[Mapserver-users] RE: failed dependencies: libgd.so.1.8
Hatcher Matthew
MJHATCHER at qinetiq.com
Mon May 12 05:08:48 EDT 2003
Gerald,
Yes, you need to make a soft link from libgd.so.1.8.3 to libgd.so.1.8, as
this is the dependency that rpm cannot find.
That should solve your problems. Failing that, check that your library paths
are setup correctly to find the so objects.
Matt.
Message: 3
Reply-To: gbuckmaster at cox.net
Organization: Imagery Analysis Support Group
To: mapserver-users at lists.gis.umn.edu
Date: Fri, 9 May 2003 13:08:05 -0700
Subject: [Mapserver-users] (ALOT) failed dependencies: libgd.so.1.8
Greetings,
I know I should be retaining source code for all these applications and
libraries, but I have a hard enough time just retaining my sanity ;^)
The packages below are from the latest FreeGIS ISO. As you can see
from my attempts the MapServer and GRASS packages cannot find the
libgd library, even though it is already installed.
[root at ventanavista i386]# rpm --install gd-1.8.3-1.i386.rpm
package gd-1.8.3-1 is already installed
[root at ventanavista i386]# rpm --install grass-5.0.0-1.i386.rpm
error: failed dependencies:
libgd.so.1.8 is needed by grass-5.0.0-1
[root at ventanavista i386]# rpm --install mapserver-3.6.1-1.i386.rpm
libgd.so.1.8 is needed by mapserver-3.6.1-1
Here is where the libgd libraries reside:
lrwxrwxrwx 1 root root 14 May 5 23:24 libgd.so ->
libgd.so.2.0.0*
lrwxrwxrwx 1 root root 14 May 9 12:07 libgd.so.1 ->
libgd.so.1.8.3*
-rwxr-xr-x 1 root root 189116 Apr 19 2001 libgd.so.1.8.3*
lrwxrwxrwx 1 root root 14 May 5 00:43 libgd.so.2 ->
libgd.so.2.0.0*
-rwxr-xr-x 1 root root 211504 Feb 3 04:58 libgd.so.2.0.0*
Do I need to create a softlink to libgd.so.1.8.3?
Any ideas?
Gerald Buckmaster
The Information contained in this E-Mail and any subsequent correspondence
is private and is intended solely for the intended recipient(s).
For those other than the recipient any disclosure, copying, distribution,
or any action taken or omitted to be taken in reliance on such information
is prohibited and may be unlawful.
Emails and other electronic communication with QinetiQ may be monitored.
Calls to our Customer Contact Centre may be recorded for quality control,
regulatory and monitoring purposes.
