[Mapserver-users] OracleSpatial switches to include...(correction)
Jesiel de Souza
jesiel at cttmar.univali.br
Fri May 9 15:40:37 EDT 2003
This is a multi-part message in MIME format.
------=_NextPart_000_0033_01C31649.B84A3300
Content-Type: text/plain;
charset="iso-8859-1"
Content-Transfer-Encoding: quoted-printable
Hi Richard,=20
To know if its compilation of the MapServer with OracleSpatial is =
correct, proceed the following way:=20
1. Execute mapserver.exe -v=20
2. The output must contain "INPUT=3DORACLESPATIAL"=20
Like this sample:
MapServer version 3.7 (development) OUTPUT=3DPNG SUPPORTS=3DTTF =
INPUT=3DTIFF INPUT=3DORACLESPATIAL INPUT=3DSHAPEFILE=20
In this case, the input says it does exists.
In other cases, you need to compile the MapServer again, including the =
OracleSpatial suports in your makefile.vc.
Regards,=20
Jesiel de Souza
----- Original Message -----=20
To: Jesiel de Souza=20
Sent: Tuesday, May 06, 2003 1:30 PM
Subject: RE: [Mapserver-users] OracleSpatial switches to =
Thanks Jesiel.
=20
OK.I think I have properly compiled MapServer with the Oracle Spatial =
switch. It is a little different for me since I am using an nmake.opt =
file (the way it's set up with the latest version of MapServer).
=20
How can I tell if Oracle is properly referenced? I am using =
PHP_Mapscript.
=20
Also, I am not sure how to set up MapServer now that I have everything =
compiled. IIS is all set up and PHP and PHP_Mapscript are all working.
=20
But how do I create a new MapServer project?
=20
Many thanks in advance for your help and time!
=20
Cheers,
=20
Richard
=20
Content-Type: text/html;
<!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 4.0 Transitional//EN">
<HTML xmlns=3D"http://www.w3.org/TR/REC-html40" xmlns:v =3D=20
"urn:schemas-microsoft-com:vml" xmlns:o =3D=20
"urn:schemas-microsoft-com:office:office" xmlns:w =3D=20
"urn:schemas-microsoft-com:office:word" xmlns:st1 =3D=20
"urn:schemas-microsoft-com:office:smarttags"><HEAD>
<META http-equiv=3DContent-Type content=3D"text/html; =
charset=3Diso-8859-1">
<META content=3DWord.Document name=3DProgId>
<META content=3D"MSHTML 6.00.2800.1106" name=3DGENERATOR>
<META content=3D"Microsoft Word 10" name=3DOriginator><LINK=20
href=3D"cid:filelist.xml at 01C313CB.5537E080" =
rel=3DFile-List><o:SmartTagType=20
name=3D"time"=20
namespaceuri=3D"urn:schemas-microsoft-com:office:smarttags"></o:SmartTagT=
ype><o:SmartTagType=20
name=3D"date"=20
name=3D"State"=20
name=3D"place"=20
ype><!--[if gte mso 9]><xml>
<o:OfficeDocumentSettings>
<o:DoNotRelyOnCSS/>
</o:OfficeDocumentSettings>
</xml><![endif]--><!--[if gte mso 9]><xml>
<w:WordDocument>
<w:SpellingState>Clean</w:SpellingState>
<w:GrammarState>Clean</w:GrammarState>
<w:DocumentKind>DocumentEmail</w:DocumentKind>
<w:EnvelopeVis/>
<w:Compatibility>
<w:BreakWrappedTables/>
<w:SnapToGridInCell/>
<w:WrapTextWithPunct/>
<w:UseAsianBreakRules/>
</w:Compatibility>
<w:BrowserLevel>MicrosoftInternetExplorer4</w:BrowserLevel>
</w:WordDocument>
</xml><![endif]--><!--[if !mso]>
<STYLE>st1\:* {
BEHAVIOR: url(#default#ieooui)
</STYLE>
<![endif]-->
<STYLE>
/* Font Definitions */
@font-face
{font-family:Tahoma;
panose-1:2 11 6 4 3 5 4 4 2 4;
mso-font-charset:0;
mso-generic-font-family:swiss;
mso-font-pitch:variable;
mso-font-signature:1627421319 -2147483648 8 0 66047 0;}
/* Style Definitions */
p.MsoNormal, li.MsoNormal, div.MsoNormal
{mso-style-parent:"";
margin:0in;
margin-bottom:.0001pt;
mso-pagination:widow-orphan;
font-size:12.0pt;
font-family:"Times New Roman";
mso-fareast-font-family:"Times New Roman";}
a:link, span.MsoHyperlink
{color:blue;
text-decoration:underline;
text-underline:single;}
a:visited, span.MsoHyperlinkFollowed
{color:purple;
p.MsoAutoSig, li.MsoAutoSig, div.MsoAutoSig
{margin:0in;
font-size:12.0pt;
p
{mso-margin-top-alt:auto;
margin-right:0in;
mso-margin-bottom-alt:auto;
margin-left:0in;
font-size:12.0pt;
span.EmailStyle18
{mso-style-type:personal;
mso-style-noshow:yes;
mso-ansi-font-size:10.0pt;
mso-bidi-font-size:10.0pt;
font-family:Arial;
mso-ascii-font-family:Arial;
mso-hansi-font-family:Arial;
mso-bidi-font-family:Arial;
color:windowtext;}
span.EmailStyle19
font-family:Arial;
color:navy;}
span.EmailStyle20
font-family:Arial;
color:navy;}
span.EmailStyle22
{mso-style-type:personal-reply;
font-family:Arial;
color:navy;}
span.SpellE
{mso-style-name:"";
mso-spl-e:yes;}
@page Section1
{size:8.5in 11.0in;
margin:1.0in 1.25in 1.0in 1.25in;
mso-header-margin:.5in;
mso-footer-margin:.5in;
mso-paper-source:0;}
div.Section1
{page:Section1;}
</STYLE>
<!--[if gte mso 10]>
<style>
/* Style Definitions */=20
table.MsoNormalTable
{mso-style-name:"Table Normal";
mso-tstyle-rowband-size:0;
mso-tstyle-colband-size:0;
mso-padding-alt:0in 5.4pt 0in 5.4pt;
mso-para-margin:0in;
mso-para-margin-bottom:.0001pt;
font-size:10.0pt;
</style>
<o:shapedefaults v:ext=3D"edit" spidmax=3D"1026" />
<o:shapelayout v:ext=3D"edit">
<o:idmap v:ext=3D"edit" data=3D"1" />
</o:shapelayout></xml><![endif]--></HEAD>
<BODY lang=3DEN-US style=3D"tab-interval: .5in" vLink=3Dpurple =
link=3Dblue=20
bgColor=3Dwhite>
<DIV><FONT face=3DArial size=3D2><FONT color=3D#808080 size=3D2>
<P><FONT face=3DArial color=3D#000000 size=3D2>Hi Richard, </FONT></P>
<P><FONT face=3DArial color=3D#000000 size=3D2>To know if its =
compilation of the=20
MapServer with OracleSpatial is correct, proceed the following way: =
</FONT></P>
<P><FONT face=3DArial color=3D#000000 size=3D2>1. Execute mapserver.exe =
-v </FONT></P>
<P><FONT face=3DArial color=3D#000000 size=3D2>2. The output must =
contain=20
"INPUT=3DORACLESPATIAL" </FONT></P>
<P><FONT face=3DArial color=3D#000000 size=3D2>Like this =
sample:<BR></FONT><FONT=20
face=3DArial color=3D#000000 size=3D2>MapServer version 3.7 =
(development) OUTPUT=3DPNG=20
SUPPORTS=3DTTF INPUT=3DTIFF INPUT=3DORACLESPATIAL INPUT=3DSHAPEFILE =
</FONT></P>
<P><FONT face=3DArial color=3D#000000 size=3D2>In this case, the input =
says it does=20
exists.</FONT></P>
<P><FONT face=3DArial color=3D#000000 size=3D2>In other cases, you need =
to compile the=20
MapServer again, including the OracleSpatial suports in your=20
makefile.vc.</FONT></P>
<P><FONT face=3DArial color=3D#000000 size=3D2>Regards, </FONT></P>
<P><FONT face=3DArial color=3D#000000 size=3D2>Jesiel de =
Souza</FONT></P>
<P><FONT face=3DArial color=3D#000000 =
size=3D2></FONT></FONT></FONT> </P></DIV>
<BLOCKQUOTE dir=3Dltr=20
style=3D"PADDING-RIGHT: 0px; PADDING-LEFT: 5px; MARGIN-LEFT: 5px; =
BORDER-LEFT: #000000 2px solid; MARGIN-RIGHT: 0px">
<DIV style=3D"FONT: 10pt arial">----- Original Message ----- </DIV>
<DIV=20
style=3D"BACKGROUND: #e4e4e4; FONT: 10pt arial; font-color: =
black"><B>From:</B>=20
<A title=3DRichardBecher at SierraSystems.com=20
href=3D"mailto:RichardBecher at SierraSystems.com">Becher, Richard</A> =
</DIV>
<DIV style=3D"FONT: 10pt arial"><B>To:</B> <A =
title=3Djesiel at cttmar.univali.br=20
href=3D"mailto:jesiel at cttmar.univali.br">Jesiel de Souza</A> </DIV>
<DIV style=3D"FONT: 10pt arial"><B>Sent:</B> Tuesday, May 06, 2003 =
1:30 PM</DIV>
<DIV style=3D"FONT: 10pt arial"><B>Subject:</B> RE: [Mapserver-users]=20
OracleSpatial switches to include...(correction)</DIV>
<DIV><FONT face=3DArial size=3D2></FONT><FONT face=3DArial =
size=3D2></FONT><FONT=20
face=3DArial size=3D2></FONT><FONT face=3DArial size=3D2></FONT><FONT =
face=3DArial=20
size=3D2></FONT><FONT face=3DArial size=3D2></FONT><FONT face=3DArial=20
size=3D2></FONT><BR></DIV>
<DIV class=3DSection1>
<P class=3DMsoNormal><FONT face=3DArial color=3Dnavy size=3D2><SPAN=20
style=3D"FONT-SIZE: 10pt; COLOR: navy; FONT-FAMILY: Arial">Thanks=20
Jesiel.<o:p></o:p></SPAN></FONT></P>
style=3D"FONT-SIZE: 10pt; COLOR: navy; FONT-FAMILY: =
Arial"><o:p> </o:p></SPAN></FONT></P>
style=3D"FONT-SIZE: 10pt; COLOR: navy; FONT-FAMILY: Arial">OK=85I =
think I have=20
properly compiled <SPAN class=3DSpellE>MapServer</SPAN> with the =
Oracle Spatial=20
switch.<SPAN style=3D"mso-spacerun: yes"> </SPAN>It is a little =
different=20
for me since I am using an <SPAN class=3DSpellE>nmake.opt</SPAN> file =
(the way=20
it=92s set up with the latest version of <SPAN=20
class=3DSpellE>MapServer</SPAN>).<o:p></o:p></SPAN></FONT></P>
style=3D"FONT-SIZE: 10pt; COLOR: navy; FONT-FAMILY: Arial">How can I =
tell if=20
Oracle is properly referenced?<SPAN style=3D"mso-spacerun: yes"> =
</SPAN>I=20
am using <SPAN =
class=3DSpellE>PHP_Mapscript</SPAN>.<o:p></o:p></SPAN></FONT></P>
style=3D"FONT-SIZE: 10pt; COLOR: navy; FONT-FAMILY: Arial">Also, I am =
not sure=20
how to set up <SPAN class=3DSpellE>MapServer</SPAN> now that I have =
everything=20
compiled.<SPAN style=3D"mso-spacerun: yes"> </SPAN>IIS is all =
set up and=20
PHP and <SPAN class=3DSpellE>PHP_Mapscript</SPAN> are all=20
working.<o:p></o:p></SPAN></FONT></P>
style=3D"FONT-SIZE: 10pt; COLOR: navy; FONT-FAMILY: Arial">But how do =
I create a=20
new <SPAN class=3DSpellE>MapServer</SPAN> =
project?<o:p></o:p></SPAN></FONT></P>
style=3D"FONT-SIZE: 10pt; COLOR: navy; FONT-FAMILY: Arial">Many thanks =
in=20
advance for your help and time!<o:p></o:p></SPAN></FONT></P>
Arial">Cheers,<o:p></o:p></SPAN></FONT></P>
Arial">Richard<o:p></o:p></SPAN></FONT></P>
<DIV>
<P class=3DMsoNormal style=3D"MARGIN-LEFT: 0.5in"><FONT face=3DArial =
color=3Dnavy=20
size=3D2><SPAN=20
Arial"><o:p></o:p></SPAN></FONT> </P></DIV></DIV></BLOCKQUOTE></BODY=
></HTML>
------=_NextPart_000_0033_01C31649.B84A3300--
