Fw: [Mapserver-users] transparent background raster (tif)
Rosangela Silva
rosangela.silva at zenitpolar.com.br
Tue May 27 14:18:51 EDT 2003
This is a multi-part message in MIME format.
------=_NextPart_000_000A_01C32463.473B80B0
Content-Type: text/plain;
charset="iso-8859-1"
Content-Transfer-Encoding: 8bit
Hello,
I'm using mapserver 3.6.5.
I don't know how the mapserver interprets the background of the
tiff or jpg images. I'm looking for information about it, and some
softwares assumes the transparent background like a cannel "alpha",
but I don't know exactly how it works.
Sorry, but, for while, it is everything I know to explain.
Thanks
Rosângela.
----- Original Message -----
> From: "Ed McNierney" <ed at topozone.com>
> To: "Rosangela Silva" <rosangela.silva at zenitpolar.com.br>;
> "Mapserver-Users at Lists. Gis. Umn. Edu" <mapserver-users at lists.gis.umn.edu>
> Sent: Tuesday, May 27, 2003 2:20 PM
> Subject: RE: [Mapserver-users] transparent background raster (tif)
> Rosangela -
> The first thing you need to do is tell us what makes a pixel "background".
> Is it a specific RGB color or a specific pixel value? Also, let us know
> what version of MapServer you're using, because the OFFSITE parameter is
> different in 3.7.
> - Ed
> Ed McNierney
> President and Chief Mapmaker
> TopoZone.com / Maps a la carte, Inc.
> 73 Princeton Street, Suite 305
> North Chelmsford, MA 01863
> ed at topozone.com
> (978) 251-4242
> -----Original Message-----
> From: Rosangela Silva [mailto:rosangela.silva at zenitpolar.com.br]
> Sent: Tuesday, May 27, 2003 1:03 PM
> To: Mapserver-Users at Lists. Gis. Umn. Edu
> Subject: Re: [Mapserver-users] transparent background raster (tif)
> Dear Christina,
> Thanks for your help.
> I try to do it but everything became transparent,
> how can I do only background transparent??
> Thanks
> Rosângela
> My layer definition is:
> LAYER
> NAME "sp250"
> TILEINDEX "teste/sp250.shp"
> TILEITEM "IMAGE"
> STATUS DEFAULT
> TYPE RASTER
> #OFFSITE 0
> CLASS
> EXPRESSION "1" #1 refers to the colour-index
> COLOR -1 -1 -1 #transparent
> END
> # MAXSCALE
> # MINSCALE
> END
> From: "Christina Biakowski (CCGIS)" <christina.biakowski at ccgis.de>
> To: "Mapserver-Users at Lists. Gis. Umn. Edu"
> <mapserver-users at lists.gis.umn.edu>; "Rosangela Silva"
> Sent: Tuesday, May 27, 2003 3:59 AM
> Subject: AW: [Mapserver-users] transparent background raster (tif)
> > Hello,
> > perhaps you have already tried this: I think you have to find out the
> > colour-index of your background-color and set it to transparent,
> > either in the general layer section using the parameter OUTPUT with the
> > index of your background-color like e.g.
> > LAYER
> > NAME DGK1
> > TYPE RASTER
> > DATA "520911.tif"
> > STATUS ON
> > OFFSITE 0 #0 refers to the colour-index that has to be displayed
> > transparent
> > or defining an explicit class. For Rasters the classitem must be set to
> > VALUE.
> > LAYER
> > CLASSITEM "VALUE"
> > CLASS
> > END
> > The colour-index you could for example find out by using the ArcGis
> > Layer-Properties.
> > The described way works with Mapserver 3.6x, but I remember to have read
> > that in 3.7 it is implemented in a different way.
> > I hope this helps!
> > Best regards, Christina
> > -----Ursprüngliche Nachricht-----
> > Von: mapserver-users-admin at lists.gis.umn.edu
> > [mailto:mapserver-users-admin at lists.gis.umn.edu]Im Auftrag von Rosangela
> > Silva
> > Gesendet: Montag, 26. Mai 2003 16:44
> > An: mapserver-users at lists.gis.umn.edu
> > Betreff: Re: [Mapserver-users] transparent background raster (tif)
> > I could not send the files (large size) but
> > I'm sending an example in mapserver to you understand
> > better the problem.
> > Thanks
> > Rosângela
> > > Hello,
> > > I'm having a problem to show some images that have a black background.
> > > I need to see them with transparent background, is it possible in
> > Mapserver?
> > > They are in tiff format. I generate a tiff with transparent
background,
> > that
> > > can be seen using ArcGis, for example, (please, look the examples
> > attached).
> > > I'm using tile index for display this images. But is there some
property
> > > that can
> > > be set to background be transparent??
> > > Thansk
> > > Rosângela
> > > _______________________________________________
> > > Mapserver-users mailing list
> > > Mapserver-users at lists.gis.umn.edu
> > > http://lists.gis.umn.edu/mailman/listinfo/mapserver-users
Content-Type: image/gif;
name="example.gif"
Content-Transfer-Encoding: base64
Content-Disposition: attachment;
filename="example.gif"
R0lGODlhdwCvAPcAAAAAAAAIAAAQAAAACAAAEAAIDAAAGAAIGAgAAAgIAAgQAAgIEBAAABAIABAI
CBkJAQIVAgQSDgAQHAgQHAgYDBAQCBUVCBQQFAQYHAoYIBQYGBgYIQ0hCBAeHRIiHxQ0EiUgCyQ/
DDE4D0M8DSxeCDdfC0FgEE9fEDg7IENcIF5NHFtnHjg9MEhXN1pZLFxURG1XG29WLGVrG2hpK3Va
KXNrKX9aJ4JrJWxZPXldPWxcUnhhV4FiMYhiMYxeNo5gSTd4CEh6CUZ4FUt1J1h5F2Z1F1x2Lmh0
MUaIFFaHFFCSElqhFFSFJ2GGKVuOK16gJm14IHZ0IHFzNXV4K3t7JXtzMYF1K4xzL2yFH2+BM3eF
KImALmyOJnuMLXaYKnWsK3VvPoRvPYRzQoR7OYxrPYx1PJRtPJxvOWp+QYGBP3yKP3uiPIx7QpR/
OZGGPJCcO05vSmVtXYBuVndvcZhvQpR7QpxzQphxVHt7SpR/RoWFSIqaR4GOUJyQSol9Yo6VbKVt
RKVzSq1zQqV7QqV7SqVrUqVzVq1zUrVzUq17SqV7Uq17UrV7UqV7WqWEQq2EQqWESqWEUqWMQqWM
Sq2ESq2EUrGISrWEUqWRSqWUUq2URrGMUqWcSrGUUp2mSKqvTKV/Xqp+YK9+Xbd/XKmMXqaZXa+W
XruUWqeEbaiVcL2JZb2Zaa6Tfqeemrmbe8meeKOudp+/dq24g720eailnreykr27ksu1laWlpaWl
rampqa2tpa2tra21rbetpdK/pa2tta21ta21vbWtrbW1rbW1tbW1xrW9tb21rb29tbXBtb29vc7G
rb3Gtb29xsq9vcPLur3WrcHGxsbOxsbWtc7Mv87awdbeu8bGzs7Q09bO1tbWztbW1tbW3t7Wxt7e
xufOtefWzt7e1t7nxt7vvd7vzt7n1ufp097e3ufn3ufv3u/n3t7e597n5+fn5+/v5/fv5/f/5//3
5+fn7+/v7+/37/f37/f/7+/v9+/39/f39/f/9///9/f3//f//////ywAAAAAdwCvAEAI/gD/CRxI
sKDBgwgTKlzIsKHDhxD/+SM4sWBFihgHXpSYUeDGjx05agwJcmTEhSVNqvRo0eBGlitT/pvjqwIY
FK2SsWoxZ4QKEDlUzHmG4ycIED0mRdF3kqFMkSuhRlWJ60WeKnXs1LlSxUydNm7ytBkDhUqkPG4U
lalxpkaeO33GYHU0qcoYMzXKtMkzIw+bGEybKnzpUZ9hfRNlrWmyJounFUSM1FgxRoqpKopm8JDC
RgymPHbC8IhBpnMNGnXYVOnRB5IbN0KgcHKTpQiaxXn6cAnCpIsbMWGqVAlDxkyjRWXqROJBp4yp
pYIHh6SFo9YdMGCOhPmBChWrPqDu/qAyBCgHIDuHwrhwdIdOIxc5coQRLSaHnBw75MhhMyMMHTY1
4FCFZGCIQUYORUQGhQxNOMFFF1kcgUUWbLCxggt3sMHDFDXIAFN0LUV1ETrOZJPOPy/sAAIDxSzz
TzEDLTPNQPpk848+c4CgCB1hmCFWcHlUMoYeU5C1AipHVHFEEp4wEUQaaXCGx5BGZKGGFm6owYQQ
QHTJBBFjBBEYiC6FJNWZLxH2DzQhCIEFFkUW6UYVU0zBhRtpTJhCC2gMEYQbTRDxBBdcEKHCHWfp
IQYbUKYBRRZp9PEHHnL4ocMOL4xJJkkEZYPNP9ngwkIIJJRAhAlEBGpEEkk8oQQR/kl8EYQXa7yx
BhdMPPHFG1k44YSrJACBxBJPPAGEq0wc60QKcBiRggtNGIGCEXrogYceftDhx7Y77HCEEdkZIQUY
MGi66Yf/mJMFFmqgwcQa8K6hRgsfGGECChpEIEIEFkRQQQUeKGABGgFcQIEFFYiQxQgopACCBxoY
rMHEHWRwAAtMUDBBBhMY8YIEExwQQQYVb+ABHHCggTIaKZDAxBAhsOABxxoAYO65OOes88489+zz
z0AHLXRDcQwAwNFIJ6300kw37fTTUEctNdJxgFj01FhnrXXSIKBQQxuJQFJGhW0QsogZbdRRh1dk
XBHGIGRQkUYRbfThipoOXb11/tYWgKB0Ay7UIAIAKOARRhmVRAIJJpEMYkUZkFShhhWdtNGEFStA
4YYjbFixBRZ9mBEGGK9RUeQYY9BAGQ+Hq1YLP9HpDXUCFRjBBBMmjBBGDj2oocI1LqTwhBueuGHE
FG6gPuAKNYQRgxh5RC99HpCMwUYYudGBehpb5KEFEVk0ocYYXexRBhFBEFGkHlXkUEYeUoxBRmp3
+HVDGTzk8YvVRu/tgAtyQMUOfsCDFhjCDpuA3iJ4YCAelIEQPPABHXwQhjGEQQw/2EEOcICDF+jA
PqI4ECjAUAUD1WEKWSiSFGIghRqkYQxikEITAjXDJBAhDfURwwwoJAQlxAJv/kTr396G+LQYXKIM
70teHyKxAiN0oQRXUcEMULCCPUhhCl3Ig6LEkAUpzGAMr2GDGz6nhicQYYdbkAX/iMhGpKXAC2+Y
QhreEAUrOGIMVBhDGpqQBCdkYQhEKEETuPCEJSghDalhw1nqUIb46MEIaUhFJMaQhWQhAQlAwEMr
1pg1EJjABENgQqyWQMgmPCEJuOOCEryAhRBYyQgsSEGgzEgCIzihCSZgwhe88IUvNCEFt0EBCjoQ
AQpgwAkhCEEHNFCxDniABS4YFx/wgAcpWAkNamiCEJ6ABBJcMhZHEww2cKGLcprznOZsBjWuQY1m
lIMc0BCGMIIBjF7Ukxe8/uhFPvGJT33yU5/6bEYy+rlPftYTGNH4RzSoEY1t6KIXuQBGLnQR0YPa
86L7DIYx6BkMXnSUF9kI59BGStKcPSVNZQoRumTCUhoFI6UdKQY9fnZSlaILTSr1RzFs9I9hoOAF
LxABCGQQhbVQoQxQ6Aoh7lcJMvTgCnUIAwx64IjQ1OA0Y+hDH7ZQhivcbFM1NZNA/NCGL4zADUFY
Axa8gIk9XDAMNajCKRLHgzrwoAaZWKIagJAFTMiNDQuqwpyo4IZB3LEKRSDLo7JYhhmsgAZkoAMM
fGAGQhCiB7Db2UWyoQN/tIIFLRjCEJpoBCMMAQ8p6NUJmsCZJhxhBnSo/kOBWHEHVYSHDoDwASHK
QJzi8KBBSZjCho7HvTRoAQqegAIYx1CHPIiBTn4BEFZAEYkWyuAIZVCEf0ABGJ49RSDwCIcrOqgD
OajAB5cwxCbowANF3KESNuCBDQxhBjLwRRGBiMEPOJiDH4gBDDm4avxSqAYupCEPU1ADFFTwwhp0
AVeoTBX43KCHLGRhD3y8ZDdJEIJ6eNdMKLXpTS+CCxAQ4gpFqgHyqpCFyggHCi8bgRDgJwY98mAG
McjDD+wQiDyooQ+OyIMfpHDgIclByEX4KpnCGhVxiKMi5siGlNMBDQAIIZesIsJVt+AGWr3BC1ro
Qqu+9AYTqPIJWOhC/hUQSYo7kGE4YMCBHsCgBj6AwQgrGIIQhDCEJkQozv34sEDcwQt6zCEORBCC
GtagZ1gh4ZRfWJYTSqCEJexAACmIAAQ4YAEN5IEIXPhCobjghC8sIdJeQAEGjACxiVFgYhGYGDMp
kAFmcswDOMDDEdJgJTVUsglIcJCvgMCEFARasxpxhz2WbQ9+2CMf+MAHPaZN7XdQe9rWrva16VGP
ZW+bHtme9jzqMQ96lPvb6P42PvKRD3S7o6Twjre8503vett7aLJro7737TQEOG0OQGRIvvmtbxG4
IAb5cwMUvtcHKUAhyGOwg1bqMAiJm0EReXgqGRxRg6zUwTVVuGob/qbwutgJkeBpUIMQmOAEWzax
Bq8NjWuroIcxJMcOkfABGOsgBRlYyQwodoMKflyEL7hhEjtXsRWOqggyqEAFVSBEDSx4hhgsgg4q
+EVmmzJwqWHoD9ZqASzwzBgeRPwOP0D7HdAuh6b/YINhIIQZmDM/JJIBdYfLQxbKQBnUqWELRcJD
fXhQBTBkVe9dkEIV/MygCB1BD3nAQw1swUki3qERjYjEJX6QCkK8wi+lIIUcLIAAC8Sgby5oJBLL
EAhCKCIGWJkPG+CXOfYNAQszmNMMpOBFUQohWkdYbBcSzQQklAAIpWICsWAR8IV0neBTk3MKSpEJ
1M2dkY4AAxGw/oCE24WgCVisAhHUwOIxxMAQI1REtfJw4EzkIRLYwsMcdOCHWlS+jQEIAABCMAQv
JMECKMABNpQqxYIqXCAEQcAFb/Amg+InDlJIS+AFPUQoqxRpxdIFanAtaBA+YbYHoCAGlCIH+YEH
3DJ/rSBSJ/F8TFMCWCAE37JyJiBIJJAESxArqfAFT2AEHGAEGvAvCWNGINACIuABFuAC4SNqukQC
EuNqGlBrHNCEy7RME4MBFKMBE9CEJtMCLZACwPQELuAEePAHLfAHRnNvZniGaJiGTgFTUtFSMcEp
bxiHKwWHOsNkU+GGcyiHbUiHezgVIGKHOCVifZiHhFgQ6HAM/gOhDdwwEHPADRMBDLTADM3XFIAY
YiLChgvRCiBwAjdwBo6QSHYwCJVgB3qxNnZ3BXZwBnYBBVvQB1ZwAvYgaCMmYpZ4U//QCnNwiy+Q
CuRSBgqHBTJAG1AwCH1QBYFgB2lDCOdRWZFwA1ewcVYQBpDwcXMicmNgBV4li4F4if8wAF0zAAtQ
AAMwABXgAjKQCv8gDtcSd4qTCZAACVcAOWEwOZvgCJcDGZvTBzUgCUSACXTwA3QmCaZjBagzGash
e/NxA0r2hyAmECyQi/+wATBCACMwfEPgBEPwBDIgGa/FI0fAWmmgGlkRCWZgBWFRBStgJWVABsjD
YH0gA1/Q/gWbYAXRYwVJVVR5gHUqUAOEIBxiYAY2EAh1AAOJM4knsRG4AAAfkARCQAQiECAxMAYu
YAuoNTxv0AfBtwdXgDpHcAIzUAYwsCjwZwfSEwmrxwZ9UAaoswVglAXgkwTjUz51UARAQATKxSg2
8D52UQZ08BZ+YQVvlgegYAewY5QPQRjH5g08AHZ4AAeT0mfkx1x0UAh3sAOFIAZ3kAONUAY+EB9R
x17FkRwriTpIxChjIANyASVbYBdpIAd3NTpVoFWUNAZTcARZAAUzdAS71gd4QHNFYJgQIRPTMAcs
gAKVgnZh8ALtEQkVskANFAaV4AM0kFsX1BVioEEc5EED/vSBPHAH/0UcdoBCUyAGU+ACVRADaoBD
1uQERJAqoiQFOcR7bjAESqAESbAP2miJv9AIdzCYmqkInzc/qZADDPAPAFAH1cAAInADOQAD8xEI
ikAIARZVh6MHYZA547MCTRCMXbB7UzADTeAk0WIEj2JciZYEmAQEJVACTKAET+Ak+Ils3DgQ7KAP
7HBsevgSf4ACjMBIezEG7zcD4GMCqCNFKpACe5AFDtYHaUAGeJAFVTADpOMGjOIGE+IFTLBDXfBg
W2dSDfmlZlIMAPAP7yAGKdAHpcAGd1FXPhIGUIAFueIEH8AE5UcEXRBDQhcIqFADjZAHfJAHQFoK
QhZ//iK4LTiAn8DZEJVIi4M2pgNxDms1J3tABTfgBmWQR3nSR3/EBCRgp8SySj0mBpHAnI2UA3iA
BkeQCqTABr0iLJiEBzugAwsZHYAIKseADSAQAk8QBNVQDwAQYU3QSyEgYSaQBG+gBVhAKFvyBLxk
SGZ0Sl6gBKFGSIOiBn4wTX7WBVqwB6QAgvqxA2BATX7QLfN3qLLoDq0wEdrQCn6QTKxSLH3UKqhk
AnyEZt+XTcI0S0RAAqn1MkGwS73UBENwGyvAAh9wARFwAJw6TBvAMRnwTNGEBn5ATU/qa0/KBMAm
LEqABESQqA5xEYb2AVgQGX9EBENgKiYQBJX2BX2w/gZP0AQhIC0UUAEUcAFe8AQGlwJD6AJqkARe
wAWxkgQeQLOy9moZwAEdIIUdcIUaQIVN2LRN+0wt8AKhZQReUFpZ8Ac30QJ+KBgXwQ0iQENCAC9P
wAIZ8LBRaAEGYwE127YIcwEawLZsewEegAILwC8GcwE0WwETMwEoMA4uuwZ8wAEY8AEbgAIy4wEN
K2sTMAERgAEUoDEyU2u1RoUUYDN1CBMVMRGbKxKcyxKdG7qgO7oc0bmee7qiW7qk+7mkq4au+7qw
G7uyO7u0W7u2G2+4EAe6u7u827u++7vAG7zCO7zEW7y8iwv3B33Ku7xUk7zM+7xIgwBdM3oJ0DUP
/mABRQECP6ACG9A1OdA1IGAHlGdy0LtvXYMALzACIlAkbZBUYxAFVSBx8asWPaAXN0ADVwAJdhBy
NMADcwQJWmB/5Fu+WqMCORC/PsIVqFgHYTEWygUJaEEIYfCMPDB7xagXEIw8PfA1ZdAHM1AHAiwY
KrhvpLAFX3AC4idqV+kGFwQgbrAJpGBXkEADVeB+kaAGJKAGmhAFOBQFqOkGU2CSjpA8NcCKUHAE
XKAGkeNYkGUHKmAGPkAJt+C8WrMHnjAEi/EJJxAZk5EGYJAJ2KMZJZQHk5AHdgUGedkZNOAWblAD
ZNAHk+AGexAENcAJCgYFt5EFaNEEQbBW1xMc/lVABvMjColQBnagCDRwCFawPwM8NRWQAqZFWkxg
BHwgAmuQBCnABa2lGf+BmahQW5FwB7lVWbzlVHRQA6SGBFWwIZTRBXoEJ3G0XM1FnlXgF2PwRXVA
CvDTIUdQB4bgH7eAoyl4clMDAqjgCniQA7yXA3TACn7gCnoQCj+gCoUwQXQQCIGQAzMACZNJB/CR
A2QABmSwO3JQXpUiBitAB2JABzMwAwNSA2BAHDkQKMHHIA4CIY9CIWyQAjHgB/gDBXfTyFsDAixw
IDigA3cwAnQwCndwCk7lXongAxEUCJElBjUQCmbQXzgQHz/wA1KgzVOgeBZWYAdWBR0aA1lw/gVH
8GArlwRGMENTwH4WhmEoekkk8AceSxAjrDUXcDS38AAg4G9TkwAvIHd15QhlIByQEAlTgJVbYAQz
gAotNEh7YEPjQ3NioAdSYARq4MpZIgRIwCUrRwRqJNAEDDUxAAkqFqWEZReJFxxF8DIhUASqIQZQ
UgXwwQZptwg+tjl18AcyAHlW4AdZ7QtUfNZHAwK/hwULVwZT4ItTQCdewAZa0ARakAJDAAftOQZY
0CBckAUrgAN3QAgUtihSQCQo5AZ8MClycAc6sAuH3UYK4DeJjTQWwAEo8CWilARQwCFuoAW89AZc
EGZjhgVl5gQuOiEvlAdtxlthgAPhmnJ8/rDVK/AyfIYGXlQLKBgROy01HHCyplICQmAv2kQES3BL
8uplXtAgvSQvThArmNRDxGIsyIIEWApazjIER7ACKfB41IQtP7At3/otaAAZM6DdjjrMU6MACYM7
sfBHTSlKkCawXEACEegCFJBpTygALMAGgvIF20dIpvYFj+YBHmAEHfBqTEgBUlhrUXi2G6AD2VGx
FjZDwbYGvkIC4JTg3E3MTYMCa+AFfGAEXPAJ8MIFfMACELAGH8ABNZsCCtCDB6MBCoACaCAAetsv
KTADHyBMcHsBcKsBr1YxBmAETzAAG7MBagAHBiABC7AxHdCwLBAHq40GfIAGpLIsHpC0/hkQAXOw
3bcb6II+6IRe6IZOU3yIh4O46Ire6HyIM4QR6Yk+6TlK6YWY0yghiJJe6Zx+6ZZ+JpkLpnf46Y5+
ELWoJpguHaIO6pvu6Xr4D+3AAgjxEsXQDijCDmIFVoy66qxO6gSRE8gL63MwB+TUCkCFDv+wDMSA
C63QCkIFA/fgM7W4jbOo6XA4B63wC7+AFFEQPSBAB2fAAypwCJYlcc7jA2UwCWDRB3NZmNpI7fA+
7QLRCrzAEXOAI3HwArRgCycABUlwBYPgFmJTB4QACYGAOjdQHGcQW2PAOqA2BlvQBjfQpaE+o9Vu
8QWBDKwABmbAQly2IGUwCJkgHBPH/noT1FXspRdsQAYOxAZlYAVW0AYwLwOzypCrPu2WiA623goj
wAM9EMhVIANftJp6YVxANgV1EAjJYQZ3gBfJkQeO4DZX0AaUYAU98BW0qQI1T6u7vhI8XhDswAI4
mgwIV8EPRAZk6QaQAGRkEQWcQAR9wANlPBk2IPE+ABdVEPNV4AV78HE3MAM1MAOiSi5b77Vdjy4A
kJ5bqgCa8wZgtAdVQAp4cAOh0wN2ICT3Y3aOsKVaAAMdkjxukDZzmTxRMD8ysHBdUCeP41hsUF98
yfI2EIs9I+8hAgBjYCueoAZOsAcp4IKQIAVrsXF64DZsYAdQBaQ38AZCkAZRIAls/hAFfRD6ebAW
QVAHXMUGzbX2hMekcRU9V2AFl5AIiUAKg2ADhU+JDfEHfczYWyDkJPBH8CMF0x8Jr3UE8q8aa7+q
kWBFMyBGXQUQddi0GSOwjacuXNz0gQLGyicuQJpAyhOmTh0pbsqUqZOnRp5LNGiosPfP5EmUKVWu
ROnvpDt9rQCYqADgTxwQfbjAStHkS5Y+nPakyFRFkZgqpNiIGROmBp0aNMpUCcODDaQ+ZdKwcZMn
DxQja7qc6NJkDRUsUkgsYbhlDBinYciUoUM30qgwK0YpsqNCH0vAgVO6lAYglicgQ06UKJFCxRET
f76t4VI2y5QZPI6UUjEjC91N/mJAHTpE5xChSHnY5KHDJkuVMWXaZNEDJcsKKGq6uJnSJwuULn1m
1KAqBszHPoryzBhTpQoPRQJp/BVcnaXLf/6WxeknrYUaNGjioIl2DQ2TJFJmTKEb5gegO4VyiAl1
Rw8dO3Z6bKxipmoVKJLIIo+OYFODCDa0aGKLNPRII4wwxJhqDDasULCM5tjQsAksMknjjghloM46
Ek/CLiVm5HglFTCMWCELMfAghZQ85JDjjh1+uCMHQ0S5o647xLijhh/I+IGOMGggg447IgHDuCny
mCIHNuoY44gjagBDjh9qyMKNI9IYA4ssdMsiCyn2OGIFKcQQY70xihixRBJP/jTJJWxewCGHHGws
RMcc7mCDDzvMIIQHOpasJAYawvChBzr45FOMH3J44YUddrhDUDnE4EGMGGCbooo80uBBijRWaOK3
LIQgwogmmuCiiRmEjEFDHN7Qgoh96KTTzuz+kWaZbvy4AxUcVHDBhRwSGUWVOjbJIRDWeKAhkCVb
MyIMEHPQAQccdPihzTvICGMMMWpQY4ox0iDisirAKKOGNLJYk4km8OXwiDH0YGMGIohAD4gSSMgn
WF+rAxbYf2pZJRUcY1ABlE1jEOMVM1YJ5wE66FjEjjp4qIIMHgy54wcxcuiyBjilqEGKLGY1ggo1
tkChihik4IIJ9JAQ4ogs/moYIwv0nHBCCSSQQBoIIA5O2LqFVYoDAABoAIefF+x4BQQA4AFgHWD+
AeCBf3iZhhYQ3mllBEXMMIOMGsow1A5C2IgTijGYy2IGNpqYQjchkmACCj2OcE4NLoTI4g0jCiYh
BSGU5iKJOZ8GLOqWTHoBmxZawUebaS5XqR9azICkLjPaYGOL1cKAAgkomKANBXebUAMLLUwFwysp
pMADCue06IKIfPNdIwkOK7d8JcxNVInh5hFuBQRB7IDEyhq0MEKG9SK/jI0VpmAhj3alCNSFWpHa
IxI+3NjCjd+aGMMUPcaAQvnlB9M/c/77dx6laYxgBW/oAxt2Y7eFIG45/kngAgqY0IUVtGFUpqiC
HsDwJDmIIhRpOAIb+uAHP+BhBWPogRxAGAb85e9/K7zT/ljYwpOYgwhBIBwm2vAR3rhPBkUwAQog
YIQWCEEhWWhCFWZVxBz4QQ9hiMGWxCADCrUhDyCUgw50EAcdpFCFCHth9Lh4J3qYpDBJ+IT93FCF
OpThCnmoQh/cYIQhuAAPKUgCBJIgAy28YQ9cUAMqNkUHj9DggkCrgh8GlYY0NMEIJ/CDCfuxxeu4
EIYvZEk36kEMAEyuCFbIDRW2kIk3uEENbtiZIqdAhCR04QlPcEIJplIHMlyFEHlAgx9K5S+MEMFn
QmDCEGawgyxCknmS/vyiSbKBjhKEgB//yIYJqBYAxgisBEJwwhOw0AUtZCEJQFDCF7TghTcogQtE
0JUWgBAEL3AhC17oghr88Ao2NKheehClHvCAPnsaYQd4kAMewDADLarQi8w8hjVSAAEBDGEJSSBC
CbhQgiCYoARMQGcSwDnOJ7zhDURwAr6EUAIgCGGVTxACEJKAhCd44QlI+MKqXnOEFADtCF3QAyjk
wIZG7sBGeMhppnAQ0Pwx7B9/YAEx4gABEiTBBCRYjBBSwNQlmCAIX+DCGhqagjVggaQmYMIavLAG
o31hCU9Ywheq+QQiPO6paHDCBw4ABxCwIAUp8EwatkRFP6TBd3hQ/kMThgDSJEBhBo8UqkD/sYwB
mKQYHJghEwJ2tLJStZUr0GUSPCEAFpQABZuNaRO8QIQnxCoJ3QTnG+CwADi4oAMY0IAGOhCBFHCA
Ah64gGsn0IEMoKAFeNCDg8qkBiIyQQhKcALTgIAEJvRKmPpDRxxgEYISKBJxJxiCq4Sg1S98NQlB
SMIS1FAAFFDgAi0YQgrAkAQsrCFmXHBCEpzwhScAwQMaSIEHKNBaDXCAA669bwc0kIH/ulYDG2CB
B+SIB70CjQlOWENXXfQC5S73f+IQQRAC9lchrOE8T5CqEjzRAhGEAAUFCEEFIoACBXDgAyJYAAg8
UAENhCUJGjZC/mxrq4H7tnYCC/AvgCcwARzjF8CsjcCPI/CBFAxhCEx4AhPQ8AIWsKADFADq8rAT
j8kxwQtI8IkRouwBD3wAx+L1gAXEawEOVIACFhjCAsx8ATWDIMcWuMCbg9yBA6SACUvgAxAwgAE+
HIEPc5gDHFgwgQxkwAMs+MCXWYCBuXoAA0AOMACqbDnCACAJq4wsCTKAgQMMgGqjJnWpTR0AFASB
BFwz9agFEFsBQCACVEPAqAcg6laT2gMZIECr/1LYoEo42ML2H7GNfWxkJ1vZy2Z2s539bGhHW9rT
pna1rX1tbGdb29vmdre9/W1wh1vc4/721ER963PfGgDoXre6/tn9bnfHO93zbje94W1veddb3/du
N9W4s7w44DrXAyd4wQ1+cIQnfA6PtFzAE/5wiEdc4gOPQ/4cPnGMZ3zgDtCAqStQaxQ0YNQWGDUI
/mBxgWtc5REHwWZVQIYpZCIHKmgEJWIQg0QoQhGDsAMbfmCGMlDCEW5wgy1QvnKkH1wFKJgBFLBw
hTpUYZZtsB4h7DCGMfDADD44Ax2i7oMwEIELZbCCLZbZ8JQnfeUgiIELFKGCNLyvCDKwwyD64ByQ
tYEMgaBDD64A9DBcoQ11qEob0kB2K9QhCrM4utpVjoIYmMsKZKhC+KawhSrIRjeTaEMV6MYRMygC
bhxxRB6u/kCGKzgCElbogR06D4vGOz7iFlCBxdIICTIMQiBYcUScrPAGLLjhCpGowwxk0IM23EBH
faiBFdrwzT7UARI0GI4L2ECIVpz9aReXPdU8MYYuQAEEf3vDGPawhzDkQV59IEMPAhEJK0CdBm2Y
RHqpAIMqyMANY3DD4NkAhf17CjKQAeBIAyiggsxbAb4xgx6oAzrgAVcAturgPsczhTdYgzVQgwyE
HFKhirgplY2oA6DrvD6wgTcAgj6QgU4YgyjghDEYvDCQASKogy3giI6giCqwgrtzCK+wAitQBUFI
hEi4BQkUDAqcOM/SgjUovwwkgdvIA8PpiDxQDyPYnXPJ/oNMiAQ2yAQ9mIEZ6AoSUo08YJ06cIM3
QByiGxU38ITiygKKsIgyyII0KgOvkAFIqAQViECASzuCCwAASAEjsIAEQAAESIFSSAJZEIHsygJO
yIQ9GII+SD8kUQqmeI46oAEeCAO44IE8mIQ8KIMuEIg8aINXEQuyqCq0MAIgeAI3wJvmcIoyCIOO
EQM6uIsqOAFVoINbYLjt48NWQwE1cAJXWSoTSAH0IYFa+IYnqAz5wYze6QMV8JIweD82aARRKARA
CATUUA0HrA2skw3asI0VwALdOKM9mILccIMaII4yMI6PiITUWAGPcAq8qIXYSzgXAA84wAM0sAaD
mpx//sq8t3mPTZmPUMgDPTADvtuPMLiBPOABHkBHJhgDAjmjLyGCetGCdnGDB4mQqbCboYECuwkD
N4gnIuiCUviQGrDHPYy4FgiFWyCFFhmCNBADPyCFVCiDG/GDHJEDMjCERbgDuQGklCGDbIHIJbkD
UMABNnjGGsiBNmCKI3AZG/EBGciCoRkDNQAO4LqMNNiDFVgBMIgnFZiCWtC+hDnCgxsAFNgBHOCB
HfCDP9mRO0BIWAoERCEDO1AERiEDsPsBHpAUStGBF9ABYBIUOpCDMqCBO4iBpmAX8nmZKjACLpAC
oEGCV4mVWZmBIImBSCiDGegCWbhHiPsBVlAFFliW/hjIgUt4ljK4hGlhjRzggUIxAzrgIFoMgxzA
AT3ZAU3UkXMJAzaQgT2AIneZAimIlzCogr46AoHJF+LxGzwQgzSQQeJBAhL4gyIMDLWEuBz4BT8A
BR2QGFU4khi4g1UgBFSwgBEIhEWIjqirCjJohJPRTTGggRqAIjCoghqYKSJ6l3VJAR5wgURCniQQ
AsXJkjHIF+I6Gm5CAiCIhe0EjO58OAuoAAZYBRCoABA4hVeoADqzAAegtRFFgAQQUQsAgRwQPTMQ
GTKoA76rGzYggijIm6GZgXr5my4InFXRKynQyiYQgi5gHBIo0r9SGlmYUJaoUIy7AIl7gUqIBKAj
/gOiQxc2IgIhmAIBSQNgJJ4swAIx4YHdYYMa4CsoCIMpyILhyReieQMkiAXS7L6EiwFAsINNuIIy
uEoiMD4pCAIkyAIrYAMjqIEWiKc3ERL0MRcp6IM/6IO40wN0bAI2cAUpGM2WlNOEQwEXgAJPyIpR
shI3yISyUIQVcIImQAEnyAIomoItDAM9iBdKCQVSsEw3IIU4+AM5OIGQsRFkQEtfYVJMJbUUSBya
wgQrIJVW7IMoqIEiSAEU4AA0aAEk4AI9+FItwIJYqYEwsCUpECQ5yBsxoUMqIsxdiNNgLTUOsCwq
4D80yryoc9RXkaOJsiPg2APKyANUyIM76Dke/mgiMDgTnDqk/zQBP6AFcz3XAJAzE/CCIFhWKEgD
KnADTgilLpAEwTGl6+KCVSKCE2ADiyADryCENOApe9IDMQAfJtilXloBXzjYjOOAISACqkkAI/gA
EAiBIMVSExAYLrgmLZicEngCb/IqJfgs4DOnVEonL/ACPfiDVIgnPQAuPegDLfADMHABMLAgfeIn
MJAJAEA7lQOBDwgBsmWvJEiCIViDIAACEzABJ0AnLgAnbXoCT9ACJtgZDiOBkBopIEhZpYEvJViD
JjiCNK0xoCkTPWgEm2wkHZCDC8opHfBasI24BACBZBIcxhACE0BQESCCJRCCIFiCLliDEwiB/hRI
Jw6bKMRpr1V6r25yApUaAtNFgRCAoxDIgBbYgEWjqywYWRNqJAfxHT4gopJCgiSABaqZXITTAMpy
lYBRgtD9AsnC2cBJAjw4MrJFARFIAZ1hr9Bqgk3LrjfwBBY4ADxAgT/DLw0IAQ7AAP/SgNvKgA4w
MD7oLeDiAzU4gnxRGmEEAhKIheTtxYNDASPYWSLKAixdAQQNAo2lKrXlriVAgwp4MQ+AFQVkoDTo
Ai9ogrcV2i8ggdpKgRy7rw/YrzsDMtYSsPk1MD3wgzGQAiPogrttUxeABVFTXoLTVOf9KCGIBSOA
3RIwgSWYBRDgAAt4sTTTABGgAAWwAA1wn2INqAARUAMvSAI+MAIjEIEJGOEAK7L/2gAK+DEKALD7
kl8MuIAiiwAKQDIlqyYmwIPc1YA5COC0RDgRwAIg8Nxz+oIP+DQMoAABAAA/FGRCDoBBhoAQEORB
PrVCDoACKAACaAJuigUSEAAMkIIV+IM/KLQNOIBHLgBZC4AIKIAIIIAh4IACcGRHBgCHWzZfpTah
UtKVoGNyq2Vb7raAAAA7
------=_NextPart_000_000A_01C32463.473B80B0--
