I wrote: > I've developed a cool little tool for the internet mapping > framework (IMF). It allows a user to upload a shapefile and > have it added to the map as a layer..... I should mention that IMF doesn't work with Konqueror. If you are on Linux, use Mozilla to access the example instead. Doug
