[Mapserver-users] legendObj outlinecolor property does not exist?
Daniel Morissette
morissette at dmsolutions.ca
Mon May 26 19:38:54 EDT 2003
The class outlinecolor has been moved to a new style object in version
4.0dev. You can get the latest PHP MapScript 4.0 (a.k.a. 3.7) docs at:
http://www2.dmsolutions.ca/mapserver/dl/mapserver-3.7-dev-PHP-MAPSCRIPT-README.txt
See also the migration guide in the wiki for a more complete list of
changes between 3.6 and 4.0:
http://mapserver.gis.umn.edu/cgi-bin/wiki.pl?MigrationGuide
Daniel
Gerald Buckmaster wrote:
> Greetings,
> In the process of learning how to code PHP/Mapscript applications, I ran
> across a possible removal of a property from the legendObj class. My Linux
> system consists of 2.4.21-0.13mdk, PHP Version 4.3.2RC3, and MapServer
> version 4.0 (development) OUTPUT=PNG OUTPUT=JPEG OUTPUT=WBMP SUPPORTS=PROJ
> SUPPORTS=FREETYPE SUPPORTS=WMS_SERVER INPUT=TIFF INPUT=EPPL7 INPUT=JPEG
> INPUT=POSTGIS INPUT=OGR INPUT=GDAL INPUT=SHAPEFILE.
> When the code (offending portion remarked out) below is executed, nothing is
> displayed and I get the following error in my Apache error_log: PHP Fatal
> error: Property 'outlinecolor' does not exist in legend object.
> $my_legend = $map->legend;
> $my_legend->set(height, 80);
> $my_legend->set(width, 160);
> #$my_legend->set(outlinecolor, 1);
> $my_legend->set(status, MS_EMBED);
> $my_legend->set(position, MS_UL);
> $my_legend->set(postlabelcache, MS_TRUE);
> $map->drawLegend();
> BTW, when the offending line (concerning outlinecolor) is remarked out, the
> applications works perfectly.
> According to DM Solutions documentation on Mapscript 3.6, located at:
> http://www2.dmsolutions.ca/webtools/php_mapscript/php_mapscript_docs36.html
> The property does exist as shown below:
> legendObj Class
> Constructor:
> Instances of legendObj are always are always embedded inside the mapObj.
> Members:
> int height;
> int width;
> int keysizex;
> int keysizey;
> int keyspacingx;
> int keyspacingy;
> int outlinecolor; //Color of outline of box, -1 for no outline
> int status; //MS_ON, MS_OFF, MS_EMBED
> int position; //for embeded legends, MS_UL, MS_UC, ...
> int transparent;
> int interlace;
> int postlabelcache; //MS_TRUE, MS_FALSE
> labelObj label;
> colorObj imagecolor;
> string template
> Did this property get dropped in the recent development, or did I miss
> something in the build of of Mapserver 4.0 dev? More importantly, can I
> duplicate the functionality of the outlinecolor property of legendObj with
> other code?
> Thanks,
> Gerald
> Mapserver-users mailing list
> Mapserver-users at lists.gis.umn.edu
> http://lists.gis.umn.edu/mailman/listinfo/mapserver-users
