FIXED: [Mapserver-users] Linux segmenta tion problem
Hatcher Matthew
MJHATCHER at qinetiq.com
Tue May 13 10:39:29 EDT 2003
Markus,
Excellent. Thank you very much!
That version of the build worked absolutely fine for me - no seg fault.
Clearly there must be some issue with the current build. However, a couple
of weeks old is all I require.
Thanks everyone on the list for your assistance and suggestions.
Regards, Matt.
-----Original Message-----
From: m.spring at gmx.de [mailto:m.spring at gmx.de]
Sent: 13 May 2003 15:02
To: mapserver-users at lists.gis.umn.edu; Hatcher Matthew
Subject: Re: [Mapserver-users] Linux segmentatio n problem
-----BEGIN PGP SIGNED MESSAGE-----
Hash: SHA1
Hatcher Matthew <MJHATCHER at qinetiq.com> writes:
> Hi all,
> In that case, could someone please post the URL of an older copy of
> nightly.tgz so I can test if that suffers from the same problem. I don't
Checked out from CVS with
cvs -d:pserver:cvs at mapserver.gis.umn.edu:/data2/cvsroot -z3 checkout -D
"2003-05-01" mapserver
You can download it from
http://dream.lrrl.arch.tu-muenchen.de/~springm/mapserver/mapserver-dev-20030
501.tgz
I configured it with
./configure \
--without-pdf \
--without-tiff \
--with-zlib \
--with-jpeg \
--with-freetype \
--with-threads \
--with-gd=/build/server/gd-2.0.12gif \
--with-gdal=/usr/local/bin/gdal-config \
--with-ogr=/usr/local/bin/gdal-config \
--with-proj=/build/server/proj-4.4.5 \
--enable-debug
and it runs without segfault.
Note that you can test the cgi on the commandline with those commands:
# export REQUEST_METHOD=GET
# export
QUERY_STRING="map=/data/web/rgu_intern/radlmap/radlmap.dfo.map&mode=map"
# mapserv | sed '1,2d' | display
assumed that you have mapserv in your directory or in your path and -->
you have 'display' to read image data from STDIN
Hope this helps
Markus
-----BEGIN PGP SIGNATURE-----
Version: GnuPG v1.0.6 (GNU/Linux)
Comment: Processed by Mailcrypt 3.5.6 and Gnu Privacy Guard
<http://www.gnupg.org/>
iD8DBQE+wPrBxxUzQSse11ARAn0UAJwPGYysHcjeyKpxKlWjyXLbUTa2pACggSCP
1Z4W0SXvZCcyxI/fMGvutRQ=
=dz2e
-----END PGP SIGNATURE-----
The Information contained in this E-Mail and any subsequent correspondence
is private and is intended solely for the intended recipient(s).
For those other than the recipient any disclosure, copying, distribution,
or any action taken or omitted to be taken in reliance on such information
is prohibited and may be unlawful.
Emails and other electronic communication with QinetiQ may be monitored.
Calls to our Customer Contact Centre may be recorded for quality control,
regulatory and monitoring purposes.
