[Mapserver-users] Label
Lowell Filak
lfilak at medinaco.org
Tue May 13 12:35:05 EDT 2003
Simple way: I'm not sure one exists.
What we currently do is use MapScript to loop through the label cache and create a rectangular imagemap around each label.
This also creates the client-side javascript to show/hide the label as the mouse passes.
It does not create the imagemap for the actual polygon as that can take a loooong time to do dynamically based on number of arcs in each polygon & segments in each arc.
If the data is static you could always create the imagemap information ahead of time.
I have seen at least a couple of discussions to that effect...
http://mapserver.gis.umn.edu/data2/wilma/mapserver-users/0208/msg00016.html
HTH
Lowell F.
The following message was sent by "Marco Ferrari" <Mferrari at crema.unimi.it> on Tue, 13 May 2003 16:03:48 +0200.
> Hi,
> Is it possible to display a label only when the mouse is passing on a specified polygon?
> If yes, how?
> Thanks.
> Mapserver-users mailing list
> Mapserver-users at lists.gis.umn.edu
> http://lists.gis.umn.edu/mailman/listinfo/mapserver-users
