[Mapserver-users] Rosa and Windows-binary
Yewondwossen Assefa
assefa at dmsolutions.ca
Tue May 27 13:29:18 EDT 2003
Hi There,
2 things to check if the temporary files are created properly but not
loaded :
- what format are the tmp files ? If there are PNG, you shoulld use a
rosa_png.jar (http://www2.dmsolutions.ca/webtools/rosa/rosa_downloads.html)
- do you get any specific errors in your Java console ?
Later,
Roman Meier wrote:
>Hi list
>I have problems using the Rosa-Java-Applet with the
>CGI-Mapserver-Windows-Binary.
>I based the prototype on the following wiki-sample-code:
>Sample HTML templates
>A plain sample template was posted by Frank Koormann, it can be downloaded
>from
> ftp://ftp.intevation.de/users/frank/mapserver/rosa-sample.zip
>The problem is, that the map-image is not displayed in the applet window at
>all. I can see all the buttons but not the map. The mapserver-cgi produced a
>correct map-image that was put in the tmp-path.
>Another point is that not all rosa-buttons are working correctly. ZoomIn by
>rectancle and recentre is not working?
>Any ideas? Thanks in advance for your help...
>Roman
>gismap.ch, Industriestrasse 7, 4410 Liestal
>Telefon/Fax 061 901 34 31
>info at gismap.ch, http://www.gismap.ch
>_______________________________________________
>Mapserver-users mailing list
>Mapserver-users at lists.gis.umn.edu
>http://lists.gis.umn.edu/mailman/listinfo/mapserver-users
