[Mapserver-users] PHP-Mapscript dll problem
Paul Spencer
spencer at dmsolutions.ca
Fri May 9 10:16:36 EDT 2003
Marc
the php_mapscript_36.dll needs to go into your PHP extensions directory.
Normally, this would be in <path-to-php>\extensions\. You should also
check your php.ini file for the extension_dir setting and make sure that
it is pointing to the same directory.
Cheers,
Paul
Marc Drouin wrote:
> Hi everyone,
> I have a problem with PHP Mapscript. I followed the installation
> instruction and copied the php_mapscript_36.dll file in
> c:\winnt\system32 directory. When i come to test the installation using
> phpinfo(); the server returns that it could not load a specific
> function, or something like that. I checked the archives and found that
> somebody suggested to check the dependencies of the dll. I found out
> the apphelp.dll seemed to be the problem, it simply was completely
> missing from the system directory. there is also an issue with mpr.dll.
> Further investigation lead me to the microsoft site, to find out the
> apphelp.dll only come with XP or windows server 2003, BTW, I'm running
> win2000 server.
> Doe anyone had a simillar problem?
> What do I need to do to get thiongs rolling?
> I've tried replacing the dll with php_mapacript_35.dll, no succes.
> I've tried upgrading IE6, sp1, no succes.
> please help..............
> Marc
Paul Spencer
Applications and Software Development
DM Solutions Group Inc.
http://www.dmsolutions.ca
