[Mapserver-users] building gdal 1.1.8 on Mac OS X 10.2.6
John Oram
mapserver at oram.com
Sat May 10 20:32:22 EDT 2003
Hi-
In the archives,
http://lists.dmsolutions.ca/pipermail/mapserver-users/2002-February/
000556.html
Puneet had problems compiling gdal. The errors are similar to mine,
but there wasn't a followup as far as I could see.
I applied the changed to the GDALmake.opt file:
http://mapserver.gis.umn.edu/cgi-bin/wiki.pl?MacOS
But I see some sort of error with libtool and libgdal.1.1.dylib at the
end. I copied it below. I'm not sure what to do at this point.
Also, what are the standard flags to use with ./configure and gdal? I
turned off python, but am unsure what other things are required or
unnecessary. (My primary motivation with gdal is to be able to import
and export shapefiles...)
Thanks,
John
ranlib ./gdal.a
ranlib: file: ./gdal.a(pnggccrd.o) has no symbols
ranlib: file: ./gdal.a(pngvcrd.o) has no symbols
ranlib: file: ./gdal.a(tif_pixarlog.o) has no symbols
ranlib: file: ./gdal.a(cpl_vsil_unix_stdio_64.o) has no symbols
make ./libgdal.1.1.dylib
gcc -dynamiclib ./frmts/o/*.o ./core/*.o ./port/*.o ./alg/*.o
./ogr/ogrct.o ./ogr/ogr_opt.o ./ogr/ogr_fromepsg.o
./ogr/ogr_srs_validate.o ./ogr/ogrutils.o ./ogr/ogr_srs_proj4.o
./ogr/ogr_api.o ./ogr/ogrsf_frmts/generic/ogrregisterall.o
./ogr/ogrfeaturestyle.o ./ogr/ogrsf_frmts/ogrsf_frmts.a ./gdal.a
./ogr/ogr.a ./gdal.a ./port/cpl.a -lz -lm -ldl -L/usr/local/lib -lm -o
./libgdal.1.1.dylib
ld: Undefined symbols:
vtable for __cxxabiv1::__class_type_info
vtable for __cxxabiv1::__si_class_type_info
operator delete(void*)
operator new(unsigned long)
___gxx_personality_v0
operator delete[](void*)
operator new[](unsigned long)
___cxa_pure_virtual
vtable for __cxxabiv1::__vmi_class_type_info
/usr/bin/libtool: internal link edit command failed
make[1]: *** [libgdal.1.1.dylib] Error 1
make: *** [check-lib] Error 2
