[Mapserver-users] Building gdal with Xerces
Benjamin Thelen CCGIS
benjamin.thelen at ccgis.de
Thu May 15 04:50:42 PDT 2003
I suppose, this is a question especially to Frank! Sorry to bother you
again!
Basic system config concerning this thread:
freebsd 4.7
gdal 1.1.8
mapserver 3.6.5
We tried the following:
benjamin at qwertzuiop> ogrinfo rat_wald.gml
ERROR 1: Unable to create Xerces C++ based GML reader, Xerces support
not configured into GDAL/OGR.
ERROR 1: File rat_wald.gml appears to be GML but the GML reader can't
be instantiated, likely because Xerces support wasn't
configured in.
FAILURE:
Unable to open datasource `rat_wald.gml' with the following drivers.
-> ESRI Shapefile
-> UK .NTF
-> SDTS
-> TIGER
-> IHO S-57 (ENC)
-> MapInfo File
-> DGN
-> GML
-> AVCBin
-> PostgreSQL
I now have two questions:
1. I couldn't find out, which version of Xerces I should install. That seems
to be quite important, as there have been some important changes from 1.7.0
to 2.1.0_1 ( I know 2.1.0 is not the latest, but it is the latest within the
FreeBSD Ports Collection :-) Sorry to blame you with that bloody Ports
Collection again :-)).
2. Then I found out that gdal (1.1.8) has to be compiled with Xerces. Well,
there are three options I have to specify:
--with-xerces
--with-xerces-in=dir
--with-xerces-lib=opts
I tried the following (yes that is directly from source code, not using the
ports system, that will be the next step)
./configure
--with-xerces
--with-xerces-inc=/usr/local
--with-xerces-lib="-L/usr/local/lib -lxerces-c2.1.0 -lpthread" *
*this is from the example ./configure --help, I've changed the version
number.
That's the output:
checking for Xerces C++... requested, but compile or link fails!
c++ -I/usr/local -I/usr/local/include -o conftest
conftest.cpp -L/usr/local/lib -lxerces-c2_1_0 -lpthread -lpng -lz -lm -L/usr
/local/lib
conftest.cpp:1: util/PlatformUtils.hpp: No such file or directory
configure: error: Please correct Xerces options, or don't enable Xerces.
What do I have to specify for gdal & xerces and which version of xerces do I
have to install?
Thanks,
Benjamin
More information about the MapServer-users
