[Mapserver-users] Small Scalebar
Thorsten Fischer
thfischer at mapmedia.de
Wed May 21 10:00:22 EDT 2003
On Tue, 2003-05-20 at 23:26, Eduin Yesid Carriillo wrote:
> I embed the scalebar in my map. But no matter wht scale is the map,
> the scalebar is too small.
What is too small? The scalebar image size? Then you have to adjust this
part:
> SIZE 400 9
If the numbers labeling the scalebar are too small, you probably have
not set a correct value for UNITS in the header of your mapfile.
hth,
thorsten
