[Mapserver-users] compiling regex on windows
Stephen Clark
stephen.clark at focus.ca
Mon Nov 3 17:00:52 EST 2003
Heve you tried compiling using at a command window:
nmake /f makefile.vc
----- Original Message -----
To: <Mapserver-users at lists.gis.umn.edu>
Sent: Sunday, November 02, 2003 9:00 PM
Subject: [Mapserver-users] compiling regex on windows
> i'm trying to compile the regex lib on windows 2000 with vs.net. i get
> the following error:
> c:\source_code\regex-0.12\regex.c(63) : fatal error C1083: Cannot open
> include file: 'strings.h': No such file or directory
> then when i define HAVE_STRING_H to try to fix the above error i get
> these:
> c:\source_code\regex-0.12\regex.c(808) : error C2365: 're_set_syntax' :
> redefinition; previous definition was a 'function'
> c:\source_code\regex-0.12\regex.h(404) : see declaration of
> 're_set_syntax'
> c:\source_code\regex-0.12\regex.c(808) : error C2146: syntax error :
> missing ';' before identifier 'reg_syntax_t'
> c:\source_code\regex-0.12\regex.c(808) : fatal error C1004: unexpected
> end of file found
> anything i can do?
> thanks.
> abe
> Mapserver-users mailing list
> http://lists.gis.umn.edu/mailman/listinfo/mapserver-users
