[Mapserver-users] Slow MapServer with large data
pkishor_98
pkishor at geoanalytics.com
Tue May 13 09:13:41 EDT 2003
--- In mapserver-users at yahoogroups.com, jankarin at p... wrote:
> I have tried on af few shapefiles, but it doesn't help much. And it
wouldn't have any effect on our tab-data.
> By the way: Is 15 sec. for a 25 MB shapefile/40 sec for a 30 MB
MapInfo map-file the usual speed for MapServer on a PIII, 650 Mhz, 262
MB RAM ?
sorry... just jumping in. 15 secs us way too much for anything (in my
opinion). I have as big or bigger files running on a beatup 1 Ghz
Duron box (that is like a Celeron, not a PIII, in Intel-speak) with
128 Mb ram. Usually it takes a couple or 3 or 4 secs to return.
Here are my rough benchmarks -- pure db queries should be returned to
the completely formed web page in sub-second (a few hundred
microseconds usually). Mapserver queries should not exceed 5 secs
(5000 microsecs). After that I start worrying about performance.
As Steve said, judicious use of shptree goes a long way.
> If it is, there's only one thing to do, if not .....
> Anyone have some ideas?
> Jan
> woodbri at s... wrote:
> > Have you built shptree indexes for all your shapefiles?
> > On 9 May 2003 at 13:14, jankarin at p... wrote:
> > > Hello
> > > I have a little problem with the speed in MapServer.
> > > We're trying to make qiuck-viewer to shape- and
> > tab-formats, but
> > > MapServer is running slow with large data: 20 seconds:
> > Shapefil 17 MB,
> > > dbf-fil 9,5 MB. 45 seconds: Map-fil 31 MB, Dat-fil 25 MB.
> > > I have been trying with the GCI-version and PHP Mapscript
> > - same
> > > result.
> > > I am running MapServer 3.6.4 with PNG-output under Apache
> > 2.4.5 on
> > > Windows 2000. The pc is Pentim III, 650 Mhz, 262 MB RAM.
> > > In another installation (PII, 400 Mhz, 196 MB RAM) a
> > shapefile
> > > (shapefile 17 MB, dbf-fil 9,5 MB) took 80 seconds to
> > show.
> > > We're using MapServer in an application which is
> > dynamically creating
> > > map-files with Mapscript (only showing one layer at a
> > time). We're
> > > talknig about 17.000 layers in shape- and tabformats, so
> > it is not
> > > possible to improve indexfiles or anything else related to
> > a single
> > > layer.
> > > Can anyone help?
> > > Thanks,
> > > Jan Christiansen
> > > jankarin at p...
> > > Engineering College of Copenhagen
> > > _______________________________________________
> > > Mapserver-users mailing list
> > > Mapserver-users at l...
> > > http://lists.gis.umn.edu/mailman/listinfo/mapserver-users
