[Mapserver-users] Re: data/mapfile organization advice sought
pkishor_98
pkishor at geoanalytics.com
Tue May 13 09:09:02 EDT 2003
--- In mapserver-users at yahoogroups.com, Jan Hartmann <jhart at f...> wrote:
> Note that for security reasons the DATA statement is *not*
scriptable by
> default any more. You have to put "DATAPATTERN <regex>" somewhere in
> your MapFile. <regex> is a regular expression; only DATA-pathnames
> agreeing with that expression are allowed after that. When you leave
> DATAPATTERN out, all scripted DATA calls will be silently ignored.
woo hoo! methinks this is what I want. Thank Jan.
by the way, if a data file referenced in the mapfile is not found,
then Mapserver usually croaks. Is there a switch to make Mapserver
ignore errors? As I mentioned earlier, while existing layers are all
named the same, there are a few layers missing for a few countries.
For example, layer9 might not exist for a couple of countries, etc.
Would be easier for me if I could simply include all the layers in my
mapfile, but if a particular layer didn't exist, it would be simply
ignored by Mapserver.
> Puneet Kishor wrote:
> > To ms data mavens -- please give me a piece of your mind.
> > I have shapefile data of several countries, about 14 countries.
> > Each country has 8 to 12 different layers, but they are all called
the
> > same. For example, all countries have a layer called "layer1",
"layer2",
> > and so on, while a few countries may not have "layer8" or
"layer11," etc.
> > If I were to draw all the countries together, they would draw
correctly,
> > that is, they are in the correct geographic space. However, their
data
> > are self-contained. That is, even though country1 and country2 are
> > contiguous, drawing country1 does not bring up country2... they
are in
> > different folders.
> > How do I create and work with their mapfiles?
> > I can't really have one big mongo mapfile with all the layers of
all the
> > countries... it would be unworkable, and probably very inefficient.
> > On the other hand, if I have 14 different mapfiles, they will be
almost
> > identical to each other except for the path to the data. If I make a
> > tweak in any one mapfile (for example, change the color or visible
scale
> > of a layer), I will have to go and change it in 14 different mapfiles.
> > Ideally I would like to have one master mapfile (like a template),
and
> > just substitute (on the fly) the path to the data. I guess I could do
> > some preprocessing with Perl, and swap a filter keyword using regexp
> > search, to create a working, valid mapfile on the fly, but I would
also
> > have to account for those one or two particular layers that happen
to be
> > absent for a given country.
> > Please share your insight.
> > Many tia.
> > Puneet.
> > Mapserver-users mailing list
> > Mapserver-users at l...
> > http://lists.gis.umn.edu/mailman/listinfo/mapserver-users
