[Mapserver-users] Help COLOR_MATCH_THRESHOLD
Frank Warmerdam
warmerdam at pobox.com
Fri May 9 00:58:58 EDT 2003
Matt Doggett wrote:
> I have raster data (via GDAL) with values much larger than 255 and I
> tried using the PROCESSING directive as described in this thread but I'm
> not getting it to work. In fact, I can't find ANY reference to this
> option in the documentation. Apparently, you got it to work, so...how
> did you do it? What's the syntax and use for this option? Where is it
> documented?
Matt,
The option only exists in MapServer 3.7 (aka dev, aka CVS, aka 4.0). I
think it is discussed in the MapServer 3.7 raster howto.
Best regards,
and watch the world go round - Rush | Geospatial Programmer for Rent
