[Mapserver-users] Slow MapServer with large data
woodbri at swoodbridge.com
Fri May 9 07:35:18 EDT 2003
Have you built shptree indexes for all your shapefiles?
On 9 May 2003 at 13:14, jankarin at post1.dknet.dk wrote:
> Hello
> I have a little problem with the speed in MapServer.
> We're trying to make qiuck-viewer to shape- and tab-formats, but
> MapServer is running slow with large data: 20 seconds: Shapefil 17 MB,
> dbf-fil 9,5 MB. 45 seconds: Map-fil 31 MB, Dat-fil 25 MB.
> I have been trying with the GCI-version and PHP Mapscript - same
> result.
> I am running MapServer 3.6.4 with PNG-output under Apache 2.4.5 on
> Windows 2000. The pc is Pentim III, 650 Mhz, 262 MB RAM.
> In another installation (PII, 400 Mhz, 196 MB RAM) a shapefile
> (shapefile 17 MB, dbf-fil 9,5 MB) took 80 seconds to show.
> We're using MapServer in an application which is dynamically creating
> map-files with Mapscript (only showing one layer at a time). We're
> talknig about 17.000 layers in shape- and tabformats, so it is not
> possible to improve indexfiles or anything else related to a single
> layer.
> Can anyone help?
> Thanks,
> Jan Christiansen
> Engineering College of Copenhagen
> Mapserver-users mailing list
> Mapserver-users at lists.gis.umn.edu
> http://lists.gis.umn.edu/mailman/listinfo/mapserver-users
