[Mapserver-users] styleObj? member of classObj?
    Gerald Buckmaster
    gbuckmaster at cox.net
    Sat May 31 13:54:49 PDT 2003
Greetings,
Trying to understand the 3.7/4.0 documentation in regards to styleObjs.
Reading the info on styleObj class leads me to believe instances of styleObj
are always embedded inside the classObj, yet when I look at the members of
the classObj, I don't see it named:
 Members:
   string name
   string title
   int    type
   int    status      (MS_ON, MS_OFF or MS_DELETE)
   int    minscale
   int    maxscale
   string template
   labelObj label
   int    numstyles
All I see is a member called numstyles and a method called getStyle().
So how do I "attach" a styleObj to a classObj?  Doesn't seem to be consistent,
ie the labelObj is named label.
	$cityLabel = $cityCls->label; # I understand
	$cityStyle = $cityCls->???; # no clue
Thanks,
Gerald
More information about the MapServer-users
