Fw: [Mapserver-users] transparent background raster (tif)
Frank Warmerdam
warmerdam at pobox.com
Tue May 27 15:30:30 EDT 2003
Rosangela Silva wrote:
> Hi,
> My images are 8-bit TIFF, and they are peaces of sattelite
> images (Landsat - RGB composit).
> Part of these images has valid information,
> but another part is complemented with deep black color.
> I think that I couldn't specify a black collor pixel (0)
> like "transparent" because some lakes and rivers are black too.
> I'd like to show only the valid information.
> I'll try to send a tiff like an example.
> Thanks
> Rosângela
Rosângela,
Your image has exactly 0,0,0 for large areas, but some of the southern areas
are not exactly black. With MapServer 3.7 (err 4.0?) you could set an OFFSITE
value of 0,0,0 and all the exactly black areas would be transparent. However
if you want to mask all water areas as transparent you would need to do
something else.
Generally speaking, at that point you should take the image to some sort
of image processing software to mask and convert to a more suitable form to
display in mapserver. You could use GRASS, or some commercial software,
or even write a Python script on GDAL to do the processing.
Best regards,
and watch the world go round - Rush | Geospatial Programmer for Rent
