[Mapserver-users] Problem using FILTER.
braulioen at ono.com
Thu May 29 08:20:41 EDT 2003
Hi:
I am trying to filter a layer shape and I cannot. The file map is the
following one:
LAYER
NAME poligonos
DATA poligonos
STATUS DEFAULT
TYPE POLYGON
FILTER "masa='001'"
CLASS
COLOR 212 212 212
OUTLINECOLOR 0 0 0
TEMPLATE poligonos_template.html
END
END
where "masa" is the filtered feature of the shapefile, and I obtain
all the results, as if I did not use FILTER. Which is my error?.
Thanks.
Braulio.
