[Mapserver-users] known issue: no results with QueryByPoint (Mapserver
3.7 PHP mapscript)
Michael Härtel
mhaerte1 at gwdg.de
Wed May 21 10:18:15 EDT 2003
--------------030706040602000008070507
Content-Type: text/plain; charset=ISO-8859-15; format=flowed
Content-Transfer-Encoding: 8bit
Vincent Schut wrote:
>On Wednesday 21 May 2003 10:37, Eric Bridger wrote:
>>On Wed, 2003-05-21 at 11:41, Michael Härtel wrote:
>>>Do i actually need a template file if i use mapserver 3.7 with
>>>mapscript? Or is it only needed by the simple CGI version?
>>You don't need the "actual" template file, but you do need the TEMPLATE
>>attribute set in the layer. E.g. TEMPLATE "dont_exist.html". I'm not
>>sure if this is still true in 3.7
>Yes, this is still the case in 3.7.
But i assume that the query should return some result objects anyway, no
matter whether a (correct) template file exists or not. The template
file only formats the result output i guess.
Or will the query not return any results if a template file is incorrect?
unfortunately I don' t find any suitable query template files for
Version 3.7. could someone send me one? thanks
Content-Type: text/html; charset=ISO-8859-15
<!DOCTYPE html PUBLIC "-//W3C//DTD HTML 4.01 Transitional//EN">
<html>
<head>
<title></title>
</head>
<body>
Vincent Schut wrote:<br>
<blockquote type="cite" cite="mid200305211446.13138.schut at sarvision.com">
<pre wrap="">On Wednesday 21 May 2003 10:37, Eric Bridger wrote:
</pre>
<blockquote type="cite">
<pre wrap="">On Wed, 2003-05-21 at 11:41, Michael Härtel wrote:
</pre>
<pre wrap="">Do i actually need a template file if i use mapserver 3.7 with
</pre>
</blockquote>
<pre wrap="">You don't need the "actual" template file, but you do need the TEMPLATE
</pre>
</blockquote>
<pre wrap=""><!---->
</pre>
</blockquote>
no matter whether a (correct) template file exists or not. The template
file only formats the result output i guess. <br>
incorrect?<br>
<br>
<pre class="moz-signature" cols="72"></pre>
</body>
</html>
--------------030706040602000008070507--
