[Mapserver-users] PHP mapscript, pointObj->draw, transparency problem
Thevenon Fabrice
fabrice.thevenon at cg64.fr
Thu May 22 11:13:12 EDT 2003
Hello All !
My mapfile describes a map with a layer of points that are drawn
with a truetype symbol and transparency.
(I draw circles as the top layer, with transparency to see what
is below the circles).
So far, everything is OK, the points appear with transparency.
I would like to add dynamically some other transparent points to
my map with mapscript.
I'm using php mapscript 3.6.2.
I use the following code :
$map=ms_newMapObj($path_mapfile);
$image=$map->draw();
$myLayer=$map->getLayerByName("theTransparentLayerName"); #This transparent
layer comes from the mapfile
$myPoint=ms_newPointObj();
$myPoint->setXY($x,$y);
$myPoint->draw($map, $myLayer, $image, 0, ""); #class 0 renders trnsparent
in the map file
The point is drawn with the parameters expected for the class 0,
(size, color, ...) except that it is NOT transparent...
How could I do to add dynamically transparent points to my map?
Many thanks for any help!
Fabrice THEVENON
Ingénieur SIG - Informatique
Conseil Général des Pyrénées Atlantiques
Direction des Moyens Techniques
64 avenue Jean Biray
64058 Pau Cedex 9
