[Mapserver-users] finding intersections
Kieran J. Ames
kames at keyspanenergy.com
Mon May 19 20:20:37 EDT 2003
This is a multi-part message in MIME format.
--------------BADF2C3774CB53C6962FDB42
Content-Type: text/plain; charset=us-ascii
Content-Transfer-Encoding: 7bit
I went through the exercise you mention below, using ArcView Street Maps as
my original source data.
I ended up with a database of street intersections and dead-ends.
(...actually normalized street points that I query to derive intersection
data. The intersection of Main and Broad would be 2 records, each with the
same LAT/LON.) I'm using that to create a point layer that I include in my
mapfile.
The data are in a MySQL database. Data and indices total about 2.9GB. (Almost
28 million point records.)
My app resides behind a corporate firewall, so I can't give you an
interactive interface. But, I've attached a sample image... Some of the
streets that intersect with Folwell Ave in Zipcode 55108 in St. Paul, MN.
The problem is that it was easy (though tedious) to create the data. The
problem is maintaining it and adding new information. I haven't crossed that
bridge yet!
Kieran
pkishor_98 wrote:
> Someone asked me if mapserver could find intersections (constitution
> and 16th). I replied that mapserver by itself can't but there is no
> reason it couldn't be programmed. Then I realized I didn't really know
> how.
> I could create a table of intersections for every road (line), but I
> would have to start with a table of roads first.
> I could do some finagling with geocoding.
> Or I could...
> all ideas welcomed. In return, I will take the do-able ones and wiki 'em.
> Puneet.
> Mapserver-users mailing list
> Mapserver-users at lists.gis.umn.edu
> http://lists.gis.umn.edu/mailman/listinfo/mapserver-users
Content-Type: image/gif;
name="GENERIC_MAP1053389504271.gif"
Content-Transfer-Encoding: base64
Content-Disposition: inline;
filename="GENERIC_MAP1053389504271.gif"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--------------BADF2C3774CB53C6962FDB42--
