[Mapserver-users] SDE-problem
Steve Lime
steve.lime at dnr.state.mn.us
Tue May 13 14:19:16 EDT 2003
Have you edited the windows services file to register your SDE server?
>>> Jörn Witte <jwitte at gmx.at> 05/13/03 01:00PM >>>
I've compiled the Mapserver 3.6.5 on WinXP with MSVC++ 6.0 and
SDE-support successfully.
But if I try to connect the ArcSDE Database, I get the following
error-message:
msSDELayerOpen(): SDE error. SE_connection_create(): Entry for SDE
instance not found in services file. (-102)
The error-message doesn`t exist, if the MapServer and the
ArcSDE-geodatabase are running on the same host.
Does anyone have an idea of what is going wrong?
Thanks,
Jörn Witte
