[Mapserver-users] SDE-support-problem
Jörn Witte
jwitte at gmx.at
Tue May 6 09:29:29 EDT 2003
This is a multi-part message in MIME format.
------=_NextPart_000_0001_01C313E4.4A6C5230
Content-Type: text/plain;
charset="iso-8859-1"
Content-Transfer-Encoding: quoted-printable
=20
I=92ve got a question concerning ArcSDE 8.1 and Mapserver 3.6.5.=20
I=92ve compiled the Mapserver on XP with MSVC++ successfully..
After this, i have move the mapserv.exe into the cgi-bin-folder (Apache)
and
configured a new map-file on MapLab.
Now, i starts the MapBrowser and gets the following message: =
=91MapServer
Error in msSDELayerOpen(): SDE support is not available.=92 =20
Does anyone have an idea of what is going wrong?
=20
Thanks,
J=F6rn Witte
=20
=20
My configuration is:
=20
C:\Programme\Apache Group\Apache2\cgi-bin>mapserv -v
MapServer version 3.6.5 OUTPUT=3DGIF OUTPUT=3DPNG OUTPUT=3DJPEG =
OUTPUT=3DWBMP
SUPPORTS=3DPROJ SUPPORTS=3DTTF SUPPORTS=3DWMS_SERVER INPUT=3DTIFF =
INPUT=3DSDE
INPUT=3DOGR INPUT=3DSHAPEFILE
=20
=20
My Makefile is:
=20
=20
# makefile.vc - Main MapServer makefile for MSVC++
# This VC++ makefile will build MAPSERVER.LIB, MAPSERV.EXE, and the
other
# MapServer command-line programs.
# To use the makefile:
# - Open a DOS prompt window
# - Run the VCVARS32.BAT script to initialize the VC++ environment
variables
# - Start the build with: nmake /f makefile.vc
# $Id: Makefile.vc,v 1.21.2.1 2002/08/01 14:46:45 assefa Exp $
=20
OPTFLAGS =3D /nologo /Zi /W3 /DDEBUG /DWIN32
#OPTFLAGS =3D /nologo /Zi=20
BASE_CFLAGS =3D $(OPTFLAGS)=20
LDFLAGS =3D /NODEFAULTLIB:libcd /DEBUG
=20
CC=3D cl
LINK=3D link /debug
=20
# If you want to ignore missing datafile errors uncomment the following
# line. This is especially useful with large tiled datasets that may not
# have complete data for each tile.
IGNORE_MISSING_DATA=3D-DIGNORE_MISSING_DATA
=20
# Apparently these aren't as commonplace as I'd hoped. Edit the
# following line to reflect the missing functions on your platform.
#STRINGS=3D-DNEED_STRCASECMP -DNEED_STRNCASECMP -DNEED_STRDUP
=20
# Proj.4 distribution (cartographic projection routines). Not required
for normal use. (EXPERIMENTAL)
PROJ_LIB=3D../proj-4.4.3/src/proj.lib
PROJ_INC=3D-I../proj-4.4.3/src
PROJ=3D-DUSE_PROJ -DUSE_PROJ_API_H
=20
#Use this flag to compile with WMS support
WMS=3D-DUSE_WMS
=20
#Use this flag to compile with WMS Client support
#you need the libwww from http://www.w3.org/Library/.
#WMSCLIENT=3D -DUSE_WMS_LYR
=20
#WWWLIB_INC=3D-I../libwww/library/src -I../libwww/modules/expat/xmlparse
#WWWLIB_LIB=3D../libwww/bin/wwwcore.lib ../libwww/bin/wwwapp.lib
../libwww/bin/wwwinit.lib ../libwww/bin/wwwutils.lib
=20
# GD distribution (graphics library GIF and/or PNG support). (REQUIRED)
# - Version 1.2 is included and writes LZW GIF (-DUSE_GD_GIF
-DUSE_GD_SWAP_XY).
# - Versions 1.3 to 1.5 write non-LZW GIF (-DUSE_GD_GIF).
# - Versions 1.6 and greater write PNG (-DUSE_GD_PNG). Add -lpng -lz
to GD_LIB line.
# - Versions 1.8 (or was it 1.7?) also supports JPEG and WBMP
(-DUSE_GD_JPEG -DUSE_GD_WBMP)
# The following lines will compile GD 1.2:
#GDFONT_OBJ=3D gd-1.2/gdfontt.obj gd-1.2/gdfonts.obj
gd-1.2/gdfontmb.obj \
# gd-1.2/gdfontl.obj gd-1.2/gdfontg.obj
#GD_INC=3D -I./gd-1.2
#GD_LIB=3D gd-1.2/gd.lib
#GD=3D -DUSE_GD_GIF -DUSE_GD_SWAP_XY
#MAKE_GD=3Dgd
=20
# A patched version of GD that supports GIF, JPEG, PNG and WBMP can be=20
# downloaded from http://www.rime.com.au/gd/.
# The following defns will include the patched GD 1.8.4 with TTF:
GDFONT_OBJ=3D
GD_INC=3D -I../gd-1.8.4
GD_LIB=3D ../gd-1.8.4/gd.lib \
../jpeg-6b/libjpeg.lib \
../lpng120/projects/msvc/win32/libpng/lib_dbg/libpng.lib \
../zlib/zlib.lib ../freetype-2.1.4/objs/freetype214ST_D.lib
GD=3D -DUSE_GD_GIF -DUSE_GD_PNG -DUSE_GD_JPEG -DUSE_GD_WBMP
-DUSE_GD_TTF \
-DUSE_GD_TTF -DGD_HAS_GDIMAGEGIFPTR
MAKE_GD=3Dgd
=20
# ../jpeg-6b/libjpeg.lib \
# ../libpng-1.0.8/libpng.lib \
# ../zlib/zlibstat.lib ../freetype/lib/freetype.lib
#GD=3D -DUSE_GD_GIF -DUSE_GD_PNG -DUSE_GD_JPEG -DUSE_GD_WBMP
-DUSE_GD_TTF \
# -DUSE_GD_TTF -DGD_HAS_GDIMAGEGIFPTR
#MAKE_GD=3Dgd
=20
# TIFF distribution (raster support for TIFF and GEOTIFF
imagery).(RECOMMENDED)
TIFF_INC=3D-I../tiff-v3.5.5/libtiff
TIFF_LIB=3D../tiff-v3.5.5/libtiff/libtiff.lib
TIFF=3D-DUSE_TIFF
=20
# JPEG distribution (raster support for grayscale JPEG images, INPUT
ONLY).
#JPEG_INC=3D
#JPEG_LIB=3D-ljpeg
#JPEG=3D-DUSE_JPEG
=20
# EPPL7 Support (this activates ERDAS as well) Included in the
distribution. Probably the best raster alternative if
# you've got EPPL7 laying around. See http://www.lmic.state.mn.us/ for
more information. (RECOMMENDED)
#EPPL=3D-DUSE_EPPL
#EPPL_OBJ=3Depplib.obj
=20
# OGR Support OGC Simple Feature inspired interface for vector
# formats. See http://gdal.velocet.ca/projects/opengis/
GDAL_DIR=3D ..\gdal-1.1.8
OGR=3D-DUSE_OGR
OGR_LIB =3D $(GDAL_DIR)/gdal.lib
$(GDAL_DIR)/ogr/ogrsf_frmts/ogrsf_frmts.lib
$(GDAL_DIR)/ogr/ogrsf_frmts/ogrsf_frmts_sup.lib $(GDAL_DIR)/ogr/ogr.lib
$(GDAL_DIR)/ogr/../port/cpl.lib
OGR_INC =3D -I$(GDAL_DIR)/ogr/ogrsf_frmts -I$(GDAL_DIR)/ogr
-I$(GDAL_DIR)/ogr/../port -I$(GDAL_DIR)/core
=20
#GDAL=3D-DUSE_GDAL
=20
# ESRI SDE support.
SDE_OPT=3D-DUSE_SDE -DWIN32
SDE_INC=3D -I ../arcsde/include -I ../arcsde/bin
SDE_LIB=3D../arcsde/lib/sde81.lib ../arcsde/lib/sg81.lib
../arcsde/lib/pe81.lib
=20
# UofMN GIS/Image Processing Extension (very experimental)
#EGIS=3D-DUSE_EGIS
=20
#ERR_OBJ=3D./errLog/errLog.o
#ERR_INC=3D-I./errLog
#ERR_LIB=3D-L./errLog -lerrLog
=20
#IMGGEN_OBJ=3D./imgSrc/imgLib.o
#IMGGEN_INC=3D-I./imgSrc
#IMGGEN_LIB=3D-L./imgSrc -limgGEN
=20
#ECWDIR=3D C:\ProgFile\ECW_SDK
#ECW_LIB=3D$(ECWDIR)\lib\NCSEcw.lib $(ECWDIR)\lib\NCSEcwC.lib \
# $(ECWDIR)\lib\NCSUtil.lib
# VC++ does not include the REGEX library... so we must provide our one.
# The following definitions will try to build GNU regex-0.12 located in
the
# regex-0.12 sub-directory.
# If it was not included in the source distribution, then you can get it
# ftp://ftp.gnu.org/pub/gnu/regex/regex-0.12.tar.gz
#REGEX_OBJ=3D..\regex-0.12\regex.obj
#REGEX_INC=3D-I ..\regex-0.12
=20
# IMPORTANT NOTE ABOUT REGEX FOR PHP_MAPSCRIPT USERS:
# If you want to compile the PHP_MAPSCRIPT module, then you have to make
# MapServer uses the same version of the REGEX library that PHP was=20
# compiled with:
PHP_REGEX=3D..\php-4.3.1\regex
#PHP_REGEX=3D..\php-3.0.14\regex
#PHP_REGEX=3D..\php-4.0.6\regex
#PHP_REGEX=3D..\php-4.1.2\regex
#PHP_REGEX=3D..\php-4.2.1\regex
#PHP_REGEX=3D..\php-4.2.2\regex
REGEX_OBJ=3D$(PHP_REGEX)\regcomp.obj $(PHP_REGEX)\regerror.obj \
$(PHP_REGEX)\regexec.obj $(PHP_REGEX)\regfree.obj
REGEX_INC=3D-I$(PHP_REGEX) -DPHP_NO_ALIASES
=20
# REGEX needs some special flags... here they are for VC++ 6.0
#REGEX_OPT=3D-DHAVE_STRING_H -DREGEX_MALLOC
=20
# --- You shouldn't have to edit anything else. ---
=20
# Main MapServer library.
MS_LIB =3D mapserver.lib
MS_OBJS =3D mapbits.obj maphash.obj mapshape.obj mapxbase.obj \
mapparser.obj maplexer.obj mapindex.obj maptree.obj \
mapsearch.obj mapstring.obj mapsymbol.obj mapfile.obj \
maplegend.obj maputil.obj mapscale.obj mapquery.obj \
maplabel.obj maperror.obj mapprimitive.obj mapproject.obj\
mapraster.obj cgiutil.obj mapsde.obj mapogr.obj \
maptemplate.obj mappostgis.obj maplayer.obj mapresample.obj
mapwms.obj mapwmslayer.obj mapgml.obj maporaclespatial.obj \
mapprojhack.obj \
$(EPPL_OBJ) $(REGEX_OBJ)
=20
MS_HDRS =3D map.h mapfile.h
=20
MS_EXE =3D mapserv.exe \
shp2img.exe legend.exe \
shptree.exe scalebar.exe sortshp.exe tile4ms.exe
=20
LIBS =3D $(MS_LIB) $(GD_LIB) $(TIFF_LIB) $(JPEG_LIB) \
$(PROJ_LIB) $(ERR_LIB) $(IMGGEN_LIB) $(OGR_LIB) \
$(WWWLIB_LIB) $(ECW_LIB) $(SDE_LIB)=20
=20
INCLUDES =3D $(GD_INC) $(TIFF_INC) $(JPEG_INC) \
$(PROJ_INC) $(ERR_INC) $(IMGGEN_INC) $(REGEX_INC) $(OGR_INC)
$(WWWLIB_INC) $(SDE_INC)
=20
CFLAGS =3D $(BASE_CFLAGS) $(INCLUDES) $(REGEX_OPT) $(STRINGS) \
$(EPPL) $(PROJ) $(TIFF) $(JPEG) $(GD) $(OGR) $(WMS)
$(WMSCLIENT) \
$(IGNORE_MISSING_DATA) $(GDAL) -DFEATURE_INFO_HTML
$(SDE_OPT)
=20
# $(EPPL) $(PROJ) $(TIFF) $(JPEG) $(GD) $(OGR) $(WMS)
$(WMSCLIENT) \
# $(IGNORE_MISSING_DATA) $(GDAL) -DFEATURE_INFO_HTML
=20
default: all
=20
all: $(MS_LIB) $(MS_EXE)
=20
$(MS_OBJS): $(MS_HDRS)
=20
$(MS_LIB): $(MS_OBJS)
copy $(GDAL_DIR)\gdal11.pdb .
lib /out:$(MS_LIB) $(MS_OBJS)
=20
$(MS_EXE): $(LIBS)
=20
gd::
cd gd-1.8.4
nmake /f makefile.nt gd.lib OPTFLAGS=3D"$(OPTFLAGS)"
cd ..
=20
.c.obj: =20
$(CC) $(CFLAGS) /c $*.c /Fo$*.obj
=20
.cpp.obj: =20
$(CC) $(CFLAGS) /c $*.cpp /Fo$*.obj
=20
.c.exe:
$(LINK) $(LDFLAGS) $*.obj $(LIBS)
=20
.cpp.exe:
=20
=20
clean:
del *.obj
del $(REGEX_OBJ)
del $(MS_LIB)
del $(MS_EXE)
del *.pdb
del *.exp
del *.ilk
# cd gd-1.2
# nmake -f makefile.nt clean
# cd ..
=20
=20
=20
my mapfile is:
=20
=20
MAP
NAME "Bremen"
STATUS ON
EXTENT 3.46e+006 5.87198e+006 3.50161e+006 5.90314e+006=20
SIZE 400 300=20
IMAGECOLOR 255 255 255
TRANSPARENT OFF
UNITS METERS
INTERLACE ON
IMAGETYPE PNG
IMAGEQUALITY 75
WEB
MINSCALE 20000
MAXSCALE 5e+007
IMAGEPATH "c:/windows/temp/"
IMAGEURL "/ms_tmp/"
END
QUERYMAP
STATUS OFF
SIZE -1 -1=20
COLOR 255 255 0
STYLE HILITE
END
LEGEND
STATUS OFF
TRANSPARENT FALSE
INTERLACE TRUE
POSITION LL
KEYSIZE 20 10=20
KEYSPACING 5 5=20
TEMPLATE "C:/Programme/Apache
Group/Apache2/htdocs/maplab-2.0rc5/htdocs/mapbrowser/legend_template.htm
l"
LABEL
TYPE BITMAP
SIZE MEDIUM
OFFSET 0 0=20
BUFFER 0
MINDISTANCE -1
MINFEATURESIZE -1
COLOR 255 255 255
PARTIALS TRUE
FORCE FALSE
END
END
SCALEBAR
STATUS ON
COLOR 255 255 255
OUTLINECOLOR 0 0 0
BACKGROUNDCOLOR 0 0 0
TRANSPARENT FALSE
UNITS KILOMETERS
INTERVALS 5
SIZE 150 5=20
STYLE 0
POSITION LL
INTERLACE TRUE
LABEL
TYPE BITMAP
SIZE SMALL
OFFSET 0 0=20
BUFFER 0
MINDISTANCE -1
MINFEATURESIZE -1
COLOR 0 0 0
PARTIALS TRUE
FORCE FALSE
END
END
LAYER
NAME "Verwaltung"
STATUS ON
DATA "BREMEN_STADTTEILE,shape"
TYPE POLYGON
CONNECTIONTYPE SDE
CONNECTION "kbs2,esri_sde,sde,sde,EsgibtReis"
UNITS METERS
SIZEUNITS PIXELS
TOLERANCE 3
TOLERANCEUNITS PIXELS
TEMPLATE "ttt.html"
CLASS
NAME "Verwaltungseinheiten"
SYMBOL 0
COLOR 90 200 90
SIZE 1
MINSIZE 1
MAXSIZE 100
END
END
END
Content-Type: text/html;
<html xmlns:o=3D"urn:schemas-microsoft-com:office:office" =
xmlns:w=3D"urn:schemas-microsoft-com:office:word" =
xmlns=3D"http://www.w3.org/TR/REC-html40">
<head>
<META HTTP-EQUIV=3D"Content-Type" CONTENT=3D"text/html; =
charset=3Diso-8859-1">
<meta name=3DProgId content=3DWord.Document>
<meta name=3DGenerator content=3D"Microsoft Word 10">
<meta name=3DOriginator content=3D"Microsoft Word 10">
<link rel=3DFile-List href=3D"cid:filelist.xml at 01C313E4.290CECD0">
<!--[if gte mso 9]><xml>
<o:OfficeDocumentSettings>
<o:DoNotRelyOnCSS/>
</o:OfficeDocumentSettings>
</xml><![endif]--><!--[if gte mso 9]><xml>
<w:WordDocument>
<w:DocumentKind>DocumentEmail</w:DocumentKind>
<w:HyphenationZone>21</w:HyphenationZone>
<w:EnvelopeVis/>
<w:Compatibility>
<w:BreakWrappedTables/>
<w:SnapToGridInCell/>
<w:WrapTextWithPunct/>
<w:UseAsianBreakRules/>
</w:Compatibility>
<w:BrowserLevel>MicrosoftInternetExplorer4</w:BrowserLevel>
</w:WordDocument>
</xml><![endif]-->
<style>
/* Style Definitions */
p.MsoNormal, li.MsoNormal, div.MsoNormal
{mso-style-parent:"";
margin:0cm;
margin-bottom:.0001pt;
mso-pagination:widow-orphan;
font-size:12.0pt;
font-family:"Times New Roman";
mso-fareast-font-family:"Times New Roman";}
a:link, span.MsoHyperlink
{color:blue;
text-decoration:underline;
text-underline:single;}
a:visited, span.MsoHyperlinkFollowed
{color:purple;
pre
{margin:0cm;
font-size:10.0pt;
font-family:"Courier New";
span.EmailFormatvorlage17
{mso-style-type:personal-compose;
mso-style-noshow:yes;
mso-ansi-font-size:10.0pt;
mso-bidi-font-size:10.0pt;
font-family:Arial;
mso-ascii-font-family:Arial;
mso-hansi-font-family:Arial;
mso-bidi-font-family:Arial;
color:windowtext;}
@page Section1
{size:595.3pt 841.9pt;
margin:70.85pt 70.85pt 2.0cm 70.85pt;
mso-header-margin:35.4pt;
mso-footer-margin:35.4pt;
mso-paper-source:0;}
div.Section1
{page:Section1;}
</style>
<!--[if gte mso 10]>
<style>
/* Style Definitions */=20
table.MsoNormalTable
{mso-style-name:"Normale Tabelle";
mso-tstyle-rowband-size:0;
mso-tstyle-colband-size:0;
mso-padding-alt:0cm 5.4pt 0cm 5.4pt;
mso-para-margin:0cm;
mso-para-margin-bottom:.0001pt;
font-size:10.0pt;
</style>
<![endif]-->
</head>
<body lang=3DDE link=3Dblue vlink=3Dpurple =
style=3D'tab-interval:35.4pt'>
<div class=3DSection1>
<p class=3DMsoNormal><font size=3D2 face=3DArial><span =
style=3D'font-size:10.0pt;
font-family:Arial'>Hi,<o:p></o:p></span></font></p>
font-family:Arial'><o:p> </o:p></span></font></p>
<p class=3DMsoNormal><font size=3D2 face=3DArial><span lang=3DEN-GB =
style=3D'font-size:
10.0pt;font-family:Arial;mso-ansi-language:EN-GB'>I’ve got a =
question
concerning ArcSDE 8.1 and Mapserver 3.6.5. <o:p></o:p></span></font></p>
style=3D'font-size:
10.0pt;font-family:Arial;mso-ansi-language:EN-GB'>I’ve compiled =
the
Mapserver on XP with MSVC++ successfully..<o:p></o:p></span></font></p>
style=3D'font-size:
10.0pt;font-family:Arial;mso-ansi-language:EN-GB'>After this, i have =
move the
mapserv.exe into the cgi-bin-folder (Apache) =
and<o:p></o:p></span></font></p>
style=3D'font-size:
10.0pt;font-family:Arial;mso-ansi-language:EN-GB'>configured a new =
map-file on
MapLab.<o:p></o:p></span></font></p>
style=3D'font-size:
10.0pt;font-family:Arial;mso-ansi-language:EN-GB'>Now, i starts the =
MapBrowser
and gets the following message: ‘MapServer Error in =
support is not available.’ <span =
style=3D'mso-spacerun:yes'>=A0</span><o:p></o:p></span></font></p>
style=3D'font-size:
10.0pt;font-family:Arial;mso-ansi-language:EN-GB'>Does anyone have an =
idea of
what is going wrong?<o:p></o:p></span></font></p>
style=3D'font-size:
10.0pt;font-family:Arial;mso-ansi-language:EN-GB'><o:p> </o:p></span=
></font></p>
style=3D'font-size:
10.0pt;font-family:Arial;mso-ansi-language:EN-GB'>Thanks,<o:p></o:p></spa=
n></font></p>
style=3D'font-size:
10.0pt;font-family:Arial;mso-ansi-language:EN-GB'>J=F6rn =
Witte<o:p></o:p></span></font></p>
style=3D'font-size:
></font></p>
style=3D'font-size:
></font></p>
style=3D'font-size:
10.0pt;font-family:Arial;mso-ansi-language:EN-GB'>My configuration =
is:<o:p></o:p></span></font></p>
style=3D'font-size:
></font></p>
style=3D'font-size:
10.0pt;font-family:Arial;mso-ansi-language:EN-GB'>C:\Programme\Apache
Group\Apache2\cgi-bin>mapserv -v<o:p></o:p></span></font></p>
style=3D'font-size:
10.0pt;font-family:Arial;mso-ansi-language:EN-GB'>MapServer version =
3.6.5
OUTPUT=3DGIF OUTPUT=3DPNG OUTPUT=3DJPEG OUTPUT=3DWBMP SUPPORTS=3DPROJ =
SUPPORTS=3DTTF
SUPPORTS=3DWMS_SERVER INPUT=3DTIFF INPUT=3DSDE INPUT=3DOGR =
INPUT=3DSHAPEFILE<o:p></o:p></span></font></p>
style=3D'font-size:
></font></p>
style=3D'font-size:
></font></p>
style=3D'font-size:
10.0pt;font-family:Arial;mso-ansi-language:EN-GB'>My Makefile =
style=3D'font-size:
></font></p>
style=3D'font-size:
></font></p>
<p class=3DMsoNormal =
style=3D'mso-layout-grid-align:none;text-autospace:none'><font
size=3D2 face=3D"Courier New"><span lang=3DEN-GB =
style=3D'font-size:10.0pt;font-family:
"Courier New";mso-ansi-language:EN-GB'>#<o:p></o:p></span></font></p>
"Courier New";mso-ansi-language:EN-GB'># makefile.vc - Main MapServer =
makefile
for MSVC++<o:p></o:p></span></font></p>
"Courier New";mso-ansi-language:EN-GB'># This VC++ makefile will build
MAPSERVER.LIB, MAPSERV.EXE, and the other<o:p></o:p></span></font></p>
"Courier New";mso-ansi-language:EN-GB'># MapServer command-line =
programs.<o:p></o:p></span></font></p>
"Courier New";mso-ansi-language:EN-GB'># To use the =
makefile:<o:p></o:p></span></font></p>
"Courier New";mso-ansi-language:EN-GB'>#<span =
</span>- Open a DOS prompt window<o:p></o:p></span></font></p>
</span>- Run the VCVARS32.BAT script to initialize the VC++ environment
variables<o:p></o:p></span></font></p>
</span>- Start the build with:<span style=3D'mso-spacerun:yes'>=A0 =
</span>nmake /f
makefile.vc<o:p></o:p></span></font></p>
"Courier New";mso-ansi-language:EN-GB'># $Id: Makefile.vc,v 1.21.2.1 =
2002/08/01
14:46:45 assefa Exp $<o:p></o:p></span></font></p>
"Courier =
New";mso-ansi-language:EN-GB'><o:p> </o:p></span></font></p>
"Courier New";mso-ansi-language:EN-GB'>OPTFLAGS =3D<span =
style=3D'mso-tab-count:
1'>=A0 </span>/nologo /Zi /W3 /DDEBUG =
/DWIN32<o:p></o:p></span></font></p>
"Courier New";mso-ansi-language:EN-GB'>#OPTFLAGS =3D<span =
1'> </span>/nologo /Zi <o:p></o:p></span></font></p>
"Courier New";mso-ansi-language:EN-GB'>BASE_CFLAGS =3D <span =
1'>=A0=A0=A0 </span>$(OPTFLAGS) <o:p></o:p></span></font></p>
size=3D2 face=3D"Courier New"><span =
style=3D'font-size:10.0pt;font-family:"Courier New"'>LDFLAGS
=3D<span style=3D'mso-tab-count:1'>=A0=A0 </span>/NODEFAULTLIB:libcd =
/DEBUG<o:p></o:p></span></font></p>
style=3D'font-size:10.0pt;font-family:"Courier =
New"'><o:p> </o:p></span></font></p>
style=3D'font-size:10.0pt;font-family:"Courier New"'>CC=3D<span
style=3D'mso-spacerun:yes'>=A0=A0=A0=A0 =
</span>cl<o:p></o:p></span></font></p>
style=3D'font-size:10.0pt;font-family:"Courier New"'>LINK=3D<span
style=3D'mso-spacerun:yes'>=A0=A0 </span>link =
/debug<o:p></o:p></span></font></p>
New"'>#<o:p></o:p></span></font></p>
"Courier New";mso-ansi-language:EN-GB'># If you want to ignore missing =
datafile
errors uncomment the following<o:p></o:p></span></font></p>
"Courier New";mso-ansi-language:EN-GB'># line. This is especially useful =
with
large tiled datasets that may not<o:p></o:p></span></font></p>
"Courier New";mso-ansi-language:EN-GB'># have complete data for each =
tile.<o:p></o:p></span></font></p>
New"'>IGNORE_MISSING_DATA=3D-DIGNORE_MISSING_DATA<o:p></o:p></span></font=
></p>
"Courier New";mso-ansi-language:EN-GB'># Apparently these aren't as =
commonplace
as I'd hoped. Edit the<o:p></o:p></span></font></p>
"Courier New";mso-ansi-language:EN-GB'># following line to reflect the =
missing
functions on your platform.<o:p></o:p></span></font></p>
"Courier New";mso-ansi-language:EN-GB'>#STRINGS=3D-DNEED_STRCASECMP
-DNEED_STRNCASECMP -DNEED_STRDUP<o:p></o:p></span></font></p>
New"'>STRINGS=3D-DNEED_STRCASECMP
-DNEED_STRNCASECMP<o:p></o:p></span></font></p>
size=3D2 face=3D"Courier New"><span lang=3DFR =
"Courier New";mso-ansi-language:FR'># Proj.4 distribution (cartographic
projection routines). </span></font><font size=3D2 face=3D"Courier =
New"><span
lang=3DEN-GB style=3D'font-size:10.0pt;font-family:"Courier =
EN-GB'>Not required for normal use. </span></font><font size=3D2
New"'>(EXPERIMENTAL)<o:p></o:p></span></font></p>
New"'>PROJ_LIB=3D../proj-4.4.3/src/proj.lib<o:p></o:p></span></font></p>
New"'>PROJ_INC=3D-I../proj-4.4.3/src<o:p></o:p></span></font></p>
"Courier New";mso-ansi-language:FR'>PROJ=3D-DUSE_PROJ =
-DUSE_PROJ_API_H<o:p></o:p></span></font></p>
"Courier New";mso-ansi-language:FR'><o:p> </o:p></span></font></p>
"Courier New";mso-ansi-language:EN-GB'>#Use this flag to compile with =
WMS
support<o:p></o:p></span></font></p>
"Courier =
New";mso-ansi-language:EN-GB'>WMS=3D-DUSE_WMS<o:p></o:p></span></font></p=
"Courier =
WMS
Client support<o:p></o:p></span></font></p>
"Courier New";mso-ansi-language:EN-GB'>#you need the libwww from
http://www.w3.org/Library/.<o:p></o:p></span></font></p>
style=3D'font-size:10.0pt;font-family:"Courier New"'>#WMSCLIENT=3D
-DUSE_WMS_LYR<o:p></o:p></span></font></p>
New"'>#WWWLIB_INC=3D-I../libwww/library/src
-I../libwww/modules/expat/xmlparse<o:p></o:p></span></font></p>
New"'>#WWWLIB_LIB=3D../libwww/bin/wwwcore.lib
../libwww/bin/wwwapp.lib ../libwww/bin/wwwinit.lib =
../libwww/bin/wwwutils.lib<o:p></o:p></span></font></p>
"Courier New";mso-ansi-language:EN-GB'># GD distribution (graphics =
library GIF
and/or PNG support). </span></font><font size=3D2 face=3D"Courier =
New"><span
New"'>(REQUIRED)<o:p></o:p></span></font></p>
</span>- Version 1.2 is included and writes LZW GIF (-DUSE_GD_GIF
-DUSE_GD_SWAP_XY).<o:p></o:p></span></font></p>
</span>- Versions 1.3 to 1.5 write non-LZW GIF =
(-DUSE_GD_GIF).<o:p></o:p></span></font></p>
</span>- Versions 1.6 and greater write PNG (-DUSE_GD_PNG). Add -lpng =
-lz to
GD_LIB line.<o:p></o:p></span></font></p>
</span>- Versions 1.8 (or was it 1.7?) also supports JPEG and WBMP
(-DUSE_GD_JPEG -DUSE_GD_WBMP)<o:p></o:p></span></font></p>
"Courier New";mso-ansi-language:EN-GB'># The following lines will =
compile GD
1.2:<o:p></o:p></span></font></p>
style=3D'font-size:10.0pt;font-family:"Courier New"'>#GDFONT_OBJ=3D<span
style=3D'mso-tab-count:1'>=A0=A0=A0=A0=A0 </span>gd-1.2/gdfontt.obj =
gd-1.2/gdfonts.obj
gd-1.2/gdfontmb.obj \<o:p></o:p></span></font></p>
style=3D'font-size:10.0pt;font-family:"Courier New"'>#<span
style=3D'mso-tab-count:2'>=A0=A0=A0=A0=A0=A0=A0=A0=A0=A0 =
</span>gd-1.2/gdfontl.obj =
gd-1.2/gdfontg.obj<o:p></o:p></span></font></p>
style=3D'font-size:10.0pt;font-family:"Courier New"'>#GD_INC=3D<span
style=3D'mso-tab-count:1'>=A0=A0=A0 =
</span>-I./gd-1.2<o:p></o:p></span></font></p>
style=3D'font-size:10.0pt;font-family:"Courier New"'>#GD_LIB=3D<span
</span>gd-1.2/gd.lib<o:p></o:p></span></font></p>
"Courier New";mso-ansi-language:EN-GB'>#GD=3D -DUSE_GD_GIF =
-DUSE_GD_SWAP_XY<o:p></o:p></span></font></p>
New"'>#MAKE_GD=3Dgd<o:p></o:p></span></font></p>
"Courier New";mso-ansi-language:EN-GB'># A patched version of GD that =
supports
GIF, JPEG, PNG and WBMP can be <o:p></o:p></span></font></p>
"Courier New";mso-ansi-language:EN-GB'># downloaded from
http://www.rime.com.au/gd/.<o:p></o:p></span></font></p>
"Courier New";mso-ansi-language:EN-GB'># The following defns will =
include the
patched GD 1.8.4 with TTF:<o:p></o:p></span></font></p>
New"'>GDFONT_OBJ=3D<o:p></o:p></span></font></p>
style=3D'font-size:10.0pt;font-family:"Courier New"'>GD_INC=3D<span
style=3D'mso-tab-count:1'>=A0=A0=A0=A0 =
</span>-I../gd-1.8.4<o:p></o:p></span></font></p>
style=3D'font-size:10.0pt;font-family:"Courier New"'>GD_LIB=3D<span
style=3D'mso-tab-count:1'>=A0=A0=A0=A0 </span>../gd-1.8.4/gd.lib =
style=3D'font-size:10.0pt;font-family:"Courier New"'><span
style=3D'mso-spacerun:yes'>=A0=A0=A0=A0=A0=A0=A0=A0 =
</span>../jpeg-6b/libjpeg.lib \<o:p></o:p></span></font></p>
</span>../lpng120/projects/msvc/win32/libpng/lib_dbg/libpng.lib =
style=3D'mso-tab-count:1'>=A0=A0=A0=A0=A0 </span></span></font><font =
size=3D2
style=3D'font-size:10.0pt;font-family:"Courier New";
mso-ansi-language:EN-GB'>../zlib/zlib.lib<span =
</span>../freetype-2.1.4/objs/freetype214ST_D.lib<o:p></o:p></span></font=
></p>
"Courier New";mso-ansi-language:EN-GB'>GD=3D<span =
</span>-DUSE_GD_GIF -DUSE_GD_PNG -DUSE_GD_JPEG -DUSE_GD_WBMP =
-DUSE_GD_TTF \<o:p></o:p></span></font></p>
"Courier New";mso-ansi-language:EN-GB'><span =
style=3D'mso-tab-count:1'>=A0=A0=A0=A0=A0 </span>-DUSE_GD_TTF
-DGD_HAS_GDIMAGEGIFPTR<o:p></o:p></span></font></p>
New"'>MAKE_GD=3Dgd<o:p></o:p></span></font></p>
style=3D'mso-spacerun:yes'>=A0=A0=A0=A0=A0=A0=A0 =
</span>../libpng-1.0.8/libpng.lib \<o:p></o:p></span></font></p>
style=3D'mso-tab-count:1'>=A0=A0=A0=A0 </span>../zlib/zlibstat.lib<span
</span>../freetype/lib/freetype.lib<o:p></o:p></span></font></p>
style=3D'font-size:10.0pt;font-family:"Courier New"'>#GD=3D
<span style=3D'mso-spacerun:yes'>=A0=A0=A0=A0</span>-DUSE_GD_GIF =
-DUSE_GD_PNG
-DUSE_GD_JPEG -DUSE_GD_WBMP -DUSE_GD_TTF \<o:p></o:p></span></font></p>
style=3D'mso-tab-count:1'>=A0=A0=A0=A0 </span>-DUSE_GD_TTF
"Courier =
New";mso-ansi-language:EN-GB'>#MAKE_GD=3Dgd<o:p></o:p></span></font></p>
"Courier =
"Courier New";mso-ansi-language:EN-GB'># TIFF distribution (raster =
support for
TIFF and GEOTIFF imagery).(RECOMMENDED)<o:p></o:p></span></font></p>
"Courier =
New";mso-ansi-language:EN-GB'>TIFF_INC=3D-I../tiff-v3.5.5/libtiff<o:p></o=
"Courier =
New";mso-ansi-language:EN-GB'>TIFF_LIB=3D../tiff-v3.5.5/libtiff/libtiff.l=
"Courier =
New";mso-ansi-language:EN-GB'>TIFF=3D-DUSE_TIFF<o:p></o:p></span></font><=
/p>
"Courier =
"Courier New";mso-ansi-language:EN-GB'># JPEG distribution (raster =
support for
grayscale JPEG images, INPUT ONLY).<o:p></o:p></span></font></p>
"Courier =
New";mso-ansi-language:EN-GB'>#JPEG_INC=3D<o:p></o:p></span></font></p>
"Courier =
New";mso-ansi-language:EN-GB'>#JPEG_LIB=3D-ljpeg<o:p></o:p></span></font>=
</p>
"Courier =
New";mso-ansi-language:EN-GB'>#JPEG=3D-DUSE_JPEG<o:p></o:p></span></font>=
</p>
"Courier =
"Courier New";mso-ansi-language:EN-GB'># EPPL7 Support (this activates =
ERDAS as
well) Included in the distribution. Probably the best raster alternative =
if<o:p></o:p></span></font></p>
"Courier New";mso-ansi-language:EN-GB'># you've got EPPL7 laying around. =
See
http://www.lmic.state.mn.us/ for more information. =
"Courier =
New";mso-ansi-language:EN-GB'>#EPPL=3D-DUSE_EPPL<o:p></o:p></span></font>=
</p>
"Courier =
New";mso-ansi-language:EN-GB'>#EPPL_OBJ=3Depplib.obj<o:p></o:p></span></f=
ont></p>
"Courier =
"Courier New";mso-ansi-language:EN-GB'># OGR Support OGC Simple Feature
inspired interface for vector<o:p></o:p></span></font></p>
"Courier New";mso-ansi-language:EN-GB'># formats.<span
style=3D'mso-spacerun:yes'>=A0 </span>See =
http://gdal.velocet.ca/projects/opengis/<o:p></o:p></span></font></p>
size=3D2 face=3D"Courier New"><span lang=3DIT =
"Courier New";mso-ansi-language:IT'>GDAL_DIR=3D =
..\gdal-1.1.8<o:p></o:p></span></font></p>
"Courier =
New";mso-ansi-language:IT'>OGR=3D-DUSE_OGR<o:p></o:p></span></font></p>
"Courier New";mso-ansi-language:IT'>OGR_LIB =3D<span =
</span>$(GDAL_DIR)/gdal.lib $(GDAL_DIR)/ogr/ogrsf_frmts/ogrsf_frmts.lib
$(GDAL_DIR)/ogr/../port/cpl.lib<o:p></o:p></span></font></p>
"Courier New";mso-ansi-language:IT'>OGR_INC =3D =
-I$(GDAL_DIR)/ogr -I$(GDAL_DIR)/ogr/../port =
-I$(GDAL_DIR)/core<o:p></o:p></span></font></p>
"Courier New";mso-ansi-language:IT'><o:p> </o:p></span></font></p>
New"'>#GDAL=3D-DUSE_GDAL<o:p></o:p></span></font></p>
"Courier New";mso-ansi-language:FR'># ESRI SDE =
support.<o:p></o:p></span></font></p>
"Courier New";mso-ansi-language:FR'>SDE_OPT=3D-DUSE_SDE =
-DWIN32<o:p></o:p></span></font></p>
"Courier New";mso-ansi-language:IT'>SDE_INC=3D -I ../arcsde/include -I
../arcsde/bin<o:p></o:p></span></font></p>
"Courier New";mso-ansi-language:IT'>SDE_LIB=3D../arcsde/lib/sde81.lib =
../arcsde/lib/pe81.lib<o:p></o:p></span></font></p>
"Courier New";mso-ansi-language:EN-GB'># UofMN GIS/Image Processing =
Extension
(very experimental)<o:p></o:p></span></font></p>
New"'>#EGIS=3D-DUSE_EGIS<o:p></o:p></span></font></p>
New"'>#ERR_OBJ=3D./errLog/errLog.o<o:p></o:p></span></font></p>
New"'>#ERR_INC=3D-I./errLog<o:p></o:p></span></font></p>
New"'>#ERR_LIB=3D-L./errLog
-lerrLog<o:p></o:p></span></font></p>
New"'>#IMGGEN_OBJ=3D./imgSrc/imgLib.o<o:p></o:p></span></font></p>
New"'>#IMGGEN_INC=3D-I./imgSrc<o:p></o:p></span></font></p>
New"'>#IMGGEN_LIB=3D-L./imgSrc
-limgGEN<o:p></o:p></span></font></p>
style=3D'font-size:10.0pt;font-family:"Courier New"'>#ECWDIR=3D
C:\ProgFile\ECW_SDK<o:p></o:p></span></font></p>
New"'>#ECW_LIB=3D$(ECWDIR)\lib\NCSEcw.lib
$(ECWDIR)\lib\NCSEcwC.lib \<o:p></o:p></span></font></p>
</span>$(ECWDIR)\lib\NCSUtil.lib<o:p></o:p></span></font></p>
"Courier New";mso-ansi-language:EN-GB'># VC++ does not include the REGEX
library... so we must provide our one.<o:p></o:p></span></font></p>
"Courier New";mso-ansi-language:EN-GB'># The following definitions will =
try to
build GNU regex-0.12 located in the<o:p></o:p></span></font></p>
"Courier New";mso-ansi-language:EN-GB'># regex-0.12 =
sub-directory.<o:p></o:p></span></font></p>
"Courier New";mso-ansi-language:EN-GB'># If it was not included in the =
source
distribution, then you can get it from:<o:p></o:p></span></font></p>
</span>ftp://ftp.gnu.org/pub/gnu/regex/regex-0.12.tar.gz<o:p></o:p></span=
></font></p>
"Courier =
New";mso-ansi-language:EN-GB'>#REGEX_OBJ=3D..\regex-0.12\regex.obj<o:p></=
"Courier New";mso-ansi-language:EN-GB'>#REGEX_INC=3D-I =
..\regex-0.12<o:p></o:p></span></font></p>
"Courier =
"Courier New";mso-ansi-language:EN-GB'># IMPORTANT NOTE ABOUT REGEX FOR
PHP_MAPSCRIPT USERS:<o:p></o:p></span></font></p>
"Courier New";mso-ansi-language:EN-GB'># If you want to compile the
PHP_MAPSCRIPT module, then you have to make<o:p></o:p></span></font></p>
"Courier New";mso-ansi-language:EN-GB'># MapServer uses the same version =
of the
REGEX library that PHP was <o:p></o:p></span></font></p>
"Courier New";mso-ansi-language:EN-GB'># compiled =
with:<o:p></o:p></span></font></p>
"Courier =
New";mso-ansi-language:EN-GB'>PHP_REGEX=3D..\php-4.3.1\regex<o:p></o:p></=
span></font></p>
"Courier =
New";mso-ansi-language:EN-GB'>#PHP_REGEX=3D..\php-3.0.14\regex<o:p></o:p>=
</span></font></p>
"Courier =
New";mso-ansi-language:EN-GB'>#PHP_REGEX=3D..\php-4.0.6\regex<o:p></o:p><=
/span></font></p>
"Courier =
New";mso-ansi-language:EN-GB'>#PHP_REGEX=3D..\php-4.1.2\regex<o:p></o:p><=
/span></font></p>
"Courier =
New";mso-ansi-language:EN-GB'>#PHP_REGEX=3D..\php-4.2.1\regex<o:p></o:p><=
/span></font></p>
New"'>#PHP_REGEX=3D..\php-4.2.2\regex<o:p></o:p></span></font></p>
New"'>REGEX_OBJ=3D$(PHP_REGEX)\regcomp.obj
$(PHP_REGEX)\regerror.obj \<o:p></o:p></span></font></p>
style=3D'mso-spacerun:yes'>=A0 </span><span
style=3D'mso-spacerun:yes'>=A0=A0=A0=A0=A0=A0=A0=A0</span>$(PHP_REGEX)\re=
gexec.obj
$(PHP_REGEX)\regfree.obj<o:p></o:p></span></font></p>
"Courier New";mso-ansi-language:EN-GB'>REGEX_INC=3D-I$(PHP_REGEX)
-DPHP_NO_ALIASES<o:p></o:p></span></font></p>
"Courier =
"Courier New";mso-ansi-language:EN-GB'># REGEX needs some special =
flags... here
they are for VC++ 6.0<o:p></o:p></span></font></p>
"Courier New";mso-ansi-language:EN-GB'>#REGEX_OPT=3D-DHAVE_STRING_H
-DREGEX_MALLOC<o:p></o:p></span></font></p>
"Courier =
"Courier New";mso-ansi-language:EN-GB'># --- You shouldn't have to edit
anything else. ---<o:p></o:p></span></font></p>
"Courier =
"Courier New";mso-ansi-language:EN-GB'># Main MapServer =
library.<o:p></o:p></span></font></p>
"Courier New";mso-ansi-language:EN-GB'>MS_LIB<span =
</span>=3D<span style=3D'mso-tab-count:1'>=A0=A0 =
</span>mapserver.lib<o:p></o:p></span></font></p>
"Courier New";mso-ansi-language:EN-GB'>MS_OBJS =3D <span =
1'>=A0 </span>mapbits.obj maphash.obj mapshape.obj mapxbase.obj =
style=3D'mso-tab-count:2'>=A0=A0=A0=A0=A0=A0=A0=A0=A0=A0=A0 =
</span>mapparser.obj
maplexer.obj mapindex.obj maptree.obj \<o:p></o:p></span></font></p>
</span>mapsearch.obj
mapstring.obj mapsymbol.obj mapfile.obj \<o:p></o:p></span></font></p>
</span>maplegend.obj
maputil.obj mapscale.obj mapquery.obj \<o:p></o:p></span></font></p>
</span>maplabel.obj
maperror.obj mapprimitive.obj =
mapproject.obj\<o:p></o:p></span></font></p>
</span>mapraster.obj
cgiutil.obj mapsde.obj mapogr.obj \<o:p></o:p></span></font></p>
</span><span style=3D'mso-tab-count:1'>=A0=A0=A0 </span>maptemplate.obj =
mappostgis.obj
maplayer.obj mapresample.obj \<o:p></o:p></span></font></p>
</span><span style=3D'mso-tab-count:1'>=A0=A0=A0 </span>mapwms.obj =
mapwmslayer.obj
mapgml.obj maporaclespatial.obj \<o:p></o:p></span></font></p>
</span><span style=3D'mso-tab-count:1'>=A0=A0=A0 </span>mapprojhack.obj =
</span>$(EPPL_OBJ)
$(REGEX_OBJ)<o:p></o:p></span></font></p>
"Courier =
"Courier New";mso-ansi-language:EN-GB'>MS_HDRS =3D <span =
1'>=A0 </span>map.h mapfile.h<o:p></o:p></span></font></p>
"Courier =
"Courier New";mso-ansi-language:EN-GB'>MS_EXE =3D <span =
1'>=A0=A0 </span>mapserv.exe \<o:p></o:p></span></font></p>
style=3D'mso-spacerun:yes'>=A0=A0=A0=A0=A0=A0=A0=A0=A0=A0=A0=A0=A0=A0=A0 =
</span>shp2img.exe legend.exe<span
style=3D'mso-spacerun:yes'>=A0 </span>\<o:p></o:p></span></font></p>
</span>shptree.exe
scalebar.exe sortshp.exe tile4ms.exe<o:p></o:p></span></font></p>
"Courier =
"Courier New";mso-ansi-language:EN-GB'>LIBS<span =
style=3D'mso-tab-count:1'>=A0 </span>=3D<span
style=3D'mso-tab-count:1'>=A0=A0=A0=A0 </span>$(MS_LIB) $(GD_LIB) =
</span>$(PROJ_LIB)
$(ERR_LIB) $(IMGGEN_LIB) $(OGR_LIB) \<o:p></o:p></span></font></p>
style=3D'mso-tab-count:1'>=A0=A0=A0=A0=A0 </span><span
style=3D'mso-spacerun:yes'>=A0=A0=A0=A0=A0 </span>$(WWWLIB_LIB) =
$(ECW_LIB) $(SDE_LIB) <o:p></o:p></span></font></p>
"Courier =
"Courier New";mso-ansi-language:EN-GB'>INCLUDES =3D<span =
1'>=A0 </span>$(GD_INC) $(TIFF_INC) $(JPEG_INC) =
</span>$(PROJ_INC)
$(ERR_INC) $(IMGGEN_INC) $(REGEX_INC) $(OGR_INC) =
style=3D'mso-spacerun:yes'>=A0=A0=A0=A0=A0=A0=A0=A0=A0=A0=A0 =
</span>$(WWWLIB_INC) $(SDE_INC)<o:p></o:p></span></font></p>
"Courier =
"Courier New";mso-ansi-language:EN-GB'>CFLAGS =3D<span =
style=3D'mso-tab-count:1'>=A0=A0=A0 </span>$(BASE_CFLAGS)
$(INCLUDES) $(REGEX_OPT) $(STRINGS) \<o:p></o:p></span></font></p>
</span>$(EPPL)
$(PROJ) $(TIFF) $(JPEG) $(GD) $(OGR) $(WMS) $(WMSCLIENT) =
</span>$(IGNORE_MISSING_DATA) $(GDAL)
-DFEATURE_INFO_HTML $(SDE_OPT)<o:p></o:p></span></font></p>
"Courier =
style=3D'mso-tab-count:2'>=A0=A0=A0=A0=A0=A0=A0=A0=A0=A0 </span>$(EPPL)
-DFEATURE_INFO_HTML<o:p></o:p></span></font></p>
"Courier =
"Courier New";mso-ansi-language:EN-GB'>default: <span =
1'>=A0=A0 </span>all<o:p></o:p></span></font></p>
"Courier =
"Courier New";mso-ansi-language:EN-GB'>all:<span =
style=3D'mso-tab-count:2'>=A0=A0=A0=A0=A0=A0=A0 </span>$(MS_LIB)
$(MS_EXE)<o:p></o:p></span></font></p>
"Courier =
"Courier New";mso-ansi-language:EN-GB'>$(MS_OBJS):<span =
1'> </span>$(MS_HDRS)<o:p></o:p></span></font></p>
"Courier =
"Courier New";mso-ansi-language:EN-GB'>$(MS_LIB):<span =
1'>=A0 </span>$(MS_OBJS)<o:p></o:p></span></font></p>
style=3D'mso-tab-count:1'>=A0=A0=A0=A0=A0 </span>copy
$(GDAL_DIR)\gdal11.pdb .<o:p></o:p></span></font></p>
style=3D'mso-tab-count:1'>=A0=A0=A0=A0=A0 </span>lib
/out:$(MS_LIB) $(MS_OBJS)<o:p></o:p></span></font></p>
"Courier =
"Courier New";mso-ansi-language:EN-GB'>$(MS_EXE):<span =
1'>=A0 </span>$(LIBS)<o:p></o:p></span></font></p>
"Courier =
"Courier New";mso-ansi-language:EN-GB'>gd::<o:p></o:p></span></font></p>
style=3D'mso-tab-count:1'>=A0=A0=A0=A0=A0 </span>cd
style=3D'mso-tab-count:1'>=A0=A0=A0=A0=A0 </span>nmake
/f makefile.nt gd.lib =
OPTFLAGS=3D"$(OPTFLAGS)"<o:p></o:p></span></font></p>
"Courier =
"Courier New";mso-ansi-language:EN-GB'>.c.obj:<span =
style=3D'mso-tab-count:1'>=A0=A0=A0=A0=A0 </span>$(CC)
$(CFLAGS) /c $*.c /Fo$*.obj<o:p></o:p></span></font></p>
"Courier =
"Courier New";mso-ansi-language:EN-GB'>.cpp.obj:<span =
1'>=A0=A0 </span><o:p></o:p></span></font></p>
$(CFLAGS) /c $*.cpp /Fo$*.obj<o:p></o:p></span></font></p>
"Courier =
"Courier =
New";mso-ansi-language:EN-GB'>.c.exe:<o:p></o:p></span></font></p>
style=3D'mso-tab-count:1'>=A0=A0=A0=A0=A0 </span>$(LINK)
$(LDFLAGS) $*.obj $(LIBS)<o:p></o:p></span></font></p>
"Courier =
"Courier =
New";mso-ansi-language:EN-GB'>.cpp.exe:<o:p></o:p></span></font></p>
"Courier =
"Courier =
"Courier =
New";mso-ansi-language:EN-GB'>clean:<o:p></o:p></span></font></p>
"Courier New";mso-ansi-language:IT'>del =
"Courier New";mso-ansi-language:IT'><span =
style=3D'mso-tab-count:1'>=A0=A0=A0=A0=A0 </span>del
$(MS_LIB)<o:p></o:p></span></font></p>
*.pdb<o:p></o:p></span></font></p>
*.exp<o:p></o:p></span></font></p>
*.ilk<o:p></o:p></span></font></p>
style=3D'mso-tab-count:1'>=A0=A0=A0=A0 </span>cd
style=3D'mso-tab-count:1'>=A0=A0=A0=A0 </span>nmake
-f makefile.nt clean<o:p></o:p></span></font></p>
<p class=3DMsoNormal><font size=3D2 face=3D"Courier New"><span =
lang=3DEN-GB
style=3D'mso-tab-count:1'>=A0=A0=A0=A0 </span>cd ..</span></font><font =
lang=3DEN-GB =
style=3D'font-size:10.0pt;font-family:Arial;mso-ansi-language:EN-GB'><o:p=
style=3D'font-size:
></font></p>
style=3D'font-size:
></font></p>
style=3D'font-size:
></font></p>
style=3D'font-size:
10.0pt;font-family:Arial;mso-ansi-language:EN-GB'>my mapfile =
style=3D'font-size:
></font></p>
style=3D'font-size:
></font></p>
font-family:Arial'><span style=3D'mso-spacerun:yes'>=A0=A0=A0=A0=A0 =
</span>MAP<o:p></o:p></span></font></p>
font-family:Arial'><span style=3D'mso-spacerun:yes'>=A0 </span>NAME
"Bremen"<o:p></o:p></span></font></p>
font-family:Arial'><span style=3D'mso-spacerun:yes'>=A0 </span>STATUS =
ON<o:p></o:p></span></font></p>
font-family:Arial'><span style=3D'mso-spacerun:yes'>=A0 </span>EXTENT =
3.46e+006
5.87198e+006 3.50161e+006 5.90314e+006 <o:p></o:p></span></font></p>
font-family:Arial'><span style=3D'mso-spacerun:yes'>=A0 =
mso-ansi-language:EN-GB'>SIZE 400 300 <o:p></o:p></span></font></p>
style=3D'font-size:
10.0pt;font-family:Arial;mso-ansi-language:EN-GB'><span
style=3D'mso-spacerun:yes'>=A0 </span>IMAGECOLOR 255 255 =
255<o:p></o:p></span></font></p>
style=3D'font-size:
style=3D'mso-spacerun:yes'>=A0 </span>TRANSPARENT =
OFF<o:p></o:p></span></font></p>
style=3D'font-size:
style=3D'mso-spacerun:yes'>=A0 </span>UNITS =
METERS<o:p></o:p></span></font></p>
style=3D'font-size:
style=3D'mso-spacerun:yes'>=A0 </span>INTERLACE =
style=3D'font-size:
style=3D'mso-spacerun:yes'>=A0 </span>IMAGETYPE =
PNG<o:p></o:p></span></font></p>
style=3D'font-size:
style=3D'mso-spacerun:yes'>=A0 </span>IMAGEQUALITY =
75<o:p></o:p></span></font></p>
style=3D'font-size:
style=3D'mso-spacerun:yes'>=A0 </span>WEB<o:p></o:p></span></font></p>
style=3D'font-size:
style=3D'mso-spacerun:yes'>=A0=A0=A0 </span>MINSCALE =
20000<o:p></o:p></span></font></p>
style=3D'font-size:
style=3D'mso-spacerun:yes'>=A0=A0=A0 </span>MAXSCALE =
5e+007<o:p></o:p></span></font></p>
style=3D'font-size:
style=3D'mso-spacerun:yes'>=A0=A0=A0 </span>IMAGEPATH =
"c:/windows/temp/"<o:p></o:p></span></font></p>
style=3D'font-size:
style=3D'mso-spacerun:yes'>=A0=A0=A0 </span>IMAGEURL =
"/ms_tmp/"<o:p></o:p></span></font></p>
style=3D'font-size:
style=3D'mso-spacerun:yes'>=A0 </span>END<o:p></o:p></span></font></p>
style=3D'font-size:
</span>QUERYMAP<o:p></o:p></span></font></p>
style=3D'font-size:
style=3D'mso-spacerun:yes'>=A0=A0=A0 </span>STATUS =
style=3D'font-size:
style=3D'mso-spacerun:yes'>=A0=A0=A0 </span>SIZE -1 -1 =
style=3D'font-size:
style=3D'mso-spacerun:yes'>=A0=A0=A0 </span>COLOR 255 255 =
style=3D'font-size:
style=3D'mso-spacerun:yes'>=A0=A0=A0 </span>STYLE =
HILITE<o:p></o:p></span></font></p>
style=3D'font-size:
style=3D'font-size:
</span>LEGEND<o:p></o:p></span></font></p>
style=3D'font-size:
style=3D'font-size:
style=3D'mso-spacerun:yes'>=A0=A0=A0 </span>IMAGECOLOR 255 255 =
style=3D'font-size:
style=3D'mso-spacerun:yes'>=A0=A0=A0 </span>TRANSPARENT =
FALSE<o:p></o:p></span></font></p>
style=3D'font-size:
style=3D'mso-spacerun:yes'>=A0=A0=A0 </span>INTERLACE =
TRUE<o:p></o:p></span></font></p>
style=3D'font-size:
style=3D'mso-spacerun:yes'>=A0=A0=A0 </span>POSITION =
LL<o:p></o:p></span></font></p>
style=3D'font-size:
style=3D'mso-spacerun:yes'>=A0=A0=A0 </span>KEYSIZE 20 10 =
style=3D'font-size:
style=3D'mso-spacerun:yes'>=A0=A0=A0 </span>KEYSPACING 5 5 =
style=3D'font-size:
style=3D'mso-spacerun:yes'>=A0=A0=A0 </span>TEMPLATE =
Group/Apache2/htdocs/maplab-2.0rc5/htdocs/mapbrowser/legend_template.html=
style=3D'font-size:
style=3D'mso-spacerun:yes'>=A0=A0=A0 =
</span>LABEL<o:p></o:p></span></font></p>
style=3D'font-size:
style=3D'mso-spacerun:yes'>=A0=A0=A0=A0=A0 </span>TYPE =
BITMAP<o:p></o:p></span></font></p>
style=3D'font-size:
style=3D'mso-spacerun:yes'>=A0=A0=A0=A0=A0 </span>SIZE =
MEDIUM<o:p></o:p></span></font></p>
style=3D'font-size:
style=3D'mso-spacerun:yes'>=A0=A0=A0=A0=A0 </span>OFFSET 0 0 =
style=3D'font-size:
style=3D'mso-spacerun:yes'>=A0=A0=A0=A0=A0 </span>BUFFER =
style=3D'font-size:
style=3D'mso-spacerun:yes'>=A0=A0=A0=A0=A0 </span>MINDISTANCE =
-1<o:p></o:p></span></font></p>
style=3D'font-size:
style=3D'mso-spacerun:yes'>=A0=A0=A0=A0=A0 </span>MINFEATURESIZE =
style=3D'font-size:
style=3D'mso-spacerun:yes'>=A0=A0=A0=A0=A0 </span>COLOR 255 255 =
style=3D'font-size:
style=3D'mso-spacerun:yes'>=A0=A0=A0=A0=A0 </span>PARTIALS =
style=3D'font-size:
style=3D'mso-spacerun:yes'>=A0=A0=A0=A0=A0 </span>FORCE =
style=3D'font-size:
style=3D'font-size:
style=3D'font-size:
</span>SCALEBAR<o:p></o:p></span></font></p>
style=3D'font-size:
style=3D'font-size:
style=3D'font-size:
style=3D'mso-spacerun:yes'>=A0=A0=A0 </span>OUTLINECOLOR 0 0 =
style=3D'font-size:
style=3D'mso-spacerun:yes'>=A0=A0=A0 </span>BACKGROUNDCOLOR 0 0 =
style=3D'font-size:
style=3D'font-size:
style=3D'font-size:
style=3D'mso-spacerun:yes'>=A0=A0=A0 </span>UNITS =
KILOMETERS<o:p></o:p></span></font></p>
style=3D'font-size:
style=3D'mso-spacerun:yes'>=A0=A0=A0 </span>INTERVALS =
style=3D'font-size:
style=3D'mso-spacerun:yes'>=A0=A0=A0 </span>SIZE 150 5 =
style=3D'font-size:
style=3D'font-size:
style=3D'font-size:
style=3D'font-size:
style=3D'font-size:
style=3D'font-size:
SMALL<o:p></o:p></span></font></p>
style=3D'font-size:
style=3D'font-size:
style=3D'font-size:
style=3D'font-size:
style=3D'font-size:
style=3D'mso-spacerun:yes'>=A0=A0=A0=A0=A0 </span>COLOR 0 0 =
style=3D'font-size:
style=3D'font-size:
style=3D'font-size:
style=3D'font-size:
style=3D'font-size:
style=3D'mso-spacerun:yes'>=A0 </span>LAYER<o:p></o:p></span></font></p>
style=3D'font-size:
style=3D'mso-spacerun:yes'>=A0=A0=A0 </span>NAME =
"Verwaltung"<o:p></o:p></span></font></p>
style=3D'font-size:
style=3D'font-size:
style=3D'mso-spacerun:yes'>=A0=A0=A0 </span>DATA =
"BREMEN_STADTTEILE,shape"<o:p></o:p></span></font></p>
style=3D'font-size:
style=3D'mso-spacerun:yes'>=A0=A0=A0 </span>TYPE =
POLYGON<o:p></o:p></span></font></p>
style=3D'font-size:
style=3D'mso-spacerun:yes'>=A0=A0=A0 </span>CONNECTIONTYPE =
SDE<o:p></o:p></span></font></p>
style=3D'font-size:
"kbs2,esri_sde,sde,sde,EsgibtReis"<o:p></o:p></span></font></p>=
style=3D'font-size:
style=3D'font-size:
style=3D'mso-spacerun:yes'>=A0=A0=A0 </span>SIZEUNITS =
PIXELS<o:p></o:p></span></font></p>
style=3D'font-size:
style=3D'mso-spacerun:yes'>=A0=A0=A0 </span>TOLERANCE =
3<o:p></o:p></span></font></p>
style=3D'font-size:
style=3D'mso-spacerun:yes'>=A0=A0=A0 </span></span></font><font size=3D2 =
face=3DArial><span
lang=3DFR =
style=3D'font-size:10.0pt;font-family:Arial;mso-ansi-language:FR'>TOLERAN=
CEUNITS
<p class=3DMsoNormal><font size=3D2 face=3DArial><span lang=3DFR =
font-family:Arial;mso-ansi-language:FR'><span =
</span>TEMPLATE "ttt.html"<o:p></o:p></span></font></p>
</span></span></font><font size=3D2 face=3DArial><span =
font-family:Arial'>CLASS<o:p></o:p></span></font></p>
</span>NAME
"Verwaltungseinheiten"<o:p></o:p></span></font></p>
</span>SYMBOL 0<o:p></o:p></span></font></p>
</span>COLOR 90 200 90<o:p></o:p></span></font></p>
mso-ansi-language:EN-GB'>SIZE 1<o:p></o:p></span></font></p>
style=3D'font-size:
style=3D'mso-spacerun:yes'>=A0=A0=A0=A0=A0 </span>MINSIZE =
style=3D'font-size:
style=3D'mso-spacerun:yes'>=A0=A0=A0=A0=A0 </span>MAXSIZE =
100<o:p></o:p></span></font></p>
style=3D'font-size:
style=3D'font-size:
style=3D'font-size:
10.0pt;font-family:Arial;mso-ansi-language:EN-GB'>END<o:p></o:p></span></=
font></p>
</div>
</body>
</html>
------=_NextPart_000_0001_01C313E4.4A6C5230--
