[Mapserver-users] [Mapserver-dev] Template file and Mime type
Harald Wehr
hwehr at hs-harz.de
Fri May 16 01:41:30 EDT 2003
I sent this mail to developer list but got no answer. So I try it in
this list. Sorry for the cross-posting:
We are calling the mapserver cgi script from our java programs. We don't
use the java mapscript part because of some threading problems already
discussed on the mailing lists.
As template an XML file is used. This works quite well, as mapserver
does not care about the contents or extension of the file. It only fills
the results between the brackets [].
When mapserver sends this template back as response it adds a HTML mime
type and the version info to this response.
As we are expecting XML the mime type is not correct. The stream does
not begin with "<?xml version="1.0"?> like in the template file.
Would it make sense to provide another cgi parameter which sets the
expected mime type?
As there is already a [version] field in the template reference why does
mapserver prints this information always at the beginning of the response?
Thanks for your answers
Harald
