[Mapserver-users] ms3.7 GD2.0.12 Image problem
woodbri at swoodbridge.com
Mon May 12 11:31:08 EDT 2003
Hi all,
I have run into a strange image display problem with MS-3.7 (May 11th) with GD-2.0.12 using PNG24 and RGB and RGBA
I think this is either a GD-2 issue or an issue in MS.
If I use RGB then the text chars and the bounding box for the characters are both black and I only see little black boxes where characters should be. If I use RGBA it is a little bit better in that the text is displayed on a box that is a different colors but the charater bounding box is but the char. background is opaquac and overwrites the character before it.
See http://strabo01.geozone.com/mapserv.png for an example.
-Steve W.
