[Mapserver-users] Please Help me
aborruso at spaziogis.it
Mon May 19 12:49:29 EDT 2003
Dear Vincent,
probably I'm not able to explain properly my problem. I know either the
path or name of your mapfile is invalid, or mapserver does not have access
to it. That file does not exist.
My real problem is that I'm not able to see in my browser an error like
that I can see in my dos console ("msLoadMap(): Unable to access
file.(/var/mapserver/mapfiles/province2.map)".
I read in my browser an "obscure" error: "CGI Error The specified CGI
application misbehaved by not returning a complete set of HTTP headers. The
headers it did return are:"
When I have had in my server a working mapserver application I had the
possibility to read error clearer error messages in my browser. For this
reason I think there is something "strange" in my actual mapserver
installation.
Thank you,
Andrea
| | Vincent Schut |
| | <schut at sarvision|
| | .com> |
| | 19/05/2003 09.39|
| Per: aborruso at spaziogis.it |
| Cc: mapserver-users at lists.gis.umn.edu, "Palle Due Larsen" <palle at mail-online.dk> |
| Oggetto: Re: [Mapserver-users] Please Help me |
Well, as it sais 'msloadmap (the function that produced the error message:
the
mapfile loading function): unable to access file', either the path or name
of
your mapfile is invalid, or mapserver does not have access to it. As I
think
you are on windows I am afraid I can't help you with file access issues. I
have only experience with this on linux. Maybe someone else on the list can
help you with that.
But first check if your mapfile is really there and does exist.
Regards,
Vincent.
On Thursday 15 May 2003 20:11, aborruso at spaziogis.it wrote:
> Thank you Vincent.
> Now I have (in the dos consolle) a normal message error, the message I
> would like to read also in my browser. But in my browser I have:
> "CGI Error
> The specified CGI application misbehaved by not returning a complete set
of
> HTTP headers. The headers it did return are:"
> This is the url :
http://mapserver.spaziogis.it/cgi-bin/mapserv.exe?map=c:
> \nodata\map.map&mode=map
> In my console I have: "msLoadMap(): Unable to access file.
> I have written: mapserv "QUERY_STRING=map=c:\nodata\map.map&mode=map".
> I have:
> <!-- MapServer version 3.6.3 OUTPUT=GIF OUTPUT=PNG OUTPUT=JPEG
OUTPUT=WBMP
> SUPPO
> RTS=PROJ SUPPORTS=TTF SUPPORTS=WMS_SERVER
SUPPORTS=WMS_CLIENT INPUT=EPPL7
> INPUT=
> POSTGIS INPUT=OGR INPUT=GDAL
INPUT=SHAPEFILE -->
> Do you have any other advices??
> Thank you for all,
> Andrea
> | | Vincent Schut |
> | | .com> |
> | | 15/05/2003 13.43|
> | Per: aborruso at spaziogis.it, "Palle Due Larsen"
> | | Oggetto: Re:
> the correct way to do this is:
> ./mapserv
"QUERY_STRING=map=/var/mapserver/mapfiles/province2.map&mode=map"
> (of course fill in your own mapfile and eventual other parameters. I
think
> you
> need to specify at least map and mode. This example prints the image data
> to
> stdout, so you will see your png or gif or whatever scrolling as ascii on
> you
> terminal :-)
> Works with mapserver-3.7. Don't know if it works with 3.6.x versions.
> Regards,
> Vincent.
> On Wednesday 14 May 2003 19:42, aborruso at spaziogis.it wrote:
> > Dear Palle,
> > I have entered your parmameters and I have had:
> > "This script can only be used to decode form results and should be
> > initiated as a CGI via a httpd server."
> > What do you think about?
> > Thank you,
> > Andrea
> > | | "Palle Due |
> > | | Larsen" |
> > | | <palle at mail-onli|
> > | | ne.dk> |
> > | | 13/05/2003 17.33|
> > | | Cc:
> > Hi Andrea,
> > Just enter mapserv -query_string="(all your normal CGI parameters)"
> > Best regards
> > Palle Due Larsen
> > -----Original Message-----
> > From: aborruso at spaziogis.it
> > To: "Palle Due Larsen" <palle at mail-online.dk>
> > Date: Mon, 12 May 2003 09:51:09 +0200
> > Subject: Re: [Mapserver-users] Please Help me
> > > Palle,
> > > could you write me a text to use in mapserv from command line, I'm
> > > not able
> > > to translate an url to a text for the command line. I know only
> > > "mapserv
> > > -v".
> > > Thank you,
> > > Andrea
> > > | | "Palle Due |
> > > | | Larsen" |
> > > | | ne.dk> |
> > > | | 12/05/2003 09.48|
> > > | Cc:
> > > Yes, I am aware of that, it was just that your url looked a little
> > > funny, so I thought it might be that mapserver misunderstood
> > > something.
> > > However, I just checked with my installation (Win2000, IIS, ms3.6),
> > > and
> > > I get expected results when using your url, so it must be something
> > > else. Have you tried running mapserv.exe from the command-line - with
> > > those parameters - to see if it's returning a correct result?
> > > Best regards
> > > Palle
> > > Date: Mon, 12 May 2003 09:19:58 +0200
> > > > Palle,
> > > > as you can read in my past email, the map file I want to use in my
> > > > example
> > > > does not exist. Then it would be normal to have an error message,
> > > but
> > > > I
> > > > remember some more specific error messages with the old version.
> > > Then
> > > > in my
> > > > example it should be appeared a message like: "mapserv: impossible
> > > to
> > > > find
> > > > test.map". I have instead: "CGI Error The specified CGI application
> > > > headers it
> > > > did return are:".
> > > > Is this error message normal or is there something wrong in my
> > > > installation??
> > > > Thank you,
> > > > Andrea
> > > > | | "Palle Due |
> > > > | | Larsen" |
> > > > | | ne.dk> |
> > > > | | 12/05/2003 09.09|
> > > > | Cc:
> > > > Could it be that the url is wrong? Your are missing the map
> > > > parameter,
> > > > try this:
> > > > http://127.0.0.1/cgi-bin/mapserv.exe?map=C:
> > > > \Inetpub\wwwroot\mapserver\test.map&mode=map
> > > > Best Regards
> > > > Palle Due Larsen
> > > > Carl Bro GIS & IT
> > > > To: mapserver-users at lists.gis.umn.edu
> > > > Date: Thu, 8 May 2003 19:27:14 +0200
> > > > Subject: [Mapserver-users] Please Help me
> > > > > Dear users,
> > > > > some time ago I have learned to build a mapserver powered site
> > > (3.2
> > > > > version). In the last months I have not had the time to "study"
> > > the
> > > > > new
> > > > > version and features of mapserver.
> > > > > Here is my problem. I have tried to build an update manifold
> > > > powered
> > > > > site.
> > > > > I have downloaded ms36gif_gdal_pg_wms.zip and ms35_libs.zip, then
> > > I
> > > > > have
> > > > > extracted all files where they could be extracted and then I have
> > > > > made a
> > > > > simple test; I have written simply this URL:
> > > > > http://127.0.0.1/cgi-bin/mapserv.exe?=C:
> > > > > \Inetpub\wwwroot\mapserver\test.map&mode=map.
> > > > > I have this error message: "CGI Error The specified CGI
> > > application
> > > > > headers it
> > > > > did return are:"
> > > > > The file of the test url does not exist, but I remember that with
> > > > the
> > > > > old
> > > > > versions I had an error message like "it's impossible to access
> > > to
> > > > > the file
> > > > > ..." (or something similar), instead I have a generic strange
> > > error
> > > > > message
> > > > > and I think there is something strong in my mapserver
> > > installation.
> > > > > Do you have some tip or advice for me?
> > > > > I have winxp pro with IIS.
> > > > > Thank you very much,
> > > > > Andrea
> > > > > _______________________________________________
> > > > > Mapserver-users mailing list
> > > > > Mapserver-users at lists.gis.umn.edu
> > > > > http://lists.gis.umn.edu/mailman/listinfo/mapserver-users
> > > > Få en gratis emailkonto her: www.mail-online.dk
> > > > Deltag i en lille brugerundersøgelse på
> > > > nettet, og vind et gavekort på 50.000 kroner..!
> > > > www.directoffice.dk/konkurrence
> Vincent Schut
> Sarvision B.V.
> Wageningen, The Netherlands
> www.sarvision.com
Vincent Schut
Sarvision B.V.
www.sarvision.com
