[Mapserver-users] Building gdal with Xerces
Benjamin Thelen CCGIS
benjamin.thelen at ccgis.de
Fri May 16 13:28:26 EDT 2003
That means 1.7.0 won't run? Do you think, that xerces 1.6.0 would
automatically be recognized by gdal at installation time of gdal? Otherwise
I would have to find out what to specify for --with-xerces-in=dir
and --with-xerces-lib=opts. Especiall the last one is a miracle to me.
Thanks,
Ben
> -----Original Message-----
> From: Paul Spencer [mailto:pagameba at magma.ca]
> Sent: Thursday, May 15, 2003 2:41 PM
> To: Benjamin Thelen (CCGIS)
> Cc: mapserver-users at lists.gis.umn.edu
> Subject: Re: [Mapserver-users] Building gdal with Xerces
> You need xerces 1.6.0 unless Frank has updated it recently.
> Cheers,
> Paul
> Benjamin Thelen (CCGIS) wrote:
> > Hi,
> > I suppose, this is a question especially to Frank! Sorry to bother you
> > again!
> > Basic system config concerning this thread:
> > freebsd 4.7
> > gdal 1.1.8
> > mapserver 3.6.5
> > We tried the following:
> > benjamin at qwertzuiop> ogrinfo rat_wald.gml
> > ERROR 1: Unable to create Xerces C++ based GML reader, Xerces support
> > not configured into GDAL/OGR.
> > ERROR 1: File rat_wald.gml appears to be GML but the GML reader can't
> > be instantiated, likely because Xerces support wasn't
> > configured in.
> > FAILURE:
> > Unable to open datasource `rat_wald.gml' with the following drivers.
> > -> ESRI Shapefile
> > -> UK .NTF
> > -> SDTS
> > -> TIGER
> > -> IHO S-57 (ENC)
> > -> MapInfo File
> > -> DGN
> > -> GML
> > -> AVCBin
> > -> PostgreSQL
> > I now have two questions:
> > 1. I couldn't find out, which version of Xerces I should
> install. That seems
> > to be quite important, as there have been some important
> changes from 1.7.0
> > to 2.1.0_1 ( I know 2.1.0 is not the latest, but it is the
> latest within the
> > FreeBSD Ports Collection :-) Sorry to blame you with that bloody Ports
> > Collection again :-)).
> > 2. Then I found out that gdal (1.1.8) has to be compiled with
> Xerces. Well,
> > there are three options I have to specify:
> > --with-xerces
> > I tried the following (yes that is directly from source code,
> not using the
> > ports system, that will be the next step)
> > ./configure
> > --with-xerces
> > --with-xerces-inc=/usr/local
> > --with-xerces-lib="-L/usr/local/lib -lxerces-c2.1.0 -lpthread" *
> > *this is from the example ./configure --help, I've changed the version
> > number.
> > That's the output:
> > checking for Xerces C++... requested, but compile or link fails!
> > c++ -I/usr/local -I/usr/local/include -o conftest
> > conftest.cpp -L/usr/local/lib -lxerces-c2_1_0 -lpthread -lpng
> -lz -lm -L/usr
> > /local/lib
> > conftest.cpp:1: util/PlatformUtils.hpp: No such file or directory
> > configure: error: Please correct Xerces options, or don't enable Xerces.
> > What do I have to specify for gdal & xerces and which version
> of xerces do I
> > have to install?
> > Thanks,
> > Benjamin
> > Mapserver-users mailing list
> > Mapserver-users at lists.gis.umn.edu
> > http://lists.gis.umn.edu/mailman/listinfo/mapserver-users
> Paul Spencer
> Applications and Software Development
> DM Solutions Group Inc.
> http://www.dmsolutions.ca
