[Mapserver-users] Re: html-type legends with perl mapscript
Puneet Kishor
pkishor at geoanalytics.com
Tue May 27 08:33:07 PDT 2003
On Tuesday, May 27, 2003, at 09:53 AM, Daniel Morissette wrote:
> Puneet Kishor wrote:
>> I am not sure how I am going to implement this eventually, but for now
>> I want to try out a separate legend icon for each layer. If a layer
>> has
>> more than one classes then I want a single image with all the key
>> boxes
>> for each class stacked one below another. So, this is what I tried in
>> my read-write perl ;-) --
> Maybe a possible trick would be that for each layer you call
> $map->drawLegend() after setting all other layers status to OFF. This
> way every call to drawLegend() would draw only a single layer and you
> would not have to worry about building the legend image and placing the
> icons and labels yourself, etc.
oh yeah. been there, done that. The problem with that approach is it
also draws the names of the layers (classes). I only want the
itty-bitty keybox. Eventually I want to create (html legends) with
keyboxes I can click on and open up color-selectors, and layer names
with checkboxes I can use to turn them on or off, or entire layer
elements I can select for querying purposes, etc. See, I need to be
able to build the individual components of a legend/layer control...
and the keybox is one of the denominators. drawLegendIcon seems to be
the ticket, as soon as I get it working, that is.
Thanks,
pk/
More information about the MapServer-users
