[Mapserver-users] Re: Linux segmentation problem
Vincent Schut
schut at sarvision.com
Tue May 13 08:59:50 EDT 2003
Nope, don't see any problems...
Mind that if you compiled some of the libs yourself these usually end up in
/usr/local/lib, while installed libs are in /usr/lib. If you compile a lib
yourself you should first remove the installed (redhat) lib package (rpm -e
libxxx), otherwise probably the old installed version would still be used,
which can (and will) lead to errors. Or configure any libs you compile to get
installed in /usr/lib (--prefix=... configure option). But as shp2img runs
fine, I don't think you have a problem like this.
However, you could check just to be sure... there should be no libraries in
/usr/lib that are also in /usr/local/lib.
I'm no regular user of the cgi version of mapserver. Usually use
php_mapscript. Maybe someone with more mapserver cgi debugging experience can
say something about this?
Cheers,
Vincent.
On Tuesday 13 May 2003 14:49, Hatcher Matthew wrote:
> Hi,
> All the libraries are found and look to be in the places I expected them to
> be. Anybody more seasoned at looking at this kind of stuff than me see any
> problems?
> Matt.
> ldd mapserv
> libgd.so.2 => /usr/local/lib/libgd.so.2 (0x40029000)
> libjpeg.so.62 => /usr/lib/libjpeg.so.62 (0x4007a000)
> libfreetype.so.6 => /usr/lib/libfreetype.so.6 (0x40098000)
> libpng12.so.0 => /usr/lib/libpng12.so.0 (0x400e9000)
> libz.so.1 => /usr/lib/libz.so.1 (0x4010c000)
> libproj.so.0 => /usr/local/lib/libproj.so.0 (0x4011a000)
> libgdal.1.1.so => /usr/local/lib/libgdal.1.1.so (0x4014d000)
> libcurl.so.2 => /usr/lib/libcurl.so.2 (0x403a4000)
> libssl.so.4 => /lib/libssl.so.4 (0x403c7000)
> libcrypto.so.4 => /lib/libcrypto.so.4 (0x403fc000)
> libdl.so.2 => /lib/libdl.so.2 (0x404ed000)
> libresolv.so.2 => /lib/libresolv.so.2 (0x404f0000)
> libgssapi_krb5.so.2 => /usr/kerberos/lib/libgssapi_krb5.so.2
> (0x40503000)
> libkrb5.so.3 => /usr/kerberos/lib/libkrb5.so.3 (0x40516000)
> libk5crypto.so.3 => /usr/kerberos/lib/libk5crypto.so.3 (0x40574000)
> libcom_err.so.3 => /usr/kerberos/lib/libcom_err.so.3 (0x40584000)
> libpthread.so.0 => /lib/tls/libpthread.so.0 (0x40586000)
> libm.so.6 => /lib/tls/libm.so.6 (0x40593000)
> libstdc++.so.5 => /usr/lib/libstdc++.so.5 (0x405b6000)
> libc.so.6 => /lib/tls/libc.so.6 (0x42000000)
> libXpm.so.4 => /usr/X11R6/lib/libXpm.so.4 (0x40669000)
> libX11.so.6 => /usr/X11R6/lib/libX11.so.6 (0x40678000)
> libungif.so.4 => /usr/lib/libungif.so.4 (0x40757000)
> libgcc_s.so.1 => /lib/libgcc_s.so.1 (0x4075f000)
> /lib/ld-linux.so.2 => /lib/ld-linux.so.2 (0x40000000)
> -----Original Message-----
> From: Vincent Schut [mailto:schut at sarvision.com]
> Sent: 13 May 2003 13:37
> To: Hatcher Matthew; 'Björn Platzen';
> 'mapserver-users at lists.gis.umn.edu'
> Subject: Re: [Mapserver-users] Linux segmentatio n problem
> Matt,
> If you want to be sure about the shared libraries, run 'ldd mapserv' (and
> 'ldd
> php_mapscript.so' if you want to use mapscript).
> Regards,
> Vincent Schut.
> On Tuesday 13 May 2003 14:00, Hatcher Matthew wrote:
> > Hi Bjoern,
> > Thanks for your suggestion, but unfortunately, shp2img runs fine without
> > any errors!
> > I don't think mapserv is actually getting as far as reading the map file,
> > because I get a segmentation fault whether I specify a valid map file or
> > not. I'm pretty sure it's not that it can't find some shared libraries,
> > as they normally complain that they are missing when you do "mapserv -v".
> > Any more ideas?!
> > Matt.
> > From: Björn Platzen [mailto:bplatzen at sosnetz.de]
> > Sent: 13 May 2003 12:47
> > To: Hatcher Matthew; 'mapserver-users at lists.gis.umn.edu'
> > Subject: Re: [Mapserver-users] Linux segmentation problem
> > Hi Matthew,
> > > However, if I pass any parameters at all, be they in mapserver, WMS
> > > or WFS format, I get an internal server error. The error log says
> > > only "premature end of script", and if I run mapserv at the command
> > > line by passing a QUERY_STRING here, I get "segmentation fault".
> > I had a similar problem and could find out what went wrong the shp2img
> > program, that was compiled with mapserver. Run it on a shell with your
> > mapfile (e.g. shp2img -m mapfile.map -o output.png) and see, if there
> > are any errors. If yes, I think, that the same errors will happen using
> > the mapserv CGI.
> > hth,
> > Bjoern.
______________________________________
Vincent Schut
Sarvision B.V.
Wageningen, The Netherlands
www.sarvision.com
