[Mapserver-users] WMS server issues
Ed McNierney
ed at topozone.com
Sat May 3 12:51:21 EDT 2003
Doug -
I would recommend highly that commas NOT be used in layer names, as the
spec requires the comma to be the separator character in a layer list.
By spec, the escaped commas should be handled properly, so thanks for
that input - but the French server docs should make it very clear that
their layer names MUST be escaped.
- Ed
Ed McNierney
President and Chief Mapmaker
TopoZone.com / Maps a la carte, Inc.
73 Princeton Street, Suite 305
North Chelmsford, MA 01863
Phone: (978) 251-4242 Fax: (978) 251-1396
ed at topozone.com
-----Original Message-----
Sent: Saturday, May 03, 2003 12:14 PM
To: Mapserver-users at lists.gis.umn.edu
Subject: [Mapserver-users] WMS server issues
I've encountered a couple of problems using MapServer as a WMS server. I
couldn't get the bugzilla to work for me, so here they are here.
1. Commas in layer names
I've been accessing a remote French MapServer site that uses commas in
the
layer names like "pe_7,5m", which indicate that the layer is at 1:7.5
million (the comma is the decimal character). Even when requesting the
layers in an encoded way (like
LAYERS=rec_7%2C5m,pe_7%2C5m,hydro_7%2C5m ...), the layers are not
included
in the GetMap image that is returned. Although it is not necessary for
people to name their layers this way, MapServer should deal with this if
they do.
2. Invalid XML in application/vnd.ogc.gml GetFeatureInfo response.
When requested this way (layer must be defined as DUMP true in order for
this to work), the resulting XML response can be invalid if the fields
contain certain text. MapServer should automatically convert special
characters (&,",') to &, " and ' that are found in field
values to ensure a valid XML response.
Doug
Doug Cates
Moxi Media Inc.
757 - 1641 Lonsdale Avenue,
Vancouver, BC, Canada V7M 2J5
Phone: 604-984-8109
Fax: 604-608-4764
E-Mail: doug at moximedia.com
Web: www.moximedia.com
Mapserver-users mailing list
http://lists.gis.umn.edu/mailman/listinfo/mapserver-users
