[Mapserver-users] draw pie charts
Eric Bridger
eric at gomoos.org
Fri May 23 04:50:26 EDT 2003
You cannot do this with mapserver alone. But since mapserver produces
PNG's or GIF's you should be able to use the map as a base image and add
whatever you want using an image library, e.g. GD which is what
mapserver uses. See: http://stein.cshl.org/WWW/software/GD/ for a perl
version.
On Fri, 2003-05-23 at 08:56, Nuno Cabrita wrote:
> Hi, everyone, I want to draw a map with pie charts at certain points,
> but I can't find a way to do that.
> Does anyone know a way to do it?
> Mapserver-users mailing list
> Mapserver-users at lists.gis.umn.edu
> http://lists.gis.umn.edu/mailman/listinfo/mapserver-users
