[Mapserver-users] more (known issue: no results with QueryByPoint (Mapserver 3.7 PHP mapscript))
Michael Härtel
mhaerte1 at gwdg.de
Wed May 21 08:01:21 PDT 2003
Thanks to all for the answers.
according to the contributions i changed my map file to this (i added a
class even hough i dont want to show it in th map but it seems to be
turned on and therefor switched to visible status to be queried):
LAYER #wrs2
NAME "WRS-2_frame"
PROJECTION
proj=longlat
ellps=WGS84
datum=WGS84
no_defs
END
DATA "wrs2/wrs2"
STATUS ON
TYPE POLYGON
CLASS #all frames
NAME "WRS-2 frames"
#COLOR 200 200 200
OUTLINECOLOR 255 0 0
STATUS ON
END # country border
TOLERANCEUNITS kilometers
TOLERANCE 5
DUMP TRUE
HEADER "H:\_webroot_\mapserv_header.html"
TEMPLATE "H:\_webroot_\mapserv_query_template.html"
FOOTER "H:\_webroot_\mapserv_footer.html"
END # layer wrs2
in the PHTML File i use these lines to perform the query:
$query=$querylayer->QueryByPoint($my_point_geo,MS_MULTIPLE,-1);
$my_point_geo is a point object with geographic coordinates:
(object(point)(4) { ["_handle_"]=> resource(49) of type (Unknown)
["x"]=> float(18.454166666666) ["y"]=> float(31.758333333335) ["m"]=>)
target_layer is "->getlayerbyname('WRS-2 frame')";
AND: SOMETHING CHANGED:
The message "Warning: MapServer Error in msQueryByPoint(): No matching
record(s) found" does not appear anymore (success!)
BUT: $query is an integer, that ALWAYS is "0"! i think $query should
return "MS_SUCCESS" (1) if some objects in the shape file were found but
it doesn't!
So i think my situation has not really changed :(
More information about the MapServer-users
