[Mapserver-users] mapserver win32 compilation problems
Rosangela Silva
rosangela.silva at zenitpolar.com.br
Mon May 12 13:40:40 EDT 2003
This is a multi-part message in MIME format.
------=_NextPart_000_000F_01C31894.75CE59F0
Content-Type: text/plain;
charset="iso-8859-1"
Content-Transfer-Encoding: quoted-printable
Hi Gayathri,
Thanks for your help.
I change the u_short to short and it's solve the erros in
HTProt.h and HTHost.h files.=20
But about 'sockaddr_in' , how you sad, the file "in.h" is=20
in Cygwin directory. But I'm not compiling mapserver
under Cygwin, is it wrong?? I try to copy this file
and others files of cygwin../include/sys directory, but
other erros had appeared.
About workspace and compile mapserver with VC++,
I tried to make this when Prashant Desai posted your dsw, but
I had many many erros of LINK that they had made me to give up . =20
But I need to compile mapserver, specially because I'm using
posgresql7.3.2-1 and postgis 0.7.5.=20
Thanks
Rosangela.
To: 'Rosangela Silva' ; Mapserver-Users at Lists. Gis. Umn. Edu=20
Cc: vladimir.kozlov at idm.ru ; jnovak at novacell.com=20
Sent: Monday, May 12, 2003 1:53 PM
Subject: RE: [Mapserver-users] mapserver win32 compilation problems
Hi ,
I have got the exact errors you mention, earlier in my attempts to =
compile.=20
For some reason the u_short does not work well for "cl" in windows.,=20
if you change u_short to short - it will compile without those u_short =
errors ( I am not sure of the implications).,=20
Again if you check that error, "Libwww/Library/src/HTHstMan.h(94) : =
error C2079: 'sock_addr' uses undefined struct 'sockaddr_in'"
and open HTHstMan.h, you will see that, this is actually coming from a =
inclusion of the header "wwwsys.h" and that requires a "in.h" which =
under cygwin lib.,
sockaddr_in is defined in "in.h", somehow the VC++ compiler overlooks =
this and we have this persistent error.
But the way I overcame these errors when I hurt real bad to compile =
Mapserver with WMS was,=20
by using the VC++ workspace Prashant Desai posted sometime back and =
setting my lib paths in VC workspace and compiling mapserver using a =
VC++ workspace.
If you would like to have a copy of the workspace let me know. Will =
send it to you.
Thanks,
Gayathri
-----Original Message-----
From: Rosangela Silva [mailto:rosangela.silva at zenitpolar.com.br]
Sent: Monday, May 12, 2003 7:40 AM
To: Mapserver-Users at Lists. Gis. Umn. Edu
Cc: vladimir.kozlov at idm.ru; jnovak at novacell.com
Subject: [Mapserver-users] mapserver win32 compilation problems
Hello,
I'm trying to compile mapserver on win32 (winxp) and I'm looking
for some help but I coundn't find it in lists (mapserver, libwww).
I'm using the precompiled Libwww avaiable for Vladimir A. Kozlov
(ftp://ftp.idm.ru/libwww).
And I'm using the "compiling postgis with mapserver" instructions by =
Gayathri Swaminathan=20
(http://lists.gis.umn.edu/pipermail/mapserver-users/2003-April/003469.htm=
l). About
postgis, I don't know if it will run, because the warnings "ignored" =
lines.
The mapserver compilation erros results are:
nmake /f Makefile.vc
Microsoft (R) Program Maintenance Utility Version 6.00.8168.0
Copyright (C) Microsoft Corp 1988-1998. All rights reserved.
cl libpq7.3.2/libpq.lib =
libpq7.3.2/interfaces/libpq/libpqdll.lib /nologo
/Zi /W3 /DDEBUG /DWIN32 libpq7.3.2/libpq.lib =
ll.lib -I gd-1.8.4 -I tiff-v3.5.7/libtiff -I proj-4.4.5/src =
-Iphp-4.3.1\rege
x -DPHP_NO_ALIASES -Igdal-1.1.7/ogr/ogrsf_frmts -Igdal-1.1.7/ogr =
-Igdal-1.1.7/og
r/../port -Igdal-1.1.7/core -I Libwww/library/src -I =
Libwww/modules/expat/xmlpa
rse -DHAVE_STRING_H -DREGEX_MALLOC -DNEED_STRCASECMP =
-DNEED_STRNCASECMP -DUSE_
EPPL -DUSE_PROJ -DUSE_PROJ_API_H -DUSE_TIFF -DUSE_GD_GIF =
-DUSE_GD_PNG -DUSE_GD_
JPEG -DUSE_GD_WBMP -DUSE_GD_TTF -DUSE_GD_TTF -DGD_HAS_GDIMAGEGIFPTR =
-DUSE_OGR -
DUSE_WMS -DUSE_WMS_LYR -DIGNORE_MISSING_DATA -DUSE_GDAL =
-DFEATURE_INFO_HTML /c
mapwmslayer.c /Fomapwmslayer.obj
Command line warning D4027 : source file 'libpq7.3.2/libpq.lib' =
ignored
Command line warning D4027 : source file =
'libpq7.3.2/interfaces/libpq/libpqdll.l ib' ignored
ignored
mapwmslayer.c
Libwww/Library/src/HTProt.h(58) : error C2061: syntax error : =
identifier 'HTProtocolId'
Libwww/Library/src/HTProt.h(58) : error C2059: syntax error : ';'
Libwww/Library/src/HTProt.h(85) : error C2146: syntax error : =
missing ')' before identifier 'port'
Libwww/Library/src/HTProt.h(85) : error C2081: 'HTProtocolId' : name =
in formal parameter list illegal
Libwww/Library/src/HTProt.h(85) : error C2061: syntax error : =
identifier 'port'
Libwww/Library/src/HTProt.h(85) : error C2059: syntax error : ';'
Libwww/Library/src/HTProt.h(85) : error C2059: syntax error : ','
Libwww/Library/src/HTProt.h(88) : error C2059: syntax error : ')'
Libwww/Library/src/HTProt.h(132) : error C2061: syntax error : =
identifier 'HTProtocol_id'
Libwww/Library/src/HTProt.h(132) : error C2059: syntax error : ';'
Libwww/Library/src/HTProt.h(132) : error C2059: syntax error : =
'type'
Libwww/Library/src/HTHost.h(65) : error C2146: syntax error : =
missing ')' before identifier 'u_port'
Libwww/Library/src/HTHost.h(65) : error C2081: 'u_short' : name in =
Libwww/Library/src/HTHost.h(65) : error C2061: syntax error : =
identifier 'u_port'
Libwww/Library/src/HTHost.h(65) : error C2059: syntax error : ';'
Libwww/Library/src/HTHost.h(65) : error C2059: syntax error : ')'
Libwww/Library/src/HTHost.h(66) : error C2146: syntax error : =
Libwww/Library/src/HTHost.h(66) : error C2081: 'u_short' : name in =
Libwww/Library/src/HTHost.h(66) : error C2061: syntax error : =
identifier 'u_port'
Libwww/Library/src/HTHost.h(66) : error C2059: syntax error : ';'
Libwww/Library/src/HTHost.h(66) : error C2059: syntax error : ')'
Libwww/Library/src/HTHstMan.h(60) : error C2061: syntax error : =
identifier 'u_short'
Libwww/Library/src/HTHstMan.h(94) : error C2079: 'sock_addr' uses =
Libwww/Library/src/HTHstMan.h(110) : error C2059: syntax error : '}'
mapwmslayer.c(292) : warning C4013: 'index' undefined; assuming =
extern returning int
mapwmslayer.c(292) : warning C4047: '=3D' : 'const char *' differs =
in levels of in direction from 'int '
mapwmslayer.c(340) : warning C4013: 'isspace' undefined; assuming =
mapwmslayer.c(368) : warning C4090: 'function' : different 'const' =
qualifiers
mapwmslayer.c(368) : warning C4024: 'strcasecmp' : different types =
for formal and actual parameter 2
NMAKE : fatal error U1077: 'cl' : return code '0x2'
Stop.
All helps are welcome,
Thanks
Ros=E2ngela
Content-Type: text/html;
<!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 4.0 Transitional//EN">
<HTML><HEAD>
<META http-equiv=3DContent-Type content=3D"text/html; =
charset=3Diso-8859-1">
<META content=3D"MSHTML 6.00.2800.1170" name=3DGENERATOR>
<STYLE></STYLE>
</HEAD>
<BODY bgColor=3D#ffffff>
<DIV><FONT face=3DArial size=3D2>Hi Gayathri,</FONT></DIV>
<DIV><FONT face=3DArial size=3D2></FONT> </DIV>
<DIV><FONT face=3DArial size=3D2>Thanks for your help.</FONT></DIV>
<DIV><FONT face=3DArial size=3D2>I change the u_short to short and it's =
solve the=20
erros in</FONT></DIV>
<DIV><FONT face=3DArial size=3D2>HTProt.h and HTHost.h files. =
</FONT></DIV>
<DIV><FONT face=3DArial size=3D2>But about 'sockaddr_in' , how you sad, =
the file=20
"in.h" is </FONT></DIV>
<DIV><FONT face=3DArial size=3D2>in Cygwin directory. But I'm not =
compiling=20
mapserver</FONT></DIV>
<DIV><FONT face=3DArial size=3D2>under Cygwin, is it wrong?? I try to =
copy this=20
file</FONT></DIV>
<DIV><FONT face=3DArial size=3D2>and others files of =
cygwin../include/sys directory,=20
but</FONT></DIV>
<DIV><FONT face=3DArial size=3D2>other erros had appeared.</FONT></DIV>
<DIV><FONT face=3DArial size=3D2>About workspace and compile =
mapserver with=20
VC++,</FONT></DIV>
<DIV><FONT face=3DArial size=3D2>I tried to =
make this when Prashant=20
Desai posted your dsw, but</FONT></DIV>
<DIV><FONT face=3DArial size=3D2>I had many many erros =
of LINK that=20
they had made me to give up .</FONT> </DIV>
<DIV><FONT face=3DArial size=3D2>But I need to compile mapserver, =
specially because=20
I'm using</FONT></DIV>
<DIV><FONT face=3DArial size=3D2>posgresql7.3.2-1 and postgis 0.7.5. =
</FONT></DIV>
<DIV><FONT face=3DArial size=3D2>Thanks</FONT></DIV>
<DIV><FONT face=3DArial size=3D2>Rosangela.</FONT></DIV>
<BLOCKQUOTE dir=3Dltr=20
style=3D"PADDING-RIGHT: 0px; PADDING-LEFT: 5px; MARGIN-LEFT: 5px; =
BORDER-LEFT: #000000 2px solid; MARGIN-RIGHT: 0px">
<DIV style=3D"FONT: 10pt arial"><STRONG>From:</STRONG> <A =
title=3Dgayathri at ou.edu=20
href=3D"mailto:gayathri at ou.edu">Swaminathan, Gayathr</A><A =
href=3D"mailto:gayathri at ou.edu">i</A> </DIV>
<DIV style=3D"FONT: 10pt arial"><STRONG>To:</STRONG> <A=20
title=3Drosangela.silva at zenitpolar.com.br=20
href=3D"mailto:rosangela.silva at zenitpolar.com.br">'Rosangela =
Silva'</A> ; <A=20
title=3Dmapserver-users at lists.gis.umn.edu=20
href=3D"mailto:Mapserver-Users at Lists. Gis. Umn. =
Edu">Mapserver-Users at Lists. Gis.=20
Umn. Edu</A> </DIV>
<DIV style=3D"FONT: 10pt arial"><B>Cc:</B> <A =
title=3Dvladimir.kozlov at idm.ru=20
href=3D"mailto:vladimir.kozlov at idm.ru">vladimir.kozlov at idm.ru</A> ; <A =
title=3Djnovak at novacell.com=20
href=3D"mailto:jnovak at novacell.com">jnovak at novacell.com</A> </DIV>
<DIV style=3D"FONT: 10pt arial"><B>Sent:</B> Monday, May 12, 2003 1:53 =
PM</DIV>
<DIV style=3D"FONT: 10pt arial"><B>Subject:</B> RE: [Mapserver-users] =
mapserver=20
win32 compilation problems</DIV>
<DIV><FONT face=3DArial size=3D2></FONT><FONT face=3DArial =
size=3D2></FONT><FONT=20
face=3DArial size=3D2></FONT><BR></DIV>
<DIV><SPAN class=3D602484918-12052003><FONT face=3DArial size=3D2>Hi=20
,</FONT></SPAN></DIV>
<DIV><SPAN class=3D602484918-12052003><FONT face=3DArial size=3D2>I =
have got the=20
exact errors you mention, earlier in my attempts to compile.=20
<DIV><SPAN class=3D602484918-12052003><FONT face=3DArial=20
size=3D2></FONT></SPAN> </DIV>
<DIV><SPAN class=3D602484918-12052003><FONT face=3DArial size=3D2>For =
some reason=20
the<STRONG> u_short does not work well for "cl" in windows</STRONG>.,=20
<DIV><SPAN class=3D602484918-12052003><FONT face=3DArial =
size=3D2><STRONG>if you=20
change u_short to short</STRONG> - it will compile without those =
u_short=20
errors ( I am not sure of the =
implications)., </FONT></SPAN></DIV>
size=3D2>Again if you check=20
that error, "Libwww/Library/src/HTHstMan.h(94) : error C2079: =
'sock_addr' uses=20
undefined struct 'sockaddr_in'"</FONT></SPAN></DIV>
color=3D#0000ff=20
size=3D2><FONT color=3D#000000>and open HTHstMan.h, you will see that, =
this is=20
actually coming from a inclusion of the header "wwwsys.h" and that =
requires a=20
"in.h" which under cygwin lib.,</FONT></FONT></SPAN></DIV>
size=3D2><STRONG>sockaddr_in is defined in "in.h"</STRONG>, somehow =
the VC++=20
compiler overlooks this and we have this persistent =
error.</FONT></SPAN></DIV>
size=3D2>But the way I=20
overcame these errors when I hurt real bad to compile <SPAN=20
class=3D602484918-12052003><FONT face=3DArial size=3D2>Mapserver with =
WMS=20
was</FONT></SPAN>, </FONT></SPAN></DIV>
<DIV><SPAN class=3D602484918-12052003><FONT face=3DArial size=3D2>by =
using the VC++=20
workspace Prashant Desai posted sometime back and setting my lib paths =
in VC=20
workspace and compiling mapserver using a VC++ =
workspace.</FONT></SPAN></DIV>
<DIV><SPAN class=3D602484918-12052003><FONT face=3DArial size=3D2>If =
you would like=20
to have a copy of the workspace let me know. Will send it to=20
you.</FONT></SPAN></DIV>
size=3D2>Thanks,</FONT></SPAN></DIV>
size=3D2>Gayathri</FONT></SPAN></DIV>
<BLOCKQUOTE dir=3Dltr style=3D"MARGIN-RIGHT: 0px">
<DIV class=3DOutlookMessageHeader dir=3Dltr align=3Dleft><FONT =
face=3DTahoma=20
size=3D2>-----Original Message-----<BR><B>From:</B> Rosangela Silva=20
[mailto:rosangela.silva at zenitpolar.com.br]<BR><B>Sent:</B> Monday, =
May 12,=20
2003 7:40 AM<BR><B>To:</B> Mapserver-Users at Lists. Gis. Umn.=20
Edu<BR><B>Cc:</B> vladimir.kozlov at idm.ru;=20
jnovak at novacell.com<BR><B>Subject:</B> [Mapserver-users] mapserver =
win32=20
compilation problems<BR><BR></FONT></DIV>
<DIV><FONT face=3DArial size=3D2>Hello,</FONT></DIV>
<DIV><FONT face=3DArial size=3D2>I'm trying to compile mapserver on =
win32=20
(winxp) and I'm looking</FONT></DIV>
<DIV><FONT face=3DArial size=3D2>for some help but I coundn't find =
it in lists=20
(mapserver, libwww).</FONT></DIV>
<DIV><FONT face=3DArial size=3D2>I'm using the =
precompiled Libwww avaiable=20
for Vladimir A. Kozlov</FONT></DIV>
<DIV><FONT face=3DArial size=3D2>(<A =
href=3D"ftp://ftp.idm.ru/libwww/"><FONT=20
face=3D"Times New Roman"=20
size=3D3>ftp://ftp.idm.ru/libwww</FONT></A>).</FONT></DIV>
<DIV><FONT face=3DArial size=3D2>And I'm using the "compiling =
postgis with=20
mapserver" </FONT><FONT face=3DArial size=3D2>instructions by =
Gayathri=20
Swaminathan </FONT></DIV>
<DIV><FONT face=3DArial size=3D2>(<A=20
href=3D"http://lists.gis.umn.edu/pipermail/mapserver-users/2003-April/003=
469.html">http://lists.gis.umn.edu/pipermail/mapserver-users/2003-April/0=
03469.html</A>).=20
About</FONT></DIV>
<DIV><FONT face=3DArial size=3D2>postgis, I don't know if it will =
run, because=20
the warnings "ignored" lines.</FONT></DIV>
<DIV><FONT face=3DArial size=3D2>The mapserver compilation erros =
results=20
are:</FONT></DIV>
<DIV><FONT face=3DArial size=3D2>nmake /f Makefile.vc</FONT></DIV>
<DIV><FONT face=3DArial size=3D2>Microsoft (R) Program Maintenance=20
Utility Version 6.00.8168.0<BR>Copyright (C) Microsoft =
Corp=20
1988-1998. All rights reserved.</FONT></DIV>
<DIV><FONT face=3DArial =
size=3D2> cl=20
libpq7.3.2/libpq.lib libpq7.3.2/interfaces/libpq/libpqdll.lib=20
/nologo<BR> /Zi /W3 /DDEBUG /DWIN32 libpq7.3.2/libpq.lib=20
libpq7.3.2/interfaces/libpq/libpqd<BR>ll.lib -I gd-1.8.4 -I=20
tiff-v3.5.7/libtiff -I proj-4.4.5/src =20
-Iphp-4.3.1\rege<BR>x -DPHP_NO_ALIASES -Igdal-1.1.7/ogr/ogrsf_frmts=20
-Igdal-1.1.7/ogr -Igdal-1.1.7/og<BR>r/../port =
-Igdal-1.1.7/core -I=20
Libwww/library/src -I Libwww/modules/expat/xmlpa<BR>rse =
-DHAVE_STRING_H=20
-DREGEX_MALLOC -DNEED_STRCASECMP -DNEED_STRNCASECMP =20
-DUSE_<BR>EPPL -DUSE_PROJ -DUSE_PROJ_API_H -DUSE_TIFF =
-DUSE_GD_GIF=20
-DUSE_GD_PNG -DUSE_GD_<BR>JPEG -DUSE_GD_WBMP -DUSE_GD_TTF =
-DUSE_GD_TTF=20
-DGD_HAS_GDIMAGEGIFPTR -DUSE_OGR -<BR>DUSE_WMS -DUSE_WMS_LYR =20
-DIGNORE_MISSING_DATA -DUSE_GDAL -DFEATURE_INFO_HTML =
/c<BR>mapwmslayer.c=20
/Fomapwmslayer.obj<BR>Command line warning D4027 : source file=20
'libpq7.3.2/libpq.lib' ignored<BR>Command line warning D4027 : =
source file=20
'libpq7.3.2/interfaces/libpq/libpqdll.l ib' ignored<BR>Command line =
warning=20
D4027 : source file 'libpq7.3.2/libpq.lib' ignored<BR>Command line =
warning=20
D4027 : source file 'libpq7.3.2/interfaces/libpq/libpqdll.l ib'=20
ignored<BR>mapwmslayer.c<BR>Libwww/Library/src/HTProt.h(58) : error =
C2061:=20
syntax error : identifier =
'HTProtocolId'<BR>Libwww/Library/src/HTProt.h(58)=20
: error C2059: syntax error : ';'<BR>Libwww/Library/src/HTProt.h(85) =
: error=20
C2146: syntax error : missing ')' before identifier=20
'port'<BR>Libwww/Library/src/HTProt.h(85) : error C2081: =
'HTProtocolId' :=20
name in formal parameter list =
illegal<BR>Libwww/Library/src/HTProt.h(85) :=20
error C2061: syntax error : identifier=20
'port'<BR>Libwww/Library/src/HTProt.h(85) : error C2059: syntax =
error :=20
';'<BR>Libwww/Library/src/HTProt.h(85) : error C2059: syntax error : =
','<BR>Libwww/Library/src/HTProt.h(88) : error C2059: syntax error : =
')'<BR>Libwww/Library/src/HTProt.h(132) : error C2061: syntax error =
:=20
identifier 'HTProtocol_id'<BR>Libwww/Library/src/HTProt.h(132) : =
error=20
C2059: syntax error : ';'<BR>Libwww/Library/src/HTProt.h(132) : =
error C2059:=20
syntax error : 'type'<BR>Libwww/Library/src/HTHost.h(65) : error =
C2146:=20
'u_port'<BR>Libwww/Library/src/HTHost.h(65) : error C2081: 'u_short' =
: name=20
in formal parameter list illegal<BR>Libwww/Library/src/HTHost.h(65) =
: error=20
C2061: syntax error : identifier =
'u_port'<BR>Libwww/Library/src/HTHost.h(65)=20
: error C2059: syntax error : ';'<BR>Libwww/Library/src/HTHost.h(65) =
: error=20
C2059: syntax error : ')'<BR>Libwww/Library/src/HTHost.h(66) : error =
C2146:=20
'u_port'<BR>Libwww/Library/src/HTHost.h(66) : error C2081: 'u_short' =
: name=20
in formal parameter list illegal<BR>Libwww/Library/src/HTHost.h(66) =
: error=20
'u_port'<BR>Libwww/Library/src/HTHost.h(66)=20
: error C2059: syntax error : ';'<BR>Libwww/Library/src/HTHost.h(66) =
: error=20
C2059: syntax error : ')'<BR>Libwww/Library/src/HTHstMan.h(60) : =
error=20
'u_short'<BR>Libwww/Library/src/HTHstMan.h(94) : error C2079: =
'sock_addr'=20
uses undefined struct =
'sockaddr_in'<BR>Libwww/Library/src/HTHstMan.h(110) :=20
error C2059: syntax error : '}'<BR>mapwmslayer.c(292) : warning =
C4013:=20
'index' undefined; assuming extern =
returning int<BR>mapwmslayer.c(292)=20
: warning C4047: '=3D' : 'const char *' differs in levels of in =
direction from=20
'int '<BR>mapwmslayer.c(340) : warning C4013: 'isspace' undefined; =
assuming=20
extern returning int<BR>mapwmslayer.c(368) : warning C4090: =
'function' :=20
different 'const' qualifiers<BR>mapwmslayer.c(368) : warning C4024:=20
'strcasecmp' : different types for formal and actual parameter =
2<BR>NMAKE :=20
fatal error U1077: 'cl' : return code =
'0x2'<BR>Stop.<BR></FONT></DIV>
<DIV><FONT face=3DArial size=3D2>All helps are welcome,</DIV></FONT>
<DIV><FONT face=3DArial=20
size=3D2>Ros=E2ngela</DIV></BLOCKQUOTE></BLOCKQUOTE></FONT></BODY></HTML>=
------=_NextPart_000_000F_01C31894.75CE59F0--
