[Mapserver-users] legendObj outlinecolor property does not exist?
Gerald Buckmaster
gbuckmaster at cox.net
Mon May 26 22:21:55 EDT 2003
Daniel,
Thanks, but apparently it still does not display an outline around the legend,
but something did mess with my truetype on a different class object. My
truetype support died on the labelObj of scalebarObj...still works fine on
the labelObj of the legendObj (already tried a few minsize-maxsize scalings).
I get an error in the Apache error_log: PHP Fatal error: MapServer Error in
msGetBitmapFont(): Invalid bitmap font. Must be one of tiny, small, medium,
large or giant.
The scalebarObj label is exactly the same (even copy-pasted) as the legendObj
label but gives me this error. This file is the only code I've messed with
(font scaling worked fine before on both major objects), so I think it may be
tied somehow to modifications to the ColorObj's. I don't know...just wild
stabs in the dark.
This script works great, but doesn't render an outline around the legend.
/* BUILD LEGEND */
$my_legend = $map->legend;
$my_legend->set(height, 80);
$my_legend->set(width, 160);
$my_legend->imagecolor->setRGB(240,220,200); # tan
$my_legend->outlinecolor->setRGB(1,1,1); # black
$my_legend->set(status, MS_EMBED);
$my_legend->set(position, MS_UL);
/* SET LEGEND LABEL PROPERTIES */
$my_lg_label = $my_legend->label;
$my_lg_label->set(font, "arial");
$my_lg_label->set(type, MS_TRUETYPE);
$my_lg_label->set(size, 10);
$my_lg_label->set(minsize, 6);
$my_lg_label->set(maxsize, 12);
$my_lg_label->color->setRGB(100,100,100);
$my_legend->set(postlabelcache, MS_TRUE);
/* DRAW LEGEND */
$map->drawLegend();
This script generates the BITMAP error indicated above.
/* BUILD SCALEBAR */
$my_scalebar = $map->scalebar;
$my_scalebar->set(height, 6);
$my_scalebar->set(width, 300);
$my_scalebar->set(intervals, 10);
$my_scalebar->set(units, MS_KILOMETERS);
$my_scalebar->set(status, MS_EMBED);
$my_scalebar->set(position, MS_LC); # lower center
$my_scalebar->color->setRGB(200,10,10); # maroon
$my_scalebar->backgroundcolor->setRGB(10,100,10); # evergreen
$my_scalebar->outlinecolor->setRGB(255,255,255); # white
$my_scalebar->imagecolor->setRGB(20,255,90); # bright green
/* SET SCALEBAR LABEL PROPERTIES */
$my_sb_label = $my_scalebar->label;
$my_sb_label->set(font, "arial");
$my_sb_label->set(type, MS_TRUETYPE);
$my_sb_label->set(size, 10);
$my_sb_label->set(minsize, 6);
$my_sb_label->set(maxsize, 12);
$my_sb_label->color->setRGB(100,100,100);
$my_scalebar->set(postlabelcache, MS_TRUE);
/* DRAW SCALEBAR */
$map->drawScalebar(); # <--- ERROR ON THIS LINE
So, in summary, It looks like labelObj's attached to ScalebarObj do not like
MS_TRUETYPE as a type, or the integer style property is mandatory, regardless
of type, or I'm in over my head.
Thanks...this is getting interesting.
Gerald
On Monday 26 May 2003 04:43 pm, Daniel Morissette wrote:
> Ooopps, you're talking about the legendObj, not the classObj... I should
> have read your message more closely before responding... duh!
> This change should also be described in the migration guide, but it's a
> different story: the legend->outlinecolor is now of type ColorObj like
> all other color variables in mapscript, so you access it this way:
> $my_legend->outlinecolor->setRGB(255,0,0);
> Daniel
> > The class outlinecolor has been moved to a new style object in version
> > 4.0dev. You can get the latest PHP MapScript 4.0 (a.k.a. 3.7) docs at:
> > http://www2.dmsolutions.ca/mapserver/dl/mapserver-3.7-dev-PHP-MAPSCRIPT-R
> >EADME.txt
> > See also the migration guide in the wiki for a more complete list of
> > changes between 3.6 and 4.0:
> > http://mapserver.gis.umn.edu/cgi-bin/wiki.pl?MigrationGuide
> > Daniel
> > Gerald Buckmaster wrote:
> > > Greetings,
> > > In the process of learning how to code PHP/Mapscript applications, I
> > > ran across a possible removal of a property from the legendObj class.
> > > My Linux system consists of 2.4.21-0.13mdk, PHP Version 4.3.2RC3, and
> > > MapServer version 4.0 (development) OUTPUT=PNG OUTPUT=JPEG OUTPUT=WBMP
> > > SUPPORTS=PROJ SUPPORTS=FREETYPE SUPPORTS=WMS_SERVER INPUT=TIFF
> > > INPUT=EPPL7 INPUT=JPEG INPUT=POSTGIS INPUT=OGR INPUT=GDAL
> > > INPUT=SHAPEFILE.
> > > When the code (offending portion remarked out) below is executed,
> > > nothing is displayed and I get the following error in my Apache
> > > error_log: PHP Fatal error: Property 'outlinecolor' does not exist in
> > > legend object.
> > > #$my_legend->set(outlinecolor, 1);
> > > $map->drawLegend();
> > > BTW, when the offending line (concerning outlinecolor) is remarked out,
> > > the applications works perfectly.
> > > According to DM Solutions documentation on Mapscript 3.6, located at:
> > > http://www2.dmsolutions.ca/webtools/php_mapscript/php_mapscript_docs36.
> > >html
> > > The property does exist as shown below:
> > > legendObj Class
> > > Constructor:
> > > Instances of legendObj are always are always embedded inside the
> > > mapObj.
> > > Members:
> > > int height;
> > > int width;
> > > int keysizex;
> > > int keysizey;
> > > int keyspacingx;
> > > int keyspacingy;
> > > int outlinecolor; //Color of outline of box, -1 for no outline
> > > int status; //MS_ON, MS_OFF, MS_EMBED
> > > int position; //for embeded legends, MS_UL, MS_UC, ...
> > > int transparent;
> > > int interlace;
> > > int postlabelcache; //MS_TRUE, MS_FALSE
> > > labelObj label;
> > > colorObj imagecolor;
> > > string template
> > > Did this property get dropped in the recent development, or did I miss
> > > something in the build of of Mapserver 4.0 dev? More importantly, can
> > > I duplicate the functionality of the outlinecolor property of legendObj
> > > with other code?
> > > Thanks,
> > > Gerald
