[Mapserver-users] Railway-line style
Krzysztof Chodak
k.chodak at autoguard.pl
Wed May 21 03:07:52 EDT 2003
Hello again,
I'm using current development version of mapserver, gdlib (2.0.12 after
gdlib-config) and freetypelib (9.3.3 after freetype-config) and I'm still
not able to make these symbols turn-around.
Are these versions new enough?
BR
Krzysztof Chodak
-----Original Message-----
[mailto:mapserver-users-admin at lists.gis.umn.edu] On Behalf Of
woodbri at swoodbridge.com
Sent: Tuesday, May 20, 2003 2:25 PM
To: Krzysztof Chodak; 'Stepan Kafka'; mapserver-users at lists.gis.umn.edu
Subject: RE: [Mapserver-users] Railway-line style
Yes, it is highly recommended that you upgrade to GD 2.0.12 as there
are a bunch of mapserver related bugs fixed in this version.
-Steve W.
On 20 May 2003 at 14:01, Stepan Kafka wrote:
> It always should keep line directions (see attached file).
> (But in some versions of mapserver in combination with gd 2.0 and
> freetype libraries there was problems with truetype symbol/labels
> rotation...?)
> Stepan Kafka
> > -----P vodn¡ zpr va-----
> > Od: Krzysztof Chodak [mailto:k.chodak at autoguard.pl]
> > Odesl no: 20. kv tna 2003 13:39
> > Komu: 'Stepan Kafka'; mapserver-users at lists.gis.umn.edu
> > P edm t: RE: [Mapserver-users] Railway-line style
> > Such symbols still do not "keep" line direction (are always
> > vertical)...
> > BR
> > Krzysztof Chodak
> > From: Stepan Kafka [mailto:stepan.kafka at centrum.cz]
> > Sent: Tuesday, May 20, 2003 1:13 PM
> > To: Krzysztof Chodak; mapserver-users at lists.gis.umn.edu
> > You can use truetype symbols eg. "|" overlayed upon the line. See
> > documentation. Here you have an example of the symbol definition:
> > SYMBOL
> > NAME "railway"
> > TYPE truetype
> > FONT arial
> > CHARACTER "|"
> > GAP 25 # distance between symbols
> > END
> > In layer class definition (form 3.6.x, in 3.7 and 4.0 use rather
> > STYLE) then
> > CLASS
> > SYMBOL 'circle'
> > COLOR 0 0 0
> > SIZE 1
> > OVERLAYSYMBOL 'railway'
> > OVERLAYCOLOR 0 0 0
> > OVERLAYSIZE 10
> > END
> > You may aslo use your own truetype symbols as you need.
> > Good luck
> > Stepan Kafka
> > Help Service Remote Sensing
> > tel: +420-327514118
> > mailto:kafka at email.cz
> > http://www.bnhelp.cz
> > > -----Puvodn¡ zpr va-----
> > > Od: mapserver-users-admin at lists.gis.umn.edu
> > > [mailto:mapserver-users-admin at lists.gis.umn.edu]za u ivatele
> > > Krzysztof Chodak Odesl no: 20. kvetna 2003 11:39 Komu:
> > > mapserver-users at lists.gis.umn.edu Predmet: [Mapserver-users]
> > > Railway-line style
> > > Can anyone suggest a solution for making streight line with ticks
> > > along it? Like that one made from pluses +++++++++++++. It (ticks)
> > > should also follow line direction.
> > > BR
> > > Krzysztof Chodak
> > > _______________________________________________
> > > Mapserver-users mailing list
> > > Mapserver-users at lists.gis.umn.edu
> > > http://lists.gis.umn.edu/mailman/listinfo/mapserver-users
> > > Pr¡choz¡ zpr va neobsahuje viry.
> > > Zkontrolov no antivirov m systmem AVG (http://www.grisoft.cz).
> > > Verze: 6.0.481 / Virov b ze: 277 - datum vyd n¡: 13.5.2003
> > Odchoz¡ zpr va neobsahuje viry.
> > Verze: 6.0.483 / Virov b ze: 279 - datum vyd n¡: 19.5.2003
> > P ¡choz¡ zpr va neobsahuje viry.
