[Mapserver-users] Re: I'm not able to solve my problem!!
Ed McNierney
ed at topozone.com
Wed May 21 15:06:27 EDT 2003
Andrea -
Yes, that's one set of correct-looking permissions (at least, they look correct to someone who does not speak Italian!). However, you're only looking at one set of permissions for one directory. Does that user have EXECUTE permission on the cgi-bin folder where the mapserv.exe executable lives? Does the ISS virtual directory for that folder have EXECUTE permission?
A good test might be to define a SCALEBAR object in your MAP file, and then create a URL with the "mode=scalebar" parameter on it. That's just about the simplest test that generates a valid image output from MapServer, and allows you to test that the MapServer binary is behaving properly without getting any data file or temporary file access issues involved. If you need help doing that test, let us know.
- Ed
Ed McNierney
President and Chief Mapmaker
TopoZone.com / Maps a la carte, Inc.
73 Princeton Street, Suite 305
North Chelmsford, MA 01863
ed at topozone.com
(978) 251-4242
-----Original Message-----
From: aborruso at spaziogis.it [mailto:aborruso at spaziogis.it]
Sent: Wednesday, May 21, 2003 2:36 PM
To: mapserver-users
Subject: RE: [Mapserver-users] Re: I'm not able to solve my problem!!
Ed,
I did not want to be insufficient specicif, but I really give all the
possible permissions to the "Account Internet Guest(IUSR_NADIR-HP)". Look
please at the attached file.
Thank you,
Andrea
(See attached file: ed.jpg)
| | "Ed McNierney" |
| | <ed at topozone.com|
| | 21/05/2003 20.29|
| Per: <aborruso at spaziogis.it>, "mapserver-users" <mapserver-users at lists.gis.umn.edu> |
| Cc: |
| Oggetto: RE: [Mapserver-users] Re: I'm not able to solve my problem!! |
Andrea -
It helps if you're a little more specific about what permissions you set.
Also, remember that giving "Everyone" permission is not at all the same
thing as giving every user full access to everything, because those users
might either have individual or group access RESTRICTED at a different
level.
What is the name of the anonymous Internet user, and what specific
permissions did you set for it?
- Ed
Ed McNierney
ed at topozone.com
(978) 251-4242
Sent: Wednesday, May 21, 2003 2:11 PM
To: mapserver-users
Ed,
I know that when I'm running mapserv.exe from the command line I'm running
under the security context of the interactive user ID I logged on with. And
I know I must set properly the access right for the interenet guest user,
but I do not solve my problems also when I give all the permissions to
Internet guest user and to "Everyone" user.
Thank you,
andrea
| | "Ed McNierney" |
| | 21/05/2003 18.41|
| Cc:
problem!! |
Andrea -
You should realize that when you are running mapserv.exe from the command
line you are running under the security context of the interactive user ID
you logged on with. When you run it under IIS you are running under the
"anonymous user" account configured on that server (unless it's been
changed). What user context is being used for anonymous Web users on your
system? Does that user have proper access rights to do what you're trying
to do?
- Ed
Sent: Wednesday, May 21, 2003 12:15 PM
To: mapserver-users
Subject: [Mapserver-users] Re: I'm not able to solve my problem!!
Hi Daniel,
thank you. I'll reply to your 3 questions:
1- What do you get when you run the following in a DOS window?
mapserv.exe "QUERY_STRING=map=C:/invalid/path.map"
"<HTML>
<HEAD><TITLE>MapServer Message</TITLE></HEAD>
<!-- MapServer version 3.6.3 OUTPUT=GIF OUTPUT=PNG OUTPUT=JPEG OUTPUT=WBMP
SUPPO
RTS=PROJ SUPPORTS=TTF SUPPORTS=WMS_SERVER SUPPORTS=WMS_CLIENT
INPUT=EPPL7
INPUT=
POSTGIS INPUT=OGR INPUT=GDAL INPUT=SHAPEFILE -->
<BODY BGCOLOR="#FFFFFF">
msLoadMap(): Unable to access file. (C:/invalid/path.map)
</BODY></HTML>"
2- What do you get when you access the following URL via a web bowser?
http://localhost/scripts/mapserv.exe
(Do a 'View Source' and quote the exact result, also change the URL
to match the location of the mapserv.exe script on your server)
"<head><title>Error in CGI Application</title></head>
<body><h1>CGI Error</h1>The specified CGI application misbehaved by not
returning a complete set of HTTP headers. The headers it did return
are:<p><p><pre></pre>"
3- What do you get when you access the following URL via a web browser?
http://localhost/scripts/mapserv.exe?map=C:/invalid/path.map
(Do a 'View Source' and quote the exact result)
That's all,
Andrea
| | Daniel |
| | Morissette |
| | <morissette at dmso|
| | lutions.ca> |
| | 21/05/2003 15.38|
| Per: aborruso at spaziogis.it
| Cc: mapserver-users <mapserver-users at lists.gis.umn.edu>
| Oggetto: Re: I'm not able to solve my problem!!
Hi Andrea,
The most knowledgeable people about Windows configuration are on the
list, so I'm returning this to the list. Perhaps the main issue is that
the problem is not presented properly and those people who know don't
see the real issue so they can't jump in and help. Your Email titles
should describe the problem and not attempt to translate yor personal
feelings with respect to the problem BTW... "Please help me" as a title
will just turn down readers if anything.
I have tried to follow that thread and the information that was
exchanged there must have been incomplete (hopefully) since some of what
was described seemed impossible to me. From what I understood, it would
seem that in a DOS window your mapserv.exe returns error messages but no
HTTP headers and no MapServer version information, and when run in your
web server it returns HTTP headers and version information sometimes but
not always, causing the web server to complain about missing HTTP
headers. However, when run with no query string in your web server your
mapserv does return the expected "This script can only be used to decode
form results and should be initiated as a CGI via a httpd server."...
this is really odd, let's see...
Before blaming it on Windows configuration I would like to solve a
little mystery about the inconsistent reports that I saw in the previous
email thread.
So can you please answer the following questions, quoting exactly the
output that you get and making sure that you quote the complete output
everytime:
Please send back that information (via the list) and we'll go from
there.
Daniel
Steve Lime wrote:
> Hi Andrea: It may be a simple configuration problem but it's on a
> Windows box and I have no experience with web servers in that
> environment- sorry. Have you gone back through the list archives? I
> recall seeing lot's of discussion centered around setup on Windows
> machines...
> Steve
> >>> <aborruso at spaziogis.it> 05/18/03 12:07 PM >>>
> Dear Steve and Daniel,
> I'm writing directly to you beacause I have a mapserver problem I have
> been
> not able to solve with the help of the mapserver list (I have written my
> first message ten days ago). I'm sure it's stupid configuration problem,
> and I know you are mapserver gurus.
> This is my problem: I write in my webbroser an url like
> http://mapserver.spaziogis.it/cgi-bin/mapserv.exe?map=c:
> \nodata\map.map&mode=map and I have "CGI Error
> The specified CGI application misbehaved by not returning a complete set
> of
> HTTP headers. The headers it did return are:". This a generic error and
> I'm
> not able to understand it.
> If I write "mapserv "QUERY_STRING=map=c:\nodata\map.map&mode=map"" in my
> mapserver dos console, I have "msLoadMap(): Unable to access file. (c:
> \nodata\map.map)". This is a message that I understand and I think to be
> able to solve it. Why am I not able to read undestandable error also in
> my
> browser??
> I have Winxp Pro with IIS.
> I have MapServer version 3.6.3 OUTPUT=GIF OUTPUT=PNG OUTPUT=JPEG
> OUTPUT=WBMP SUPPORTS=PROJ SUPPORTS=TTF SUPPORTS=WMS_SERVER
> SUPPORTS=WMS_CLIENT INPUT=EPPL7 INPUT=POSTGIS INPUT=OGR INPUT=GDAL
> INPUT=SHAPEFILE.
> I have not compiled mapserver in my xp box.
> I have simply downloaded the binary files from mapserver site:
> ms36gif_gdal_pg_wms.zip and ms35_libs.zip.
> Thank you and excuse me to have write directly to you.
> Sincerly,
> Andrea
> Andrea Borruso
> Nadir s.n.c.
> Tel 0039 091580305 interno 218
> Fax 0039 0916124646
> email: aborruso at spaziogis.it
> www.spaziogis.it
Mapserver-users mailing list
Mapserver-users at lists.gis.umn.edu
http://lists.gis.umn.edu/mailman/listinfo/mapserver-users
