of these files. Once you have identified the missing
files, it is a simple matter of making sure that the file is in your
system path (normally by moving them to c:\windows\system32 or by
editing the PATH environment variable).
It may also be that your IIS configuration is not correct, but that
seems unlikely since you can load php.
Cheers,
Paul
Becher, Richard wrote:
> I have installed PHP and PHP_MAPSCRIPT. I have copied the resulting
> php_mapscript.dll file to the C:\PHP\extensions directory. I have also
> modified the php.ini file accordingly.
> When I run phpinfo() I can successfully include/load any extension
> EXCEPT php_mapscript.dll. Not sure whats going on
.any help would be
> greatly appreciated!
> Running WinXP, IIS 5, Mapserver 3.7 (latest) and PHP 4.3.2RC2 for win32
> Cheers,
> **Richard Becher**
> /*/Sierra Systems/*/*
> *130 Slater Street, Suite 800
> Ottawa, Ontario K1P 6E2
> Phone: 613.236.7888, Extension: 350
> Fax: 613.236.9333
> Email: RichardBecher at SierraSystems.com
> www.SierraSystems.com <http://www.sierrasystems.com/>
Paul Spencer
Applications and Software Development
DM Solutions Group Inc.
http://www.dmsolutions.ca
