[Mapserver-users] WMS connection for BC Albers -- howto ??
Swaminathan, Gayathri
gayathri at ou.edu
Tue Nov 4 10:58:18 EST 2003
Stephen,
Check this out for info on how to use WMS Client....
http://www.refractions.net/arc3wms/
But,if you opened the OGC file Shane sent in a text editor, you will find
the onlineresource URL and the Bbox...
So here goes your layer definition, that should work,
LAYER
NAME "wms_bcgov"
TYPE RASTER
STATUS ON
CONNECTIONTYPE WMS
CONNECTION URL
"http://slkapps2.env.gov.bc.ca/servlet/com.esri.wms.Esrimap&layers=<layernam
e>"
METADATA
"wms_srs" "EPSG:42102"
"wms_name" "wms_bgov"
"wms_server_version" "1.1.3"
# "wms_formatlist" "image/gif,image/png,image/jpeg,image/wbmp"
"wms_format" "image/png"
END
PROJECTION
"init=epsg:42102"
END
END
Substitute the <layername> with your layer of interest.,
http://slkapps2.env.gov.bc.ca/servlet/com.esri.wms.Esrimap?version=1.1.0&req
uest=capabilities
Returns the complete set of layers available.
HTH
Gayathri
-----Original Message-----
From: Stephen Clark [mailto:stephen.clark at focus.ca]
Sent: Tuesday, November 04, 2003 10:28 AM
To: Shane Nelson; mapserver-users at lists.gis.umn.edu
Subject: Re: [Mapserver-users] WMS connection for BC Albers -- howto ??
Shane,
I am not really sure hor to use this file you sent. me.
I was thinking of using this wms server as a layer in my *.map file like
below:
### wms layers from BC Gov.
LAYER
NAME "wms_bcgov"
TYPE RASTER
STATUS ON
CONNECTIONTYPE WMS
CONNECTION URL
"http://slkapps2.env.gov.bc.ca/servlet/com.esri.wms.esrimap"
METADATA
END
PROJECTION
"init=epsg:42102"
END
END
Is this possible?
----- Original Message -----
To: <mapserver-users at lists.gis.umn.edu>
Sent: Monday, November 03, 2003 4:03 PM
> Yes. I've attached an OGC file from the Arc3WMS client
> (http://www.refractions.net/arc3wms/). This particular server is very
picky
> about how it works.
> After loading the ogc file you can check the connection strings. If
> you
have
> beta2 of the WMS client they will be in the %temp%\wms_client_log.txt
file.
> ShaneQuoting Stephen Clark <stephen.clark at focus.ca>:
> > Hello,
> > Has anyone setup a wms connection to the BC Government wms servers
> > that
send
> > out data in C Albers format?
> > thanks,
> > Stephen
> > Mapserver-users mailing list Mapserver-users at lists.gis.umn.edu
> > http://lists.gis.umn.edu/mailman/listinfo/mapserver-users
