AW: AW: [Mapserver-users] Map file
Arnulf Christl CCGIS
arnulf.christl at ccgis.de
Mon May 19 03:25:52 EDT 2003
the Mapbender client we use here supports user management. If you don't
start with a correct users' ID you are not allowed to continue - even if it
is only a guest-ID. What we should do is make this transparent to the user
in the form of error messages, if the user is not correctly logged in.
If you start clicking the link "Overlay WMS" which we posted (starting from
http://wms.ccgis.de) you should not have any problems having a look at the
demos. If it does not work we would appreciate commments - maybe it has to
do with language settings or something else we missed until now?!.
Cheers, Arnulf.
-----Ursprüngliche Nachricht-----
Von: mapserver-users-admin at lists.gis.umn.edu
[mailto:mapserver-users-admin at lists.gis.umn.edu]Im Auftrag von
woodbri at swoodbridge.com
Gesendet: Samstag, 17. Mai 2003 15:04
An: Marco Ferrari; mapserver-users at lists.gis.umn.edu; Arnulf Christl
CCCGIS"
Betreff: Re: AW: [Mapserver-users] Map file
Hi all,
I tried the http://wms.ccgis.de link but in IE6 I get errors like the
following on all of your links to maps.
ie: http://wms.ccgis.de/ccgis_client/dhtml/map.php?
Line: 1219, Char: 75, Error: Unterminated string constant
and no map displays. And if I mouse over the your tools bar or the
the legend text I get:
Line: 14, Char: 1, Error: Object doesn't support this property or
method, Code: 0
On 16 May 2003 at 14:12, Arnulf Christl (CCGIS) wrote:
> Hi,
> (here come the OGC disciples again...) If you use WMS (OGC Web Map
> Service) you can load several "layers" and overlay them in a client.
> Each map "layer" then represents one WMS. One WMS Server can contain
> several layers itself. An interesting feature here is that you can
> load different vendor's WMS together and overlay them in the same
> client.
> You can have a look at a demo on our server:
> Open the project "Germany", it is an UMN MapServer project hosted as
> WMS Open the project "BRD Administrativ", it is a SICAD/SD-IMS hosted
> as WMS Open the project "Overlay WMS" It contains both of the above
> projects together. You will see that the MapServer ist faster ;-) and
> will appear first in the client. A second or two later the other
> "layer" (or rather WMS Server) "BRD Administrativ" will be painted "on
> top" by the SICAD/SD-IMS WMS.
> To overlay the projects you have to load two Capabilities documents
> into your client. They are returned by your MapServer when it is WMS
> enabled (http://mapserver.gis.umn.edu/doc36/wms-server-howto.html) and
> you call an URL similar to this one here:
> http://wms.ccgis.de/umn/bin/mapserv.exe?map=germany.map&request=capabi
> lities&wmtver=1.0.0
> Regards, Arnulf.
> [mailto:mapserver-users-admin at lists.gis.umn.edu]Im Auftrag von Marco
> Ferrari Gesendet: Freitag, 16. Mai 2003 12:27 An:
> mapserver-users at lists.gis.umn.edu Betreff: [Mapserver-users] Map file
> Hi,
> Is it possible to display more than map files in the same browser
> window? I am using a map file with many layers and so I thought to use
> more than map files. According to you, is correct? Thanks.
> Mapserver-users mailing list
> Mapserver-users at lists.gis.umn.edu
> http://lists.gis.umn.edu/mailman/listinfo/mapserver-users
