[Mapserver-dev] RE: [Mapserver-users] additional parameters
for WMS layer
Mike V. Andreev
andreev at d902.iki.rssi.ru
Thu May 22 04:15:15 EDT 2003
Paul,
Thank you for your comments
After some thinking and reading docs I guess that suggestion is good
solution in my case.
20.05.2003, 17:46, Paul Spencer wrote:
> Mike,
> if I understand what you are trying to do correctly, I have successfully
> done something similar by modifying the url that points to the WMS
> server to include my additional parameters (I added RADIUS and
> FEATURE_COUNT for cubeserv WMS servers), so my url looked like
> http://www.cubewerx.com/demo/cubeserv/cubeserv.cgi?RADIUS=3&FEATURE_COUNT=5
> Mapserver appends the WMS parameters to this URL correctly. I have also
> done this with other parameters that I have needed when developing other
> applications. Typically I do this using mapscript and modify the
> connection at run time to append my custom parameters, but you can hard
> code them too.
> Cheers,
> Paul
> Mike V. Andreev wrote:
> > Hello John,
> > thanks for your comments.
> >>Mike,
> >>I feel what you are asking is an implementation problem and not a mapserv development issue. I wouldn't like to see mapserv develop some WMS parameters that are not OGC compliant. Not everyone allows cookies on their browser for security reasons and tying mapserv into a particular type of implementation would be dangerous unless it was compliant to the OGC specification.
> >>I think that you could use hidden input types to pass the extra parameters backwards and forwards to your CGI scripts. However, I would be very surprised if the OGC specifications have not already catered for these extra parameters.
> > I'm not sure what do you mean here. If you mean that OGC specification
> > already include my parameters then you are wrong. This is not geographic
> > parameters. For example it is a list of monitoring object or a datetime
> > range. But OGC WMS specification allows me to use additional parameters
> > in request to my CGI script, and if I would request my script directly
> > there isn't a problem.
> > But request to my script must be formed by mapserver. And it contains:
> > 1) string from layerObj.connection and 2) parameters formed by mapserver
> > (such as BBOX, SRS, etc). I can not define additional parameters in
> > mapserver's map file because they must be chosen by and user and change
> > from query to query.
> > By the other hand I can send additional parameters from form fields
> > (hidden or not) only to mapserver and they will have no an effect on
> > request mapserver send to my script. Or may be I miss something in docs
> > and there is some special mapserver option for it ? This would be a
> > solution.
> >>Just my initial thoughts on the idea.
> >>John
> >>>-----Original Message-----
> >>>From: Mike V. Andreev [mailto:andreev at d902.iki.rssi.ru]
> >>>Sent: Saturday, 17 May 2003 3:35
> >>>To: mapserver-dev at lists.gis.umn.edu
> >>>Cc: mapserver-users at lists.gis.umn.edu
> >>>Subject: [Mapserver-users] additional parameters for WMSÂ layer
> >>>Hello
> >>>I have mapserever compiled with WMS client support and I use map file
> >>>with defined WMS layer. This layer is a http reference to my
> >>>perl script
> >>>on the same http server. This script understand OGC WMS parameters in
> >>>query string and can create maps whith information from some database.
> >>>But to create sensible map this script need additional information in
> >>>request. I wanted to use http cookies to store that parameters. But I
> >>>have a problem here. Then my client send request to http server with
> >>>mapserver URI request contain proper cookies but after that mapserver
> >>>need to make http request to perl script URI and of couse this request
> >>>contains no cookies.
> >>>So I want to ask two question here:
> >>>1) Can somebody give me any hits to solve my problem with
> >>>existing soft?
> >>>2) I have an idea how to extend mapserver functionality so it
> >>>be able to
> >>>solve my problem. So I want to ask what do you people think about it.
> >>>There is my proposal: each layer object could contain boolean
> >>>parameter
> >>>http_cookies_forwad (disabled by default). So if this featcher enabled
> >>>in layer with connectiontype equal to 'WMS' (and may be
> >>>'WFS') than when
> >>>mapserver make http request to proper URL it sends additional http
> >>>headers: 1) Cookie - header with cookies client send to
> >>>mapserver and 2)
> >>>X-Forwarder-For - header with original client ip (as far as mapserver
> >>>can determine it).
> >>>Just to illustrate my idea I've made simple patch to maphttp.c. I used
> >>>today's (2003-05-16) nightly build. This patch contains only
> >>>functionality for sending proper http request. There is no
> >>>any stuff to
> >>>support new feature in layreObj but I think whole idea is clear.
> >>>81a82,83
> >>>>#define HTTP_COOKIES_FORWARDING 1
> >>>243a246,247
> >>>> char *tmp_env_read, *strBuf = NULL;
> >>>> struct curl_slist *slist=NULL;
> >>>366a371,392
> >>>> /* If we need to forward http cookies to server */
> >>>> if( HTTP_COOKIES_FORWARDING && (tmp_env_read =
> >>>curl_getenv( "HTTP_COOKIE" ) ) != NULL ){
> >>>> /*add cookies to http_handle*/
> >>>> curl_easy_setopt(http_handle, CURLOPT_COOKIE,
> >>>tmp_env_read);
> >>>> /*add X-Forwarded-For header with original client ip */
> >>>> if( (tmp_env_read = curl_getenv(
> >>>"HTTP_X_FORWARDED_FOR" )) == NULL )
> >>>"HTTP_FORWARDED" ) ) == NULL )
> >>>"HTTP_CLIENT_IP" ) ) == NULL )
> >>>> tmp_env_read = curl_getenv( "REMOTE_ADDR" );
> >>>> if( tmp_env_read != NULL ){
> >>>>#define HTTP_HEADER_BUF_LENGTH 100
> >>>> strBuf = (char*)malloc( HTTP_HEADER_BUF_LENGTH );
> >>>> snprintf( strBuf, HTTP_HEADER_BUF_LENGTH,
> >>>"X-Forwarded-For: %s", tmp_env_read);
> >>>>#undef HTTP_HEADER_BUF_LENGTH
> >>>> slist = curl_slist_append( slist, strBuf);
> >>>CURLOPT_HTTPHEADER, slist);
> >>>554a581,583
> >>>> if( slist != NULL ){ curl_slist_free_all(slist); }
> >>>> if( strBuf != NULL ){ free( strBuf ); }
> >>>556a586,587
> >>>>#undef HTTP_COOKIES_FORWARDING
____________________________________________________________
| Mike Andreev, software engineer andreev at d902.iki.rssi.ru |
| SMIS Lab, Space Research Institute http://smis.iki.rssi.ru |
|____________________________________________________________|
